Skrujernet Skrevet 14. april 2009 Del Skrevet 14. april 2009 (endret) som overskriften sier er jeg ute på jakt etter et pent kabinett med veldig god luft flyt. Støy er ikke serdeles viktig. Vil helst ikke ha så mye fjortiss lys, men litt har ikke så mye og si vist det ser pent ut. Tenker på Antec 1200 eller Cooler master Storm sniper eller scout! Today, CM Storm is celebrating the deployment of the Scout™ true gaming chassis, created in close cooperation with the world’s leading professional gaming teams and eSports organizers, including Kode5, Team Fnatic and mousesports. Like all gear developed in the CM Storm Labs, the Scout has been heavily injected with Storm Tactics™ to ensure complete Strength, Security, and Control to the discerning gamer. Developed with elite engineering skills, and reinforced by the highest grade materials, your Storm gear will perform and deliver with unfailing reliability, letting you focus on your game and worry less about your hardware. Storm Tactics™ - Strength, Security, Control The Scout has been built around a solid steel body, and comes equipped with a 140mm front intake fan, as well as 140mm top and 120mm rear exhaust fans, providing an accurate airflow to efficiently manage the heat from your gaming hardware. The aggressive window side panel, with its dark automotive tint, provides mounting locations for yet another 2 x 120mm fans to deal with thermal hotspots from overclocked CPUs and GPUs. The Scout has been fortified even further with the patented StormGuard™ accessory; this unique and widely acclaimed security solution from the CM Storm Labs consists of a specially designed PCI-bracket located at the rear of the chassis body. By locking your peripherals and side panel firmly in place, Storm Tactics and the StormGuard will protect your PC and gaming gear from thieves and other thuggish individuals whenever you are AFK. Never again return to your seat at a LAN-party, only to find that some villain has grabbed your gaming mouse and headset, or even worse, your entire system. Model Number SGC-6000-KKN1-GP Available Color Black Material Steel, ABS Plastic, Mesh bezel Dimensions (D)566.6 x (W)254.6 X (H)551 mm (D)22.3 x (W)10 x (H)21.7 inch Net Weight 10.6 kg / 23.42 lb M/B Type Micro-ATX/ATX 5.25" Drive Bay 5 Exposed (without the use of exposed 3.5 inch Drive Bay) 3.5" Drive Bay 5 Hidden 1 Exposed (converted from one 5.25 inch Drive Bay) Cooling System Front: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA) Top: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA) (can be swapped for two 120mm fans or 120x240mm Radiator) Rear: 120x25mm Standard Fan x 1 (1200rpm, 17 dBA) (can be swapped for 90mm fan or 80mm fan) Bottom: Supports 140mm Fan x 1 or 120mm Fan x 1 w/ Dust Filter (optional) Side: Supports 200x30mm Fan x 1 (optional) 120x25mm Fan x 2 (optional) Expansion Slots Standard x 7, Special x 1 I/O Panel USB2.0 x 4; IEEE1394 x 1; eSATA x 1; Mic x 1; HD Audio+AC’97 x 1 Power Supply Standard ATX PS2 / EPS 12V (optional) Endret 14. april 2009 av atriC Lenke til kommentar
XYG Skrevet 6. mai 2009 Del Skrevet 6. mai 2009 Sjekk ut Vento også, er et undermerke til Asus. Ikke at jeg har noen som helst grunn til å anbefale det bortsett fra at jeg har sansen for Asus og er i ferd med å konvertere helt, til og med inkludert strömforsyning, etterhvert. La oss slenge med et smilefjes her også... Lenke til kommentar
Chavalito Skrevet 11. mai 2009 Del Skrevet 11. mai 2009 (endret) Jeg har et NZXT Apollo, men det ble for liten plass etter hvert, spesielt for kontaktene til skjermkortet. I dag fikk jeg mitt nye kabinett, CM Storm Sniper. Ganske stort kabinett ja, skulle ikke være problemer med plass. Nå er det bare i hive seg i gang med montering i det nye kabinettet. Lysene i viftene på Storm Sniper kan du slå av hvis du vil, men det kommer ikke jeg til å gjøre, det må jo være litt fancy au. Endret 11. mai 2009 av Chavalito Lenke til kommentar
Eirik Skrevet 11. mai 2009 Del Skrevet 11. mai 2009 http://microplex.no/aspx/produkt/prdinfovn...spx?plid=107565 Peeent Lenke til kommentar
