Høy ping på Internett med Tiscali ISDN.
Har hatt forferdlig ping i online spel i det siste. Og no ser det ut som at det er til alle servere untatt tiscali nettet. Andre som har samme problemet eller?
Ser ut som det er tiscali som sliter litt...
D:>ping q2.online.no
Pinging games8.online.no [193.213.112.73] with 32 bytes of data:
Reply from 193.213.112.73: bytes=32 time=250ms TTL=241
Reply from 193.213.112.73: bytes=32 time=234ms TTL=241
Ping statistics for 193.213.112.73:
   Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
   Minimum = 234ms, Maximum =  250ms, Average =  242ms
Reply from 193.213.112.73: bytes=32 time=219ms TTL=241
Reply from 193.213.112.73: bytes=32 time=235ms TTL=241
   Minimum = 219ms, Maximum =  250ms, Average =  238ms
D:>ping www.hardware.no
Pinging delta.hardware.no [217.77.34.213] with 32 bytes of data:
Reply from 217.77.34.213: bytes=32 time=344ms TTL=243
Reply from 217.77.34.213: bytes=32 time=297ms TTL=243
Reply from 217.77.34.213: bytes=32 time=250ms TTL=243
Reply from 217.77.34.213: bytes=32 time=313ms TTL=243
Ping statistics for 217.77.34.213:
   Minimum = 250ms, Maximum =  344ms, Average =  301ms
D:>ping www.tiscali.no
Pinging www.tiscali.no [213.142.64.172] with 32 bytes of data:
Reply from 213.142.64.172: bytes=32 time=31ms TTL=249
Ping statistics for 213.142.64.172:
   Minimum = 31ms, Maximum =  31ms, Average =  31ms
D:>tracert www.hardware.no
Tracing route to delta.hardware.no [217.77.34.213]
over a maximum of 30 hops:
 1    15 ms    31 ms    32 ms  ppp1-6.br.tiscali.no [213.142.67.150]
 2    31 ms    31 ms    16 ms  fe-0-1.per0.br.tiscali.no [213.142.67.129]
 3    31 ms    31 ms    32 ms  213.234.97.66
 4    47 ms    31 ms    31 ms  lo0.cr0.oeke.tiscali.no [213.142.65.3]
 5   219 ms   218 ms   219 ms  so-1-1-0.osl11.ip.tiscali.net [213.200.84.5]
 6   219 ms     *      234 ms  so-2-0-0.ams10.ip.tiscali.net [213.200.81.54]
 7   219 ms   218 ms   235 ms  br1.AMS1.gblx.net [193.148.15.80]
 8   250 ms   219 ms   234 ms  so4-0-0-2488M.cr2.AMS2.gblx.net [208.49.136.173]
 9   250 ms   250 ms   235 ms  pos9-0-2488M.cr1.CPH1.gblx.net [64.215.37.17]
10   250 ms   250 ms   250 ms  so4-0-0-2488M.ar1.OSL1.gblx.net [67.17.214.98]
11    78 ms    94 ms    78 ms  Easynet.ge-0-3-0-101.ar1.OSL1.gblx.net [64.208.2
22.174]
12    78 ms    93 ms    79 ms  gate2.easynet.no [217.77.32.167]
13   266 ms   265 ms   282 ms  delta.hardware.no [217.77.34.213]
Trace complete.
D:>tracert q2.online.no
Tracing route to games8.online.no [193.213.112.73]
 1    31 ms    16 ms    31 ms  ppp1-6.br.tiscali.no [213.142.67.150]
 2    31 ms    31 ms    31 ms  fe-0-1.per0.br.tiscali.no [213.142.67.129]
 3    31 ms    32 ms    15 ms  213.234.97.98
 4    47 ms    32 ms    31 ms  lo0.cr0.oeke.tiscali.no [213.142.65.3]
 5   218 ms   203 ms   219 ms  so-1-1-0.osl11.ip.tiscali.net [213.200.84.5]
 6   219 ms   203 ms   203 ms  so-1-0-0.cph10.ip.tiscali.net [213.200.81.5]
 7   219 ms   203 ms   235 ms  utfors-gw.dix.dk [192.38.7.92]
 8   219 ms   218 ms   219 ms  ge-0-1-0.se-sthms001-pe-1.utfors.net [212.105.10
1.202]
 9   234 ms   250 ms   250 ms  ti600000b051-ge4-2.ti.telenor.net [148.122.8.13]
10   250 ms   250 ms   266 ms  ti600001c050-ge6-1.ti.telenor.net [146.172.126.4
1]
11   265 ms   266 ms   250 ms  ti100001c050-pos13-0.ti.telenor.net [146.172.126
.33]
12   250 ms   250 ms   265 ms  ti100910d050-ge0-0.ti.telenor.net [146.172.249.1
58]
13    62 ms    63 ms    63 ms  ti100910a085-vlan10.ti.telenor.net [146.172.164.
