Noble Skrevet 20. mars 2009 Del Skrevet 20. mars 2009 Slik er det nå satt opp Internet ----- eth0 | Ubuntu server | eth1 ------- LAN Ubuntu server kjører SRCDS og Ventrilo som skal ut på nettet, resten av portene skal låses. #!/bin/bash # No spoofing if [ -e /proc/sys/net/ipv4/conf/all/rp_filter ] then for filtre in /proc/sys/net/ipv4/conf/*/rp_filter do echo 1 > $filtre done fi # No icmp echo 1 > /proc/sys/net/ipv4/icmp_echo_ignore_all echo 1 > /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts #load some modules you may need modprobe ip_tables modprobe ip_nat_ftp modprobe ip_nat_irc modprobe iptable_filter modprobe iptable_nat modprobe ip_conntrack_irc modprobe ip_conntrack_ftp # Log chain iptables -N LOG_DROP iptables -A LOG_DROP -j LOG --log-prefix '[iPTABLES DROP] : ' iptables -A LOG_DROP -j DROP # Remove all rules and chains iptables -F iptables -X # first set the default behaviour => accept connections iptables -P INPUT ACCEPT iptables -P OUTPUT ACCEPT iptables -P FORWARD ACCEPT # New chains iptables -N FIREWALL iptables -N TRUSTED #Allow ESTABLISHED and RELATED incoming connection iptables -A FIREWALL -i eth0 -m state --state ESTABLISHED,RELATED -j ACCEPT # Allow self communication iptables -A FIREWALL -i lo -j ACCEPT iptables -A FIREWALL -o lo -j ACCEPT # Send all package to the TRUSTED chain iptables -A FIREWALL -j TRUSTED # DROP all other packets iptables -A FIREWALL -j DROP # Send all through the FIREWALL chain iptables -A INPUT -j FIREWALL iptables -A FORWARD -j FIREWALL iptables -A OUTPUT -j FIREWALL # DROP all other packets iptables -A FIREWALL -j DROP # SET MASQUERADE iptables --table nat -A POSTROUTING -o eth1 -j MASQUERADE # OPEN PORTS # Bittorrent iptables -A TRUSTED -i eth0 -p tcp --sport 31839 -m state --state ESTABLISHED -j ACCEPT iptables -A TRUSTED -o eth0 -p tcp --dport 31839 -m state --state NEW,ESTABLISHED -j ACCEPT iptables -A TRUSTED -i eth0 -p udp --sport 31839 -m state --state ESTABLISHED -j ACCEPT iptables -A TRUSTED -o eth0 -p udp --dport 31839 -m state --state NEW,ESTABLISHED -j ACCEPT #SRCDS iptables -A TRUSTED -i eth0 -p tcp --sport 27015 -m state --state ESTABLISHED -j ACCEPT iptables -A TRUSTED -o eth0 -p tcp --dport 27015 -m state --state NEW,ESTABLISHED -j ACCEPT iptables -A TRUSTED -i eth0 -p udp --sport 27015 -m state --state ESTABLISHED -j ACCEPT iptables -A TRUSTED -o eth0 -p udp --dport 27015 -m state --state NEW,ESTABLISHED -j ACCEPT #Ventrilo iptables -A TRUSTED -i eth0 -p tcp --sport 3784 -m state --state ESTABLISHED -j ACCEPT iptables -A TRUSTED -o eth0 -p tcp --dport 3784 -m state --state NEW,ESTABLISHED -j ACCEPT iptables -A TRUSTED -i eth0 -p udp --sport 3784 -m state --state ESTABLISHED -j ACCEPT iptables -A TRUSTED -o eth0 -p udp --dport 3784 -m state --state NEW,ESTABLISHED -j ACCEPT Lenke til kommentar
Sokkalf™ Skrevet 21. mars 2009 Del Skrevet 21. mars 2009 Litt off-topic kanskje, jeg har ikke så mye peiling på iptables.. ..hvorfor ikke bruke f.eks shorewall til å håndtere oppsettet for deg? Personlig syns jeg det blir mye enklere å holde styr på, spesielt hvis du har en del regler. Lenke til kommentar
Wisd0m Skrevet 21. mars 2009 Del Skrevet 21. mars 2009 Bruk ufw istedet. http://www.ubuntugeek.com/ufw-uncomplicate...untu-hardy.html Egentlig bare en forenkling av iptables. Lenke til kommentar
