Debian/NSLU2 installer - rar feil: "Bootstrap error"
Hei,
Jeg installerer debian lenny på en linksys nslu2 og får en feil i installasjonsprogrammet som opplyser om en "bootstrap error". Maskinen har produsert en feilmelding som lyder slik fra der feilen begynner:
Klikk for å se/fjerne spoilerteksten nedenfor
Apr 9 19:27:20 debootstrap: dpkg pre-depends on lzma
Apr 9 19:27:20 debootstrap: lzma is not installed.
Apr 9 19:27:20 debootstrap: dpkg: warning - ignoring pre-dependency problem !
Apr 9 19:27:20 debootstrap: 338 files and directories currently installed.)
Apr 9 19:27:20 debootstrap: Preparing to replace dpkg 1.14.25 (using .../dpkg_1.14.25_armel.deb) ...
Apr 9 19:27:22 debootstrap: Unpacking replacement dpkg ...
Apr 9 19:27:31 kernel: [42952129.080000] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
Apr 9 19:27:31 kernel: [42952129.080000] sd 0:0:0:0: [sda] Sense Key : 0x3 [current]
Apr 9 19:27:31 kernel: [42952129.080000] sd 0:0:0:0: [sda] ASC=0x11 ASCQ=0xc
Apr 9 19:27:31 kernel: [42952129.080000] end_request: I/O error, dev sda, sector 6161344
Apr 9 19:27:31 kernel: [42952129.080000] EXT3-fs error (device sda5): ext3_find_entry: reading directory #150316 offset 0
Apr 9 19:27:33 kernel: [42952131.260000] EXT3-fs error (device sda5): ext3_add_entry: bad entry in directory #150316: directory entry across blocks - offset=0, inode=4294967295, rec_len=65536, name_len=255
Apr 9 19:27:33 debootstrap: dpkg: error processing var/cache/apt/archives/dpkg_1.14.25_armel.deb (--install):
Apr 9 19:27:33 debootstrap: error creating directory `./usr/share/locale/el/LC_MESSAGES': Input/output error
Apr 9 19:27:33 debootstrap: dpkg-deb: subprocess paste killed by signal (Broken pipe)
Apr 9 19:27:35 kernel: [42952133.520000] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
Apr 9 19:27:35 kernel: [42952133.520000] sd 0:0:0:0: [sda] Sense Key : 0x3 [current]
Apr 9 19:27:35 debootstrap: dpkg: error while cleaning up:
Apr 9 19:27:35 debootstrap: unable to stat installed post-installation script `/var/lib/dpkg/info/dpkg.postinst': Input/output error
Apr 9 19:27:35 kernel: [42952133.520000] sd 0:0:0:0: [sda] ASC=0x11 ASCQ=0xc
Apr 9 19:27:35 kernel: [42952133.520000] end_request: I/O error, dev sda, sector 8962826
Apr 9 19:27:35 kernel: [42952133.520000] EXT3-fs error (device sda6): ext3_get_inode_loc: unable to read inode block - inode=69963, block=295006
Apr 9 19:27:36 debootstrap: Errors were encountered while processing:
Apr 9 19:27:36 debootstrap: var/cache/apt/archives/dpkg_1.14.25_armel.deb
Apr 9 19:28:49 base-installer: error: exiting on error base-installer/debootstrap-failed
Apr 9 19:28:50 main-menu[2558]: WARNING **: Configuring 'bootstrap-base' failed with error code 1
Apr 9 19:28:50 main-menu[2558]: WARNING **: Menu item 'bootstrap-base' failed.
Apr 9 19:28:51 main-menu[2558]: DEBUG: resolver (libgcc1): package doesn't exist (ignored)
Apr 9 19:28:56 main-menu[2558]: INFO: Falling back to the package description for auto-install
Apr 9 19:28:56 main-menu[2558]: INFO: Falling back to the package description for ai-choosers
Apr 9 19:28:56 main-menu[2558]: INFO: Menu item 'di-utils-reboot' selected
Apr 9 19:29:00 main-menu[2558]: DEBUG: resolver (libgcc1): package doesn't exist (ignored)
Apr 9 19:29:05 main-menu[2558]: INFO: Falling back to the package description for auto-install
Apr 9 19:29:05 main-menu[2558]: INFO: Falling back to the package description for ai-choosers
Apr 9 19:29:05 main-menu[2558]: INFO: Menu item 'di-utils-shell' selected
Apr 9 19:29:07 main-menu[2558]: INFO: Menu item 'di-utils-shell' succeeded but requested to be left unconfigured.
Apr 9 19:29:07 main-menu[2558]: DEBUG: resolver (libgcc1): package doesn't exist (ignored)
Apr 9 19:29:11 main-menu[2558]: INFO: Falling back to the package description for auto-install
Apr 9 19:29:11 main-menu[2558]: INFO: Falling back to the package description for ai-choosers
Apr 9 19:29:11 main-menu[2558]: INFO: Menu item 'save-logs' selected
Jeg synes det er velidg rart, for jeg har brukt samme speil (det offisielle danske) tidligere uten problemer. Jeg prøvde også det svenske, men fikk den same feilmeldingen. Jeg har imidlertid byttet hvilken usbnøkkel jeg installerer til siden sist.. hva kan dette være fornoe rart?
Endret av illshit
