GjQre dvd spilleren min om til sonefri !
Hei. Har en del filmer region 1. Og skal gjQre den sone fri :
Use the following codes:
For the device: 0533
Program buttons 1-5 with the following codes (see your manual for the correct "magic key" procedure):
1: 00189
2: 00255
3: 00095
4: 00221
5: 00079
Then turn the DVD player off (standby) and enter the following on your remote:
1, 2, 3, 4, 5
The player will show "SUCCESS"
Then again:
1, 2, 3, 4, 5
And HEY HOOOO! It works.
I tried the 1,1,2,2,3,3,4,4,5,5 way first - and it didn't work. My way does though! Yepeehhh!
Men jeg skjQnner ikke det. Skal jeg skru paa dvd spilleren og trykke 0533 fQrst ? osv der
