Første kode; Hvordan få tekst i vinduet?
Hei.
Etter å lett litt frem og tilbake i Dev-C++ , kom jeg fram til at man kunne lage ferdigprojekter, men hvordan får man tekst inni "bildet"? koden er:
#include <windows.h>
/*  Declare Windows procedure  */
LRESULT CALLBACK WindowProcedure (HWND, UINT, WPARAM, LPARAM);
/*  Make the class name into a global variable  */
char szClassName[ ] = "WindowsApp";
int WINAPI WinMain (HINSTANCE hThisInstance,
				HINSTANCE hPrevInstance,
				LPSTR lpszArgument,
				int nFunsterStil)
HWND hwnd;			   /* This is the handle for our window */
MSG messages;			/* Here messages to the application are saved */
WNDCLASSEX wincl;		/* Data structure for the windowclass */
/* The Window structure */
wincl.hInstance = hThisInstance;
wincl.lpszClassName = szClassName;
wincl.lpfnWndProc = WindowProcedure;	  /* This function is called by windows */
wincl.style = CS_DBLCLKS;				 /* Catch double-clicks */
wincl.cbSize = sizeof (WNDCLASSEX);
/* Use default icon and mouse-pointer */
wincl.hIcon = LoadIcon (NULL, IDI_APPLICATION);
wincl.hIconSm = LoadIcon (NULL, IDI_APPLICATION);
wincl.hCursor = LoadCursor (NULL, IDC_ARROW);
wincl.lpszMenuName = NULL;				 /* No menu */
wincl.cbClsExtra = 0;					  /* No extra bytes after the window class */
wincl.cbWndExtra = 0;					  /* structure or the window instance */
/* Use Windows's default color as the background of the window */
wincl.hbrBackground = (HBRUSH) COLOR_BACKGROUND;
/* Register the window class, and if it fails quit the program */
if (!RegisterClassEx (&wincl))
	return 0;
/* The class is registered, let's create the program*/
hwnd = CreateWindowEx (
	   0,				   /* Extended possibilites for variation */
	   szClassName,		 /* Classname */
	   "Eg e stolt",	   /* Title Text */
	   WS_OVERLAPPEDWINDOW, /* default window */
	   CW_USEDEFAULT,	   /* Windows decides the position */
	   CW_USEDEFAULT,	   /* where the window ends up on the screen */
	   544,				 /* The programs width */
	   375,				 /* and height in pixels */
	   HWND_DESKTOP,		/* The window is a child-window to desktop */
	   NULL,				/* No menu */
	   hThisInstance,	   /* Program Instance handler */
	   NULL				 /* No Window Creation data */
/* Make the window visible on the screen */
ShowWindow (hwnd, nFunsterStil);
/* Run the message loop. It will run until GetMessage() returns 0 */
while (GetMessage (&messages, NULL, 0, 0))
	/* Translate virtual-key messages into character messages */
	TranslateMessage(&messages);
	/* Send message to WindowProcedure */
	DispatchMessage(&messages);
/* The program return-value is 0 - The value that PostQuitMessage() gave */
return messages.wParam;
/*  This function is called by the Windows function DispatchMessage()  */
LRESULT CALLBACK WindowProcedure (HWND hwnd, UINT message, WPARAM wParam, LPARAM lParam)
switch (message)				  /* handle the messages */
	case WM_DESTROY:
		PostQuitMessage (0);	   /* send a WM_QUIT to the message queue */
		break;
	default:					  /* for messages that we don't deal with */
		return DefWindowProc (hwnd, message, wParam, lParam);
return 0;
Takk for all hjelp!
Hvis dette er ditt første program så lærer du veldig fort eller så tar du vann over hode.
For å lage en label må du bruke CreateWindowEx med "Static" som classname.
Jeg ville lagt vekk windows APIet til du kan mer (hvis dette er ditt første program da)
