Jeg vil bare informere at Eset har kommet med en ny versjon av sin antivirus og Security Senter.
Den blir kalt versjon V4.
Programmet er raskere, sikkere også videre.
Du kan laste ned 31 dager trailer her:
http://www.eset.com/
What's New
Smarter Scanner — Threats don't always enter in ways you expect. ESET Smart Security inspects SSL-encrypted communication channels like HTTPS and POP3S, and intelligently scans compressed files to find threats that other products miss. ESET's Smart Optimization feature makes file scanning faster than ever.
Time-saving Firewall — The new Learning Mode saves time by automatically creating firewall rules by observing how you use your computer, while offering advanced firewall modes for power users.
Upgraded Antispam — ESET Smart Security now takes care of annoying spam with a smaller, faster, and even more effective spam filter.
Removable Media Security — Threats can enter your PC from removable media such as USB thumb drives. For self-running media, ESET Smart Security scans autorun.inf and associated files on mount, in addition to scanning any file on any removable device when it is accessed, or during a full-scan of the media. Power users can adjust ESET Smart Security to perform additional levels of scanning on removable media.
System Tools — ESET SysInspector and ESET SysRescue simplify diagnosis and cleaning of infected systems by allowing deep scans of system processes to find hidden threats, and creating bootable rescue CD/DVD or USB drives to help you repair an infected computer.
Self Defense — ESET Smart Security has built-in technology to prevent malicious software from corrupting or disabling it, so you can rest assured your system is always protected.
Usability Improvements — ESET Smart Security has numerous speed, security and usability upgrades.
* Energy-sipping battery mode extends laptop battery life without compromising security
For se om brannvreggdelen har blitt bedere.
Vi som følger med på dette vet at den har vært alt for svak.
Eset er selvføgelig bra på virus delen.
For se om matousec får testet den om en stund.
http://www.matousec.com/projects/firewall-...nge/results.php
Jeg tror ikke helt på den der fordi det står FREE på noen programmer som ikke er gratis. Pluss alle er nesten utdatert.
Så tror jeg sjekker den igjen når den har blitt oppdatert pluss at ZoneAlarm er recommend for mange fordi den tar veldig mye. Alltid hatt det og blokkert alt jeg har prøvd å laste ned av virus også videre.
Kanskje det er noe med testene?
