ASP: Får feilmelding ved registrering av ny kunde på nettbutikk
Hei
Driver nettbutikk problemet oppstår når det prøves å registrere seg som ny kunde. Når man trykket på "Registrer" knappen (etter å lagt inn personlia) kommer det en melding:
Server Error in '/' Application.
Mailbox name not allowed. The server response was: sorry, that domain isn't allowed to be relayed thru this MTA (#5.7.1)
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Net.Mail.SmtpFailedRecipientException: Mailbox name not allowed. The server response was: sorry, that domain isn't allowed to be relayed thru this MTA (#5.7.1)
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[smtpFailedRecipientException: Mailbox name not allowed. The server response was: sorry, that domain isn't allowed to be relayed thru this MTA (#5.7.1)]
MasterPage_UserRegistration.SendResponseEmail(Int3 2 CustomerID, String FullName, String UserName, String Email, String Password) +670
MasterPage_UserRegistration.Page_Load(Object sender, EventArgs e) +198
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Control.LoadRecursive() +141
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082
noen som kan hjelpe meg med dette? hos hvem ligger feilen?
  • 1 måned senere...
Stack Trace:
Stacktracen forteller egentlig svaret... Her ligger feilen i MasterPage_UserRegistration.SendResponseEmail(Int3 2 CustomerID, String FullName, String UserName, String Email, String Password) - og feilmeldingen ser ut til å indikere at du ikke får lov til å sende til den aktuelle e-mail-adressen, uten at jeg har vært borti akkurat den formuleringen tidligere. Sjekk innstillingene på mail-utsendelse?
  • 3 uker senere...
Problemet her ligger nok på e-postserveren som nettbutikken bruker. Feilmeldingen indikerer at e-postadressen som kunden skriver inn ikke er en adresse/et domene som e-postserveren har lov til å sende til.
Eventuelt så har avsender adressen ikke lov til å sende via den serveren som forsøkes brukt.
