BSD/UnixStøtter FreeBSD/FreeNAS dualcore?
http://www.freenaskb.info/kb/?View=entry&EntryID=165
Processor
Replacement:
Processors can be replaced or upgraded without any data lost. L1 and L2 cache size of the processor can make a difference.
Performance:
  • P2 it’s OK for a small network server without SoftwareRAID.
  • P3 it’s a good choice, for the server reliability and SoftwareRAID.
  • P4 is the best choice for the moment.
<li>Multi-Processors: I successfully run FreeNAS 0.685b2 on Pentium DualCore, waiting for news from AMD.
Står ingenting om når dette var skrevet, men jeg antar at det er lenge siden :p Flerkjerne er ikke noe problem i GNU/Linux, så jeg regner med at *bsd er det samme.
Et betimelig spørsmål er "hva skal du med det?"