211]
14   235 ms   234 ms   234 ms  games8.online.no [193.213.112.73]
Trace complete.
D:>
Noken som veit kva eg kan gjere?
Eg skal no teste med eit anna inet abb... dei samme testane...
Reply from 213.142.64.172: bytes=32 time=266ms TTL=244
Reply from 213.142.64.172: bytes=32 time=641ms TTL=244
Reply from 213.142.64.172: bytes=32 time=235ms TTL=244
   Minimum = 235ms, Maximum =  641ms, Average =  352ms
Reply from 217.77.34.213: bytes=32 time=78ms TTL=244
   Minimum = 78ms, Maximum =  78ms, Average =  78ms
Reply from 193.213.112.73: bytes=32 time=47ms TTL=249
Reply from 193.213.112.73: bytes=32 time=31ms TTL=249
   Minimum = 31ms, Maximum =  47ms, Average =  39ms
D:>
Gadd ikkje og ta tracert... men merka jo at tiscali sleit litt... Må vel ta og ringe til dei.
Andre med tiscali her som har det samme problemet?
Til og med websurfing går jo sørpetreigt....
Dette testa eg med Start.no sin gratis greie uten passord og brukernavn (tlf nr 21405060)
Prøv og ping www.tiscali.no og lim inn resultatet... Sjekke om det er likt over alt!
Virker som det er tiscali som har problemer ja .
Pinger games8.online.no [193.213.112.73] med 32 byte data:
Svar fra 193.213.112.73: byte=32 tid=224ms TTL=242
Svar fra 193.213.112.73: byte=32 tid=230ms TTL=242
Svar fra 193.213.112.73: byte=32 tid=232ms TTL=242
Ping-statistikker for 193.213.112.73:
Pakker: sendt = 4, mottatt = 4, tapt = 0 (0% tap),
Gjennomsnittlig tid for tur-retur i millisekunder:
minimum = 224ms, maksimum = 232ms, gjennomsnittlig = 227ms
D:>ping hardware.no
Pinger hardware.no [217.77.34.213] med 32 byte data:
Svar fra 217.77.34.213: byte=32 tid=250ms TTL=243
Svar fra 217.77.34.213: byte=32 tid=246ms TTL=243
Svar fra 217.77.34.213: byte=32 tid=247ms TTL=243
Svar fra 217.77.34.213: byte=32 tid=248ms TTL=243
Ping-statistikker for 217.77.34.213:
minimum = 246ms, maksimum = 250ms, gjennomsnittlig = 247ms
D:>ping vg.no
Pinger vg.no [193.69.165.20] med 32 byte data:
Svar fra 193.69.165.20: byte=32 tid=203ms TTL=247
Svar fra 193.69.165.20: byte=32 tid=207ms TTL=247
Svar fra 193.69.165.20: byte=32 tid=201ms TTL=247
Svar fra 193.69.165.20: byte=32 tid=199ms TTL=247
Ping-statistikker for 193.69.165.20:
minimum = 199ms, maksimum = 207ms, gjennomsnittlig = 202ms
D:>ping tiscali.no
Pinger tiscali.no [213.142.64.173] med 32 byte data:
Svar fra 213.142.64.173: byte=32 tid=23ms TTL=249
Svar fra 213.142.64.173: byte=32 tid=25ms TTL=249
Svar fra 213.142.64.173: byte=32 tid=24ms TTL=249
Ping-statistikker for 213.142.64.173:
minimum = 23ms, maksimum = 25ms, gjennomsnittlig = 23ms
Jeg har ADSL fra tiscali, og dette var jo noen ordentlige dritresultater.
