aspic Skrevet 2. april 2009 Del Skrevet 2. april 2009 Hei! Dette er vel igrunn noko eg burde kunne sidan eg tross alt går ei datarettet linje, men som topic seier får eg eit par (i mine auger) "rare" feil ved HTML-validatoren hjå w3: Line 19, Column 7: document type does not allow element "BODY" here <body> The element named above was found in a context where it is not allowed. This could mean that you have incorrectly nested elements -- such as a "style" element in the "body" section instead of inside "head" -- or two elements that overlap (which is not allowed). One common cause for this error is the use of XHTML syntax in HTML documents. Due to HTML's rules of implicitly closed elements, this error can create cascading effects. For instance, using XHTML's "self-closing" tags for "meta" and "link" in the "head" section of a HTML document may cause the parser to infer the end of the "head" section and the beginning of the "body" section (where "link" and "meta" are not allowed; hence the reported error). Slik ser koden ut: <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Frameset//EN" "http://www.w3.org/TR/html4/frameset.dtd"> <html> <head> <link rel="stylesheet" href="css/lightbox.css" type="text/css" media="screen"> <script type="text/javascript" src="js/prototype.js"></script> <script type="text/javascript" src="js/scriptaculous.js?load=effects,builder"></script> <script type="text/javascript" src="js/lightbox.js"></script> <meta http-equiv="Content-Language" content="no-nyn"> <meta http-equiv="content-type" content="text/html; charset=UTF-8"> <title>Rosendal Gardsmat!</title> </head> <body> Og vidare kjem innhaldet. Det er nok berre ein tullefeil eller noko eg har, men har verkeleg behov for å finne ut kvifor dette skjer. All hjelp mottas med takk Lenke til kommentar
Wedvich Skrevet 2. april 2009 Del Skrevet 2. april 2009 (endret) Når du bruker frameset-doctypen bruker du <frameset> i stedet for <body>, og putter innholdet via eksterne filer med<frame>'er. Eventuelt kan du putte en <noframe> inni <frameset>'en og ha vanlig HTML-innhold der. Hvis du vil ha innholdet i en <body> må du bruke en annen doctype (transitional f.eks.) Endret 2. april 2009 av Wedvich Lenke til kommentar
aspic Skrevet 2. april 2009 Forfatter Del Skrevet 2. april 2009 Ahh, takk for respons. Kva er anbefalt å bruke då? Ha frameset-doctype eller skifte til transitional? Lenke til kommentar
akkapakka Skrevet 2. april 2009 Del Skrevet 2. april 2009 (endret) Her får du vite hvilken du skal bruke og hvorfor det er viktig. http://www.alistapart.com/articles/doctype/ Endret 2. april 2009 av Exatic Lenke til kommentar
