Frederick_ Skrevet 12. april 2009 Rapporter Del Skrevet 12. april 2009 Hei skal ha en ny skjerm, en bra 24 - 26 tommer. Den skal brukes til film,spill og bare være på pcen. Kriterier: * Bra respons tid * bra farger * 24" - 26" Trenger hjelp litt fort, har lånt en 24" og orker ikke gå tilbake til en 19" Lenke til kommentar
whatever909 Skrevet 12. april 2009 Rapporter Del Skrevet 12. april 2009 jaja.. vis du SKAL ha noe som er større enn 24 uansett så drit i det jeg sier her denne skjermen her er super http://www.netshop.no/aspx/produkt/prdinfo...spx?plid=112214 syntes jeg 21,5tommer skarpebilder rask og enkel switching mellom HDMI,VGA og DVI koster 1 795,- så den er ikke dyr. her er en http://www.netshop.no/aspx/produkt/prdinfo...spx?plid=107988 ukens tilbud på netshop.......... men må stikke så kopierer/past fakta.. Highlights 26-inch widescreen display for a high definition video support up to 1080P with HDCP content protection Stylish black design with a piano black glossy front Frame rate conversation (fill to aspect ratio) Theme mode for optimized picture HDMI interface build in Ergonomics Optimum flicker-free and distortion-free picture Excellent color purity Well balanced brightness uniformity Excellent Advanced Contrast Ratio (5000:1) Space saving design Technical highlights 26 (66 cm) LCD widescreen display Excellent contrast (ACR) 5000:1 Brightness 300 cd/m2 Fast response time (typ.) 5 ms Internal power supply Reliability Low power consumption Power management according to EPA Guaranteed quality and stability Visible screen diagonal 26 inch (66 cm) Resolutions Pixels 1920 x 1200 Pixels* 1280 x 768 * expanded Picture size 554 x 348 mm Colors 16.7 million Pixel Pitch 0.2865 mm Frequencies Horizontal 30 - 83 kHz Vertical 56 - 75 Hz Brightness (typical) 300 cd/m² Advanced Contrast Ratio 5000:1 Viewing angle Horizontal 170° Vertical 160° Response time (typical) 5 ms Plug and Play VESA DDC2B Setting options Menu language (16 languages) Power saving mode Input signal select Theme Mode Brightness (Back light control) Contrast, Volume control Picture position (horizontal and vertical), H-size, Phase, Color temperature and individual color setting Auto-adjust (direct access key) Factory recall setting OSD Language English, German, Spanish, Portuguese, French, Italian, Russian, Swedish, Dutch, Finnish, Danish, Norwegian, Polish, Chinese, Japanese Base Tilt angle -5° / +15° Video input 1x D-SUB, 1x DVI-D (HDCP support), 1x HDMI Audio input / output Audio signal input 3.5 mm stereo phone jack Audio output 2 W (L) + 2 W ® Electrical values (internal power supply) Rated voltage 100 - 230 V Frequency 50 - 60 Hz Power draw Max. <65 W Stand by < 2 W Protection class 1 Temperatures/ dimensions/ weight Ambient temperature (to IEC721): Working (recommended) 5°C to 35°C Storage -20°C to 60°C Dimensions (H x W x D): (with stand) 475 x 603 x 239 mm Weight (Monitor only) 8,5 kg Reliability MTBF (demonstrated) 70,000 h Lifetime of LCD backlight 50,000 h (brightness > 50 % of original brightness) Compliance with standards Product safety EN60950 Ergonomics GS mark ISO13406-2 (Pixel fault class II) Radiation immunity and CE certification according RFI suppression to EC Directive 2004/108/EEC (EN55022/B, EN55024 EN61000-3-2/-3); RoHS Accessories Power cable (1.8 m)* 1x wall socket (Euro-Schuko-Type CEE7) Data cable (1.8 m)* D-SUB (15-pin) Audio cable (1.8 m)* 3.5 mm stereo phone jack * detachable on display Special features Standardized mounting interface according VESA FPMPMI (100 mm) Kensington Lock snakkes Lenke til kommentar
Økonom Skrevet 12. april 2009 Rapporter Del Skrevet 12. april 2009 (endret) Hei! Jeg har en BenQ G2400WD 24" (koster rundt 2400,- tror jeg) og er veldig fonøyd, den fungerer bra til spilling, film, nett osv. Oppløsningen er 1920x1200. Fargene og baklyset er jo ikke helt perfekt, men det kan man vel ikke regne med til den prisen. Det var digg å gå fra 17" til denne. Anbefales! Edit: BenQ har også modellene E2200HD og E2400HD, men disse er i 16:9 format og har 1920x1080 som høyeste oppløsning. Jeg synes det blir for bredt til å bruke som PC-skjerm, men til film er det fint. Endret 12. april 2009 av Økonom Lenke til kommentar
Frederick_ Skrevet 12. april 2009 Forfatter Rapporter Del Skrevet 12. april 2009 (endret) låner faktisk samme skjerm som deg Økonom. Tenker eg skal skaffe den. Bare lurte om det er noen bedre ute å går Tenker på den 26", blir det for stort for FPS gaming osv? Endret 12. april 2009 av Silo Lenke til kommentar
whatever909 Skrevet 12. april 2009 Rapporter Del Skrevet 12. april 2009 .. pris på den siste skjermen 2 495 låner faktisk samme skjerm som deg Økonom. Tenker eg skal skaffe den. Bare lurte om det er noen bedre ute å går Tenker på den 26", blir det for stort for FPS gaming osv? har en venn som digger FPS spilling med sånn passe stor skjerm .. vis det blir for jævlig så er det jo bare å dytte skjermen litt bakover Lenke til kommentar
Papirkurven Skrevet 12. april 2009 Rapporter Del Skrevet 12. april 2009 Tror neppe 26" blir for stort for spilling. Spiller mye CSS med 32" min, som jeg sitter en hall meter ifra, og det går helt fint. Lenke til kommentar
Frederick_ Skrevet 12. april 2009 Forfatter Rapporter Del Skrevet 12. april 2009 hmm, k. Men ser 26" har samme oppløsning som en 24" Er ikke da 26" litt teit? Lenke til kommentar
whatever909 Skrevet 13. april 2009 Rapporter Del Skrevet 13. april 2009 hmm, k. Men ser 26" har samme oppløsning som en 24" Er ikke da 26" litt teit? du må ha superøyne vis du skal begynne å klage over at 26 har samme oppløsning som en 21,5.. du kan tenke deg 1920 firkanter bortover * 1080firkanter nedover . på 21,5tommer og 26tommer.. man ser ikke synlige forskeller .. vet ikke helt om det var klart men prøvde ^^ Lenke til kommentar
Frederick_ Skrevet 13. april 2009 Forfatter Rapporter Del Skrevet 13. april 2009 kk, så legger ikke merke til noe ? Lenke til kommentar
whatever909 Skrevet 13. april 2009 Rapporter Del Skrevet 13. april 2009 kk, så legger ikke merke til noe ? nja du kan se forskjell men det kan være kvaliteten på skjermen på 21tommer og 26tommern.. men ikke sånn med pixsler det tror jeg ikke.. har en 50tommer tv som jeg spilte TF2 (full HD) og det samma med med min 21,5tommer . det som var forskjell som JEG syntes var at alt var mindre .. men så ikke no synlige forskjell .. smak og behag ^^ og 21,5tommer er mindre og sikkert lettere enn en 26tommer.. ja .. den 21,5 tommern er D¤¤¤ lett ^^ hadde en på 21tommer og var nesten 1.50 ganger tyngre Lenke til kommentar
