Slettet noen program. Problem med nettbank/surfometer pga Java
Jeg skulle ta en liten vårsjau på lap top`n her om dagen, så jeg slettet en del program jeg ikke brukte, samt tok å defragmenterte hard disken.
Etter dette så får jeg ikke brukt innloggingen på nettbanken, eller brukt surfometeret på dinside.no (java versjon)
Dette er feilmeldingen jeg får;
load: class dinside.surf.Surfometer.class not found.
java.lang.ClassNotFoundException: dinside.surf.Surfometer.class
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.SocketException: Invalid argument: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception: java.lang.ClassNotFoundException: dinside.surf.Surfometer.class
Hva må jeg gjøre for å fikse opp i dette igjen?
Bruker XP og IE
Det er Sun-java du har prøvd med? Leser av posten din at den lista referer til mange sun-adresser.
Surfometeret hadde ingen add-ons du måtte installere i tillegg? Det virker som om den mangler en liste med adresse-oppføringer som du tydligvis har slettet.