C:>ping tiscali.no
Pinging tiscali.no [213.142.64.172] with 32 bytes of data:
Reply from 213.142.64.172: bytes=32 time=235ms TTL=239
Reply from 213.142.64.172: bytes=32 time=219ms TTL=239
   Minimum = 219ms, Maximum =  235ms, Average =  231ms
C:>ping online.no
Pinging online.no [148.122.161.36] with 32 bytes of data:
Reply from 148.122.161.36: bytes=32 time=16ms TTL=56
Ping statistics for 148.122.161.36:
   Minimum = 16ms, Maximum =  16ms, Average =  16ms
C:>ping hardware.no
Pinging hardware.no [217.77.34.213] with 32 bytes of data:
Reply from 217.77.34.213: bytes=32 time=32ms TTL=245
Reply from 217.77.34.213: bytes=32 time=16ms TTL=245
   Minimum = 16ms, Maximum =  32ms, Average =  24ms
Har Telenor ADSL
Virker som om Tiscali sine linjer sliter litt, kanskje de er under angrep eller noe :shrug:
Dette er pga. at tiscali router mye av trafikken b.la til telenor via utlandet. Trafikk til b.la uninett går via nix. Dette er veldi dårlig av tiscali. Ser ut til å gå via danmark nå, menst det gikk via amsterdam før. Men det er vel ikke så veldi mange som er helt avhengige av lav ping. Det det er mest viktig for er vel de som spiller over nettet.
Er sånn alt i alt fornøyd med farten til tiscali, men har falt ned noen ganger da, det er værre men er alltid bare å resette modemet, men det er ikke så lett når du ikke er der modemet er.. :( Ringte de og de skulle sende feilmelding på det.
Det går seriøst treigere og surfe... man merker det når man har eit halvt sekund ping.
Microsoft Windows 2000 [Version 5.00.2195]
© Copyright 1985-2000 Microsoft Corp.
D:>tracert www.telenor.no
Tracing route to hotell-redsys.nextel.no [148.122.210.22]
 1    31 ms    31 ms    32 ms  ppp1-6.br.tiscali.no [213.142.67.150]
 2    16 ms    31 ms    32 ms  fe-0-1.per0.br.tiscali.no [213.142.67.129]
 3    32 ms    31 ms    31 ms  213.234.97.98
 4    31 ms    32 ms    32 ms  lo0.cr0.oeke.tiscali.no [213.142.65.3]
 5   203 ms   219 ms   219 ms  so-1-1-0.osl11.ip.tiscali.net [213.200.84.5]
 6   219 ms   219 ms   203 ms  so-1-0-0.cph10.ip.tiscali.net [213.200.81.5]
 7   218 ms   219 ms   219 ms  utfors-gw.dix.dk [192.38.7.92]
 8   250 ms   250 ms   250 ms  ge-0-1-0.se-sthms001-pe-1.utfors.net [212.105.10
1.202]
 9   250 ms   235 ms   250 ms  ti600000b051-ge4-2.ti.telenor.net [148.122.8.13]
10   266 ms   266 ms   250 ms  ti600001c050-ge6-1.ti.telenor.net [146.172.126.4
1]
11   266 ms   265 ms   266 ms  ti100001c050-pos13-0.ti.telenor.net [146.172.126
.33]
12   266 ms   250 ms   265 ms  ti100910d050-ge0-0.ti.telenor.net [146.172.249.1
58]
13    78 ms    63 ms    78 ms  ti100910a085-vlan10.ti.telenor.net [146.172.164.
211]
14   250 ms   250 ms   235 ms  hotell-redsys.nextel.no [148.122.210.22]
Trace complete.
Reply from 148.122.210.22: bytes=32 time=235ms TTL=242
Request timed out.
Reply from 148.122.210.22: bytes=32 time=250ms TTL=242
Reply from 148.122.210.22: bytes=32 time=234ms TTL=242
Ping statistics for 148.122.210.22:
   Packets: Sent = 257, Received = 241, Lost = 16 (6% loss),
   Minimum = 218ms, Maximum =  1406ms, Average =  309ms
Control-C
^C
D:>
Nei.. skal vi skifte ISP eller? F4en det heng jo ikkje på ei greip!
Jo, det er sant men det er jo ikke snakk om et halvt sekund her over lenger tid, det høyeste jeg har sett er 260.
Ja, hadde jeg ikke hatt et års bindingstid så hadde jeg nok bytta til Bluecom. Var tenkt på å velge det men ble tiscali pga. at Bluecom ble en del dyrere for en fattig arbeidsløs fyr. At en har 260 ms i ping er nok desverre ingen grunnn for heving tipper jeg, men funker da bra nok for meg!=) Har ikke bra nok maskin til å spille med der, og jeg spiller generelt lite over nettet så det er mest surfing, video titting, og nedlasting.
