Feilmelding fra Dreameweaver
Plages med at Flash låser seg, dette skjer når jeg er på tidslinja og skal gjøre endringer.
jeg jobber på mac, og har Flash cs3.
Får et dokument opp med denne meldingen, er det noen som skjønner noe av det?
//v1.7
// Flash Player Version Detection
// Detect Client Browser type
// Copyright 2005-2007 Adobe Systems Incorporated. All rights reserved.
var isIE = (navigator.appVersion.indexOf("MSIE") != -1) ? true : false;
var isWin = (navigator.appVersion.toLowerCase().indexOf("win") != -1) ? true : false;
var isOpera = (navigator.userAgent.indexOf("Opera") != -1) ? true : false;
function ControlVersion()
var version;
var axo;
var e;
// NOTE : new ActiveXObject(strFoo) throws an exception if strFoo isn't in the registry
try {
// version will be set for 7.X or greater players
axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.7");
version = axo.GetVariable("$version");
} catch (e) {
if (!version)
try {
// version will be set for 6.X players only
axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.6");
// installed player is some revision of 6.0
// GetVariable("$version") crashes for versions 6.0.22 through 6.0.29,
// so we have to be careful.
// default to the first public version
version = "WIN 6,0,21,0";
// throws if AllowScripAccess does not exist (introduced in 6.0r47)
axo.AllowScriptAccess = "always";
// safe to call for 6.0r47 or greater
} catch (e) {
if (!version)
try {
// version will be set for 4.X or 5.X player
axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.3");
} catch (e) {
if (!version)
try {
// version will be set for 3.X player
version = "WIN 3,0,18,0";
} catch (e) {
if (!version)
try {
// version will be set for 2.X player
axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash");
version = "WIN 2,0,0,11";
} catch (e) {
version = -1;
return version;
// JavaScript helper required to detect Flash Player PlugIn version information
function GetSwfVer(){
// NS/Opera version >= 3 check for Flash plugin in plugin array
var flashVer = -1;
if (navigator.plugins != null && navigator.plugins.length > 0) {
if (navigator.plugins["Shockwave Flash 2.0"] || navigator.plugins["Shockwave Flash"]) {
var swVer2 = navigator.plugins["Shockwave Flash 2.0"] ? " 2.0" : "";
var flashDescription = navigator.plugins["Shockwave Flash" + swVer2].description;
var descArray = flashDescription.split(" ");
var tempArrayMajor = descArray[2].split(".");
var versionMajor = tempArrayMajor[0];
var versionMinor = tempArrayMajor[1];
var versionRevision = descArray[3];
if (versionRevision == "") {
versionRevision = descArray[4];
if (versionRevision[0] == "d") {
versionRevision = versionRevision.substring(1);
} else if (versionRevision[0] == "r") {
if (versionRevision.indexOf("d") > 0) {
versionRevision = versionRevision.substring(0, versionRevision.indexOf("d"));
var flashVer = versionMajor + "." + versionMinor + "." + versionRevision;
// MSN/WebTV 2.6 supports Flash 4
else if (navigator.userAgent.toLowerCase().indexOf("webtv/2.6") != -1) flashVer = 4;
// WebTV 2.5 supports Flash 3
else if (navigator.userAgent.toLowerCase().indexOf("webtv/2.5") != -1) flashVer = 3;
// older WebTV supports Flash 2
else if (navigator.userAgent.toLowerCase().indexOf("webtv") != -1) flashVer = 2;
else if ( isIE && isWin && !isOpera ) {
flashVer = ControlVersion();
return flashVer;
// When called with reqMajorVer, reqMinorVer, reqRevision returns true if that version or greater is available
function DetectFlashVer(reqMajorVer, reqMinorVer, reqRevision)
