Gjest Skrevet 3. april 2009 Del Skrevet 3. april 2009 (endret) Hei! Prøver meg på chat script via LAN. Og skal legge til navnene som connecter i listview1. Alle meldinger blir sendt til en CMD vindu som kjører på egen maskin som igjen viser det i klient vinduet. Men vil også legge til navnene i listview1 for de som connecter. Kode for å hente meldinger: Private Sub getMessage() For infiniteCounter = 1 To 2 infiniteCounter = 1 serverStream = clientSocket.GetStream() Dim buffSize As Integer Dim inStream(10024) As Byte buffSize = clientSocket.ReceiveBufferSize serverStream.Read(inStream, 0, buffSize) Dim returndata As String = _ System.Text.Encoding.ASCII.GetString(inStream) readData = "" + returndata msg() Next End Sub Koden for server vinduet: Imports System.Net.SocketsImports System.Text Module Module1 Dim clientsList As New Hashtable Sub Main() Dim serverSocket As New TcpListener(8888) Dim clientSocket As TcpClient Dim infiniteCounter As Integer Dim counter As Integer serverSocket.Start() msg("Chat Server Started ....") counter = 0 infiniteCounter = 0 For infiniteCounter = 1 To 2 infiniteCounter = 1 counter += 1 clientSocket = serverSocket.AcceptTcpClient() Dim bytesFrom(10024) As Byte Dim dataFromClient As String Dim networkStream As NetworkStream = _ clientSocket.GetStream() networkStream.Read(bytesFrom, 0, CInt(clientSocket.ReceiveBufferSize)) dataFromClient = System.Text.Encoding.ASCII.GetString(bytesFrom) dataFromClient = _ dataFromClient.Substring(0, dataFromClient.IndexOf("$")) clientsList(dataFromClient) = clientSocket broadcast(dataFromClient + " Joined ", dataFromClient, False) broadcast(dataFromClient, dataFromClient, False) msg(dataFromClient + " Joined chat room ") Dim client As New handleClinet client.startClient(clientSocket, dataFromClient, clientsList) Next clientSocket.Close() serverSocket.Stop() msg("exit") Console.ReadLine() End Sub Sub msg(ByVal mesg As String) mesg.Trim() Console.WriteLine(" >> " + mesg) End Sub Private Sub broadcast(ByVal msg As String, _ ByVal uName As String, ByVal flag As Boolean) Dim Item As DictionaryEntry For Each Item In clientsList Dim broadcastSocket As TcpClient broadcastSocket = CType(Item.Value, TcpClient) Dim broadcastStream As NetworkStream = _ broadcastSocket.GetStream() Dim broadcastBytes As [byte]() If flag = True Then broadcastBytes = Encoding.ASCII.GetBytes(uName + " says : " + msg) Else broadcastBytes = Encoding.ASCII.GetBytes(msg) End If broadcastStream.Write(broadcastBytes, 0, broadcastBytes.Length) broadcastStream.Flush() Next End Sub Public Class handleClinet Dim clientSocket As TcpClient Dim clNo As String Dim clientsList As Hashtable Public Sub startClient(ByVal inClientSocket As TcpClient, _ ByVal clineNo As String, ByVal cList As Hashtable) Me.clientSocket = inClientSocket Me.clNo = clineNo Me.clientsList = cList Dim ctThread As Threading.Thread = New Threading.Thread(AddressOf doChat) ctThread.Start() End Sub Private Sub doChat() Dim infiniteCounter As Integer Dim requestCount As Integer Dim bytesFrom(10024) As Byte Dim dataFromClient As String Dim sendBytes As [byte]() Dim serverResponse As String Dim rCount As String requestCount = 0 For infiniteCounter = 1 To 2 infiniteCounter = 1 Try requestCount = requestCount + 1 Dim networkStream As NetworkStream = _ clientSocket.GetStream() networkStream.Read(bytesFrom, 0, CInt(clientSocket.ReceiveBufferSize)) dataFromClient = System.Text.Encoding.ASCII.GetString(bytesFrom) dataFromClient = _ dataFromClient.Substring(0, dataFromClient.IndexOf("$")) msg("From client - " + clNo + " : " + dataFromClient) rCount = Convert.ToString(requestCount) broadcast(dataFromClient, clNo, True) Catch ex As Exception MsgBox(ex.ToString) End Try Next End Sub End Class End Module Kode for klient vinduet: Imports System.Net.SocketsImports System.Text Public Class Form1 Dim clientSocket As New System.Net.Sockets.TcpClient() Dim serverStream As NetworkStream Dim readData As String Dim infiniteCounter As Integer Private Sub Button1_Click(ByVal sender As System.Object, _ ByVal e As System.EventArgs) Handles Button1.Click Dim outStream As Byte() = _ System.Text.Encoding.ASCII.GetBytes(TextBox2.Text + "$") serverStream.Write(outStream, 0, outStream.Length) serverStream.Flush() End Sub Private Sub msg() If Me.InvokeRequired Then Me.Invoke(New MethodInvoker(AddressOf msg)) Else TextBox1.Text = TextBox1.Text + Environment.NewLine + " >> " + readData End If End Sub Private Sub Button2_Click(ByVal sender As System.Object, _ ByVal e As System.EventArgs) Handles Button2.Click Try readData = "Conected to Chat Server ..." msg() clientSocket.Connect("127.0.0.1", 8888) Label1.Text = "Client Socket Program - Server Connected ..." serverStream = clientSocket.GetStream() clientsList.Items.Add(TextBox3.Text) Dim outStream As Byte() = _ System.Text.Encoding.ASCII.GetBytes(TextBox3.Text + "$") serverStream.Write(outStream, 0, outStream.Length) serverStream.Flush() Dim ctThread As Threading.Thread = New Threading.Thread(AddressOf getMessage) ctThread.Start() Catch ex As Exception TextBox1.Text = "Serveren er nede!" End Try End Sub Håper noen vil ta seg tid ^^ EDIT: Det med admin kan vi ta senere ^^ Endret 3. april 2009 av Gjest Lenke til kommentar
Merko Skrevet 3. april 2009 Del Skrevet 3. april 2009 (endret) Kommer ikke langt når man copy\paster koder fra andre nettsteder. Iallefall ikke når man er helt fersk i VB. Start fra begynnelsen og lær litt etter litt. Sockets må du også lære deg til dette. Endret 3. april 2009 av Merkoen Lenke til kommentar
Wubbable Skrevet 3. april 2009 Del Skrevet 3. april 2009 Vi ser at du klarer det helt selv ja, når du må spørre oss om å lage hele programmet for deg... Hør på Merkoen du Lenke til kommentar