Det har lenge vært et kjent faktum at Tiscali er totalt ubruklig til online gaming. Til tider også ubruklig til vanlig surfing..
Er selv veldig glad for at jeg ikke valgte Tiscali.. jeg har blucom, og de leverer en helt stabil linje som aldri synker under oppgitt hastighet.
"Pinging vg.no [193.69.165.20] with 32 bytes of data:
Reply from 193.69.165.20: bytes=32 time=15ms TTL=250
Reply from 193.69.165.20: bytes=32 time=31ms TTL=250
Ping statistics for 193.69.165.20:
Minimum = 15ms, Maximum = 31ms, Average = 19ms"
Så du vil berre sende eine vegen du da? Vil du ikkje ha svar tilbake når du sender ut info? Det vil i allefall eg (i form at av websida loades etc) Du skjønner det er vedlig ofte fint og få tilbakemelding på ting man sender ut, og singalet må jo gå 2 veger... Dessuten så har eg sett at det har vore oppi 1000 ms også! Satte på ping host -t ei stund... og så var det pakker som ikkje kom fram i det heile.
Formann: Spar oss for sånne innlegg... (ja jai elska bluecom)
Tenk vis alle fra tele2, ngt, bluecom (deg) catch firstmile? telenor skal sei kor glade dei er i linja si? Opprett ein post under søppel til slikt...
Dessuten kan eg skifte isp når eg vil... kom btw rekning i postkassa nuh...
Det eg lurte på om det var min pc som var heilt totalt føkka eller om det var andre som hadde samme problem.
Hva mener du her? Det er da et kjent problem med ADSL at det er lav opp hastighet, noe som fører til at ikke alle pakker kommer gjenom her. Har med bekreftelse av tcp pakker og gjøre. Dette fører til at du får høy ping når du laster ned. Dette er ikke noe som bare tiscali sliter med, men som alle adsl levrandører som har lav ut-hastighet sliter med.
Pingen på online spill, lå ca på 25 for meg idag... Men jeg har merka at nettet har vært litt tregt av og til.
Game server ip?
Din ISP?
Min Isp: TISCALI
Ip til server på tiscali linje: feks: 213.142.64.191
Du får sikkert en helv"#¤& ping hvis du ikke har ticali, men.
Game server ip?
Din ISP?
Min Isp: TISCALI
Forresten det er Counter-strike det er snakk om....!
Har fått veldig dårlig ping de siste dagene hos tiscali jeg også. Men det går visst litt opp og ned virker det som...på fredag hadde jeg ganske bra ping.
Er dette noe som kan bli fiksa med tiden eller vil tiscali ha så dårlig ping for alltid? Nytter jo nesten ikke å spille online med så høy ping.
Hvis dere hadde giddet å lese litt i forumet så hadde dere sikkert funnet endel tråder på nettopp dette og da hadde dere sikkert fått svar på det dere lurer på....
Men siden dere ikker er helt oppdatert:
Saksnr : 133 Status : Åpen
Starttid: 24/04-2003 06:00 (ca.) Sluttid: 24/04-2003 07:00 (ca.)
Berørt : Alle kunder
Vi skal oppgradere vår knutepunkt og det vil i den forbindelse bli avbrudd på forbindelsen i tidsrommet. Vi beklager de ulemper dette medfører for våre kunder.
Starttid: 28/04-2003 06:00 (ca.) Sluttid: 28/04-2003 07:00 (ca.)
Fortsettelse av arbeidet på torsdag 24/4.
Det vil oppleves brudd på forbindelsen i tidsrommet.
Det vil da si at Tiscali driver å utbedrer linja slik at tingenes tilstand blir bedre...
Slik jeg har forstått det er det TiNet (www.tiscali.net) som driver med peering-avtalene til Tiscali Norge og det er da de som må inngå eventuelle peeringavtaler med ISP'er i Norge, så suger pingen din mot tiscali kontakt din isp å få dem til å signere peering avtale med TiNet.
Har du Tiscali, kontakt dem og be pent om å få peering mot eventuelle isp'er, så kan de videreformidle det.
Hjalp dette?
Spoink: hvor finner du driftsmeldingene hen? På tiscali.no står det bare at driftsmeldingtjenesten er ute av drift...
Siden jeg har hatt Tiscali som isp i snart 3 år har jeg klart å melde meg på en maillingliste som sender ut disse meldingene. Dog har jeg forsøkt å melde meg av uten hell :)
Well sånn er det.