versionStr = GetSwfVer();
if (versionStr == -1 ) {
return false;
} else if (versionStr != 0) {
if(isIE && isWin && !isOpera) {
// Given "WIN 2,0,0,11"
tempArray = versionStr.split(" "); // ["WIN", "2,0,0,11"]
tempString = tempArray[1]; // "2,0,0,11"
versionArray = tempString.split(","); // ['2', '0', '0', '11']
} else {
versionArray = versionStr.split(".");
var versionMajor = versionArray[0];
var versionMinor = versionArray[1];
var versionRevision = versionArray[2];
// is the major.revision >= requested major.revision AND the minor version >= requested minor
if (versionMajor > parseFloat(reqMajorVer)) {
return true;
} else if (versionMajor == parseFloat(reqMajorVer)) {
if (versionMinor > parseFloat(reqMinorVer))
return true;
else if (versionMinor == parseFloat(reqMinorVer)) {
if (versionRevision >= parseFloat(reqRevision))
return true;
return false;
function AC_AddExtension(src, ext)
if (src.indexOf('?') != -1)
return src.replace(/\?/, ext+'?');
else
return src + ext;
function AC_Generateobj(objAttrs, params, embedAttrs)
var str = '';
if (isIE && isWin && !isOpera)
str += '<object ';
for (var i in objAttrs)
str += i + '="' + objAttrs + '" ';
str += '>';
for (var i in params)
str += '<param name="' + i + '" value="' + params + '" /> ';
str += '</object>';
else
str += '<embed ';
for (var i in embedAttrs)
str += i + '="' + embedAttrs + '" ';
str += '> </embed>';
document.write(str);
function AC_FL_RunContent(){
var ret =
AC_GetArgs
( arguments, ".swf", "movie", "clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"
, "application/x-shockwave-flash"
AC_Generateobj(ret.objAttrs, ret.params, ret.embedAttrs);
function AC_SW_RunContent(){
var ret =
AC_GetArgs
( arguments, ".dcr", "src", "clsid:166B1BCA-3F9C-11CF-8075-444553540000"
, null
function AC_GetArgs(args, ext, srcParamName, classid, mimeType){
var ret = new Object();
ret.embedAttrs = new Object();
ret.params = new Object();
ret.objAttrs = new Object();
for (var i=0; i < args.length; i=i+2){
var currArg = args.toLowerCase();
switch (currArg){
case "classid":
break;
case "pluginspage":
ret.embedAttrs[args] = args[i+1];
break;
case "src":
case "movie":
args[i+1] = AC_AddExtension(args[i+1], ext);
ret.embedAttrs["src"] = args[i+1];
ret.params[srcParamName] = args[i+1];
break;
case "onafterupdate":
case "onbeforeupdate":
case "onblur":
case "oncellchange":
case "onclick":
case "ondblclick":
case "ondrag":
case "ondragend":
case "ondragenter":
case "ondragleave":
case "ondragover":
case "ondrop":
case "onfinish":
case "onfocus":
case "onhelp":
case "onmousedown":
case "onmouseup":
case "onmouseover":
case "onmousemove":
case "onmouseout":
case "onkeypress":
case "onkeydown":
case "onkeyup":
case "onload":
case "onlosecapture":
case "onpropertychange":
case "onreadystatechange":
case "onrowsdelete":
case "onrowenter":
case "onrowexit":
case "onrowsinserted":
case "onstart":
case "onscroll":
case "onbeforeeditfocus":
case "onactivate":
case "onbeforedeactivate":
case "ondeactivate":
case "type":
case "codebase":
case "id":
ret.objAttrs[args] = args[i+1];
break;
case "width":
case "height":
case "align":
case "vspace":
case "hspace":
case "class":
case "title":
case "accesskey":
case "name":
case "tabindex":
ret.embedAttrs[args] = ret.objAttrs[args] = args[i+1];
break;
default:
ret.embedAttrs[args] = ret.params[args] = args[i+1];
ret.objAttrs["classid"] = classid;
if (mimeType) ret.embedAttrs["type"] = mimeType;
return ret;
  • 7 måneder senere...
