Vil bli astronaut eller astronom
bkf_94
Noen som vet hvor i Norge man kan studere astronomi? Hvor lang tid tar studiene? Går det ann å få jobb i Norge etterpå som forsker?
For å bli astronaut må man inn i luft forsvaret og så søke seg inn som astronaut hos f.eks NASA?
EDIT: og nøyaktig, hva gjør en astronom? eg vet han forsker på og studerer universet men kan noen utdype det litt? :)
Endret av bkf_94
Det spørs litt hva du har tenkt å gjøre ombord. Skal du være pilot så kreves det selvsagt masse erfaring med jetfly. Skal du "bare" være mission specialist så faller dette kravet bort. Du må uansett ha bachelor innen ditt fagfelt og en del andre ting. Skal sakse litt fra wikipedia.
NASA candidacy requirements
* Be citizens of the United States.[50][47]
* Pass a strict physical examination, and have a near and distant visual acuity correctable to 20/20 (6/6). Blood pressure, while sitting, must be no greater than 140 over 90.
[edit] Commander and Pilot
* A bachelor's degree in engineering, biological science, physical science or mathematics is required, and a graduate degree is desired, although not essential.
* At least 1,000 hours flying time as pilot-in-command in jet aircraft. Experience as a test pilot is desirable.
* Height must be 5 ft 4 in to 6 ft 4 in (1.63 to 1.93 m).
* Distant visual acuity must be correctable to 20/20 in each eye
* The refractive surgical procedures of the eye, PRK and LASIK, are now allowed, providing at least 1 year has passed since the date of the procedure with no permanent adverse after effects. For those applicants under final consideration, an operative report on the surgical procedure will be requested.
[edit] Mission Specialist
* Bachelor's degree in engineering, biological science, physical science or mathematics, as well as at least three years of related professional experience.
* Applicant's height must be 5 ft 2 in to 6 ft 4 in (1.57 to 1.93 m).
http://en.wikipedia.org/wiki/Astronaut
SÅ hvis du for eksempel utdanner deg i forsvaret som jagerpilot, flyr i 12 år så har du vell opp mot 1500 timer og så tar du ingeniør utdanning, og blir amerikansk statsborger så er det god sjangs for å bli astronut?
Gjest Slettet-p4PIYwb6
Nei, da har du kanskje 0.0002% sjangse i stedet for 0.0001%.
Bare se på de som skal opp å reparere Hubble på STS-119: http://www.nasa.gov/mission_pages/hubble/s...w_Profiles.html
Kun kommandøren og piloten har flyerfaring. At du har noen timer for forsvaret her i Norge bryr de seg lite om.
Det er gjerne folk som har utmerket seg spesielt, og gode testpiloter.
Som mission specialist har du større sjangs. Kanskje du blir det første nordmannen i rommet? Christer Fuglesang fra Sverige er vel den nærmeste. Han skal opp en tur igjen i sommer.
På NASA sine sider finner du mye info om utdannelsen til astronouter. I tillegg kan du lese litt her: http://www.esa.int/SPECIALS/Astronaut_Selection/index.html
Endret av Slettet-p4PIYwb6
Mange doktorgrader der ja. :p Men for all del, ikke gi opp av den grunn. Har du lyst til å bli astronaut, så er det bare å prøve. Hadde alle tenkt at de ikke kom til å klare det, ville ingen blitt astronauter. Selv om sjansen er liten, så er den der. :)
Endret av Mr. Bojangles
Er fullt mulig å bli astronaut, så lenge du jobber veldig hardt. Hvis du har en skikkelig stå på vilje kan du klare alt, selv en tur til rommet. Men er ikke lett, men fortsatt mulig.
NASA rekrutterer det beste av det beste, er vel bare å bli en av de beste, ser ikke hvorfor du ikke kan være en av de beste. Få deg Green Card og bra CV og du er good to go.
Tenker at astronom ville være bedre fordi vi har for mye astronomiske data nå og trenger folk som kan analysere det. Nå kjenner vi mer enn 300 planeter utenfor solsystemet, og mer og mer hver dag.
Det er interessant at nå man kan gå til rommet med bare penger, så trenger man bare en masse penger til å gå. Så tenker jeg at bli en astronom med penger er best.
