Breaking Bad - Alle sesonger (USA-sendetid)
FOR en episode. Ti ganger mer spennende enn valget.
Litt snacks fra reddit:
UVOtBEO.jpg?1
BAbRK9g.gif?1
I gifen ser man hvor kort tid de bruker på å komme seg i skjul. Mye kjappere enn klippingen tilsa. Rart at de bommet med riflene da. Pistol er forståelig (da det er vanskelig å sikte på avstand med pistol).
edit: LOL
edit 2:
"The total on screen time of the firefight was 42 seconds. A really long time to be getting shot at...
HOWEVER - How many explosions in movies do you see only once? Almost never. The same event is usually repeated from multiple perspectives.
There were many viewpoints in the firefight - Walt, Hank/Gomie, Nazis, overhead, plus a lot of close ups of various things.
Not only that, several seconds were slow motion shots.
So really, it's probably fair to divide the 42 seconds by 5 to 10. In other words the "real" time is probably less than 5 seconds. (Still a long time, but considerably more believable.)
Another thing I noticed upon closer inspection is that Hank/Gomie are not nearly as out in the open as they appear when the gunfire starts. They were both inching for cover behind the engine block and made it most of the way.Here is a shot 15 seconds before the shooting starts [1] , and they are still moving toward the SUV.
EDIT: As a better example that is really easy to remember/determine - Walt dives for cover as fast as possible and is still struggling to get to the floor at the end. I doubt that took him 40 seconds."
Endret av uTukt
  • Liker 7
Når jeg ser det igjen og prøver å følge med på ting er det ganske åpenbart at det sees fra flere forskjellige vinkler og går veldig fort, selv om scenen varer lenge. Blant annet skyter Hank ca. dobbelt så mange skudd som magasinet hans holder, og ved to anledninger ser man han skyte mange skudd på en gang, så han skyter med høy frekvens. Tenker 10-15 sekunder er et realistisk tidsvindu fra første kule avfyres til episoden slutter, om ikke mindre.
Når det gjelder treffsikkerhet er jeg derimot mer perpleks. Du ser jo at han bartefransen sikter skikkelig også. Jeg lurer på om Gomie blir truffet av et av de første skuddene. Han lener seg mot bilen og skjærer en grimase, og når jeg så det tenkte jeg at han var blitt truffet. Man ser riktignok ikke noe blod eller tegn til skade annet enn grimasen, men hele scenen er så hektisk og uoversiktlig (av gode grunner) at det fort kan ha skjedd noe uten at man nødvendigvis får se det før det er over. Det legger jo bare et ekstra lag på cliffhangeren også. Han avfyrer ingen skudd i siste halvdel av scenen. Jeg tror han ble truffet og rakk å tømme geværet sitt før han døde/svimte av.
Helt fantastisk serie. Kan nesten ikke komme på en annen serie som begynte så bra, og som likevel har hatt en konstant stigende kvalitetskurve helt frem til slutten. Breaking Bad trenger ikke å vike for noen etter min mening, selv ikke Sopranos og the Wire.
Alt tyder på at Hank dør.
Men jeg håper ikke han gjør det. En av mine favorittkarakterer. Samspillet mellom ham og Walt/Cranston har vært helt fantastisk denne sesongen, du bare merker hatet til Hank boble i ham hver gang han ser Walt.
Tror forresten ikke at nazicrewet er der for de har så voldsomt lyst å oppfylle kontrakten sin, dvs. å drepe Jessie. Tror heller at de forstod på Walt at han var i fare, kanskje de til og med la sammen to og to og forstod at det handlet om at Walt ikke ville drepe Hank, og at de fant ut at de ville redde Walt, for å få ham til å cooke noe meth for de, med eller mot Walts egen vilje. De trenger ham levende og utav fengsel rett og slett.
Det ser jo forsåvidt ut som om de skyter mot Walt i bilen også, men det tror jeg ikke er planlagt fra deres side.
En ting som forundrer meg litt. Hvorfor tok ikke Hank og Gomez frem politiskiltene sine, for å vise at de er politi? Tror dere dette bare var et et forsøk fra nazistene for å overrumple Hank og Gomez, slik at de senket våpnene sine?
Endret av Jakoozie
Men jeg håper ikke han gjør det. En av mine favorittkarakterer. Samspillet mellom ham og Walt/Cranston har vært helt fantastisk denne sesongen, du bare merker hatet til Hank sige ut av ham hver gang han ser Walt.
Eg var bombrsikker på at ei kule ville snike seg gjennom skallen til Hank når han snakket i telefonen. Men eg tenker meg at Jesse eller Walt faktisk blir skutt (men overlever).
Det var nok bare prat, ja. Antar at Jack skjønte at dette var politi, da (hvis) de så at Walt satt inne i bilen.
Han ene nazisten hadde jo også AA-12. Skal jo være umulig og bomme med den på så kloss hold. :p De drepte jo de andre meth fyrene ganske kjapt for noen par episoder siden, så de kan jo ikke være så dårlig til å skyte. Men, det var vell for spenningen sin skyld at ingen døde på denne episoden.
Var inne på den tankegangen. Må også tenke på at AA12 faktisk er ein automatisk hagle og har med andre ord ein ganske grei spredning også. Så om hagla skytr først klarer du ikkje unngå skuddene med mindre han med hagla er ein total idiot som sikter på ei tekanne 5 meter ein annen vei.
en kompis av meg så episoden mye tidligere enn meg , hans forklaring på hvor bra denne episoden var :"du kommer til å sperme gjennom nasen din" det satte standarden høyt, og jeg synes det var en vanvittig episode ^^
Er usikker på om Hank dør men vet at gomez dør som en flue neste episode, ser ikke for me ett annet utfall.
Når skal de ta å finne fram gasmaska fra skolen til walt? det er jo det definitive bevise som jeg var sikker på skulle felle ham. Er jo passende at utstyret han brukte for første gang skal felle ham. blir spennende å se hvordan de klarer å fullføre dette!
Ser ikkje korleis gasmaska skal kunne felle han med tanke på at han tilstår i den eine videoen at kokte, men også gir Hank skylda...
Savner uansett dei meksikanske tvillingane med øksa, dei var rå..
Men mest av allt savner eg Walt med eksplosiv meth.
ah good point, tenkte faktisk ikke på det, men de har jo telefonsamtalen, og om de ikke finner de penge så kan jo det være det neste beviset
uansett ja enig med at jeg savner walt sine macgyver kjemi stil og de tvillingene var awesome det er jeg enig i hehe ^^
Slugs? ;)
Jeg tror ikke de har opptaket av telefonsamtalen andre steder enn i bilen, og jeg tviler på at noen andre i DEA får tak i den. Om ikke Jack truer med å levere den inn om ikke Walt koker for dem.
Rent teknisk, hvordan klarte Hank og Gomez alene å få nøyaktig posisjon på Walt fra følgebilen, som følge av at telefonsamtalen ble holdt gående?
Mener å huske at Hank sa noe om "tracker on your car", denne velkjente dingsen du legger på innsiden av chassiset.
Ellers kunne di jo bare forfulgt han fra avstand... Ikke akkurat vanskelig å se en desperat fyr som gjør bånn gass.
