Rekkefølge på vannkjøling
Next attach the output of the Waterblock to the tubing that will input on the reservoir or pump. DO NOT CLAMP THIS DOWN YET! This way you ensure that the freshly chilled water from the radiator goes straight to the CPU. By attaching the hoses this way I found results several degrees Celsius lower than I did with the radiator before the reservoir. I also had better results with the radiator attached to an intake air source versus an exhaust port.
http://www.subzerotech.com/index.php?modul...y&id=22&page=12
