Hvordan finne ut hvilke nettleverandør jobben har?
Skal sette opp en Microsoft Outlook 2007 mail, og finner ikke hvilke smtp adresse jeg skal bruke.
Her er noen som jeg har testet ut, uten hell:
Telenor smtp.online.no
Bluecom smtp.bluecom.no
Mimer smtp.adsl.no
Nextgentel mail.broadpark.no
Tiscali smtp.tiscali.no
Tele 2 mail.c2i.net
Telenor avid (Canal digital) smtp.online.no
Smartcall smtp.smartcall.no
Kvalito / Mtu link smtp.mtulink.no
Intellinet ASA mail2.axpa.no
Catch smtp.catch.no
DataGuard AS smtp.dataguard.no
Chello smtp.chello.no
Loqal smtp.loqal.no
Frisurf smtp.frisurf.no
Ventelo NB! Må meldes inn til Ventelo mail.ventelo.net
Fjellnett smtp.fjellnett.no
Nte bredbånd smtp.nteb.no
Infonett Røros mailrelay.banetele.com
Og når jeg går ipconfig /all veien får jeg dette:
Microsoft Windows [Version 6.0.6001]
Copyright © 2006 Microsoft Corporation. All rights reserved.
C:\Users\Laptop>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : xxxxxxxxxx
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel® Wireless WiFi Link
Physical Address. . . . . . . . . : xx-xx-xx-xx-xx
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::4898:xxxx:a1c5:3df9%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.5(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 9. mars 2009 19:13:39
Lease Expires . . . . . . . . . . : 10. mars 2009 19:13:37
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : xxxxxxxxx
DHCPv6 Client DUID. . . . . . . . : xx-xx-xx-xx-xx-xx-xx-xx-xx-xx-xx-xx-xx-xx
DNS Servers . . . . . . . . . . . : 192.168.1.254
144.xxx.8.xxx
NetBIOS over Tcpip. . . . . . . . : Enabled
Er det noe jeg kan finne ut av dette?
Endret av Ray001
Det er vanlig at bedrifter ikke bruker ISP sin mail løsning men enten har sin egen mail server, eller leier på et webhotell.
ofte er det ganske lett å gjette seg til smtp server, da det er vanlig å bruke smtp.(domene). eller mail.(domene)
f.eks om epostadressen din er [email protected], kan smtp adressen være f.eks smtp.dinarbeidsplass.no eller maili.dinarbeidsplass.no
Endret av SirAmp
