[Løst]Finner ikke nettverk i Ubuntu 8.10
Hei
Har lastet ned Ubuntu 8.10 på min maskin. Alt funker bortsett fra det trådløse nettverket. Det funker forsåvidt fint med kabel, og i windows. Problemet er at jeg rett og slett ikke finner nettverket på den lista over trådløse nettverk i Ubuntu.
Utskrift av lspci:
00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 0c)
00:01.0 PCI bridge: Intel Corporation Mobile PM965/GM965/GL960 PCI Express Root Port (rev 0c)
00:1a.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 02)
00:1a.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 02)
00:1a.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 02)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 02)
00:1c.4 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 5 (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f2)
00:1f.0 ISA bridge: Intel Corporation 82801HEM (ICH8M) LPC Interface Controller (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) SATA IDE Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 02)
01:00.0 VGA compatible controller: nVidia Corporation GeForce 8600M GT (rev a1)
03:09.0 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller (rev 05)
03:09.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 22)
03:09.2 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 12)
03:09.3 System peripheral: Ricoh Co Ltd xD-Picture Card Controller (rev 12)
09:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8040 PCI-E Fast Ethernet Controller (rev 12)
0b:00.0 Network controller: Intel Corporation PRO/Wireless 4965 AG or AGN [Kedron] Network Connection (rev 61)
Utskrift av iwconfig:
lo no wireless extensions.
eth0 no wireless extensions.
wmaster0 no wireless extensions.
wlan0 IEEE 802.11abgn ESSID:""
Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated
Tx-Power=15 dBm
Retry min limit:7 RTS thr:off Fragment thr=2352 B
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
pan0 no wireless extensions.
Utskrift av ifconfig:
eth0 Link encap:Ethernet HWaddr 00:15:c5:84:4d:04
inet addr:62.16.237.97 Bcast:62.16.237.255 Mask:255.255.255.0
inet6 addr: fe80::215:c5ff:fe84:4d04/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1933293 errors:0 dropped:0 overruns:0 frame:0
TX packets:1388551 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2711885932 (2.7 GB) TX bytes:97297105 (97.2 MB)
Interrupt:16
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:2088 errors:0 dropped:0 overruns:0 frame:0
TX packets:2088 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:109699 (109.6 KB) TX bytes:109699 (109.6 KB)
wlan0 Link encap:Ethernet HWaddr 00:1d:e0:45:e1:09
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wmaster0 Link encap:UNSPEC HWaddr 00-1D-E0-45-E1-09-00-00-00-00-00-00-00-00-00-00
Har en Dell XPS 1530 hvis det skulle ha noe å si. Takker på forhånd!
Har gjort som du sier og får da dette:
xxx@xxx-computer:~$ iwconfig wlan0 essid dlink
Error for wireless request "Set ESSID" (8B1A) :
SET failed on device wlan0 ; Operation not permitted.
xxx@xxx-computer:~$ ifconfig wlan0 up
SIOCSIFFLAGS: Permission denied
xxx@xxx-computer:~$ dhcpcd
The program 'dhcpcd' is currently not installed. You can install it by typing:
sudo apt-get install dhcpcd
bash: dhcpcd: command not found
xxx@xxx-computer:~$
Siden du bruker ubuntu må du bruke sudo for å få de nødvendige rettighetene, samt bytte ut dhcpcd med dhclient, slik:
sudo iwconfig wlan0 essid dlink
sudo dhclient wlan0
Prøvde du "iwlist wlan0 scan" slik Goophy foreslo?
En mulig årsak til problemet ditt kan være at routeren er satt til å bruke en kanal som ikke er lovlig i USA. For å være sikker på at det ikke er det som er problemet kan du sette den til en kanal under 10.
Goophy sitt forslag:
xxx@xxx-computer:~$ iwlist wlan0 scan
wlan0     No scan results
anders iver sitt forslag:
xxx@xxx-computer:~$ sudo iwconfig wlan0 essid dlink
xxx@xxx-computer:~$ sudo dhclient wlan0
Internet Systems Consortium DHCP Client V3.1.1
Copyright 2004-2008 Internet Systems Consortium.
All rights reserved.
For info, please visit [url="http://www.isc.org/sw/dhcp/"]http://www.isc.org/sw/dhcp/[/url]
wmaster0: unknown hardware address type 801
Listening on LPF/wlan0/00:1d:e0:45:e1:09
Sending on   LPF/wlan0/00:1d:e0:45:e1:09
Sending on   Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 12
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 18
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
Skjønte ikke helt hva du mente med dette:
Hvilke kanaler (frekvenser) som er lov til å bruke er sterkt regulert bl.a i Norge og USA, og det er forskjellige lover som gjelder. Noen drivere lar deg bare koble til nettverk på lovlige frekvenser. Det skal være mulig å endre region slik at driveren godtar norske frekvenser, men jeg er usikker på hvordan det skal gjøres.
Prøv med "sudo iwlist wlan0 scan", jeg har opplevd tidligere at det gjør en forskjell.
