8086 Skrevet 6. mars 2009 Del Skrevet 6. mars 2009 Hei, jeg har en 320GB Samsung harddisk som jeg fikk en lesefeil på for en stund siden. Den greide ikke å lese en fil i fontmappa i Windows, hverken gjennom å boote linux eller Windows. Derfor tenkte jeg den begynte å gå ned for telling. Men etter å ha kjørt chkdisk (Windows) kan jeg lese fila, og alt virker ok. For å bestemme om det var noe galt har jeg kjørt smartctl, men det sier meg ærlig talt ganske lite. Dette er output av smartctl -a /dev/sda etter å ha kjørt smartctl -t long /dev/sda 07:58_acer6292:gsmartcontrol-0.8.3$ sudo smartctl -a /dev/sda smartctl version 5.38 [x86_64-unknown-linux-gnu] Copyright © 2002-8 Bruce Allen Home page is http://smartmontools.sourceforge.net/ === START OF INFORMATION SECTION === Device Model: SAMSUNG HM320JI Serial Number: S16LJD0Q744540 Firmware Version: 2SS00_01 User Capacity: 320 072 933 376 bytes Device is: In smartctl database [for details use: -P show] ATA Version is: 7 ATA Standard is: ATA/ATAPI-7 T13 1532D revision 0 Local Time is: Fri Mar 6 07:59:26 2009 CET ==> WARNING: May need -F samsung or -F samsung2 enabled; see manual for details. SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 112) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: ( 118) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 118) minutes. SCT capabilities: (0x003f) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 100 100 051 Pre-fail Always - 278 3 Spin_Up_Time 0x0007 252 252 025 Pre-fail Always - 2750 4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1235 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 1 7 Seek_Error_Rate 0x000f 252 252 051 Pre-fail Always - 0 8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0 9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 941 10 Spin_Retry_Count 0x0032 100 100 051 Old_age Always - 1 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 630 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 683 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 25 194 Temperature_Celsius 0x0022 082 043 000 Old_age Always - 52 (Lifetime Min/Max 1/65) 195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 290 196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 1 198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0036 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x000a 100 100 000 Old_age Always - 5 201 Soft_Read_Error_Rate 0x0032 252 252 000 Old_age Always - 0 223 Load_Retry_Count 0x0032 099 099 000 Old_age Always - 1152 225 Load_Cycle_Count 0x0032 098 098 000 Old_age Always - 28811 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 00% 934 17771238 # 2 Extended offline Completed: read failure 00% 933 17771238 SMART Selective Self-Test Log Data Structure Revision Number (0) should be 1 SMART Selective self-test log data structure revision number 0 Warning: ATA Specification requires selective self-test log data structure revision number = 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Completed_read_failure [00% left] (0-65535) 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. Det står jo "SMART overall-health self-assessment test result: PASSED", men lenger nede står det # 1 Extended offline Completed: read failure 00% 934 17771238 # 2 Extended offline Completed: read failure 00% 933 17771238 har jeg "read failure"s, og i så fall; hvorfor får jeg PASSED? Prøvde å lese en altfor lang artikkel om smartctl uten at det gjorde meg stort klokere ... Noen med litt mer innsikt kan kanskje si meg om disken er ok, eller om jeg bør sende den inn til bytte? Vil ikke sende inn disken bare for å få den i retur med at "alt var ok, bare filsystemfeil", og en regning på 500kr! Lenke til kommentar
8086 Skrevet 9. mars 2009 Forfatter Del Skrevet 9. mars 2009 Fant etter hvert GSmartControl som tolker og gir tips i henhold til hva smartctl sier. Den viste meg i rødt et par problemområder, men mente at det gikk bra inntil videre. Og siden alt fungerer igjen ... velger å bare kjøre hyppig backup inntil videre Lenke til kommentar
NgZ Skrevet 11. mars 2009 Del Skrevet 11. mars 2009 Bruker samme programmet. Testet de to gjenværende diskene i den stasjonære, etter at den tredje hadde tatt kvelden. Har "pre-failure" på en del punkter på begge diskene. Noen som vet om man kan legge ved disse dataene og reklamere på disken? Alternativet er jo å vente til diskene ryker, men for det første så er det upraktisk, og for det andre er jeg skeptisk til å sende fra meg en disk som ikke har vært renset. Jeg regner med at de fleste/alle butikker ikke sender meg en ødelagt disk tilbake, slik at jeg kan åpne den, avmagnetisere platene og bruke de som ølbrikker? Lenke til kommentar
8086 Skrevet 18. mars 2009 Forfatter Del Skrevet 18. mars 2009 Noen som vet om man kan legge ved disse dataene og reklamere på disken? Amentio kontakter sin distributør som igjen ber deg sende inn diskene for testing. At du sier det er noe galt med (mulig fabrikkerte) data er ikke nok. Ulempen er jo at det ikke er sikkert at de finner noe galt (selv om det er noe galt), og da sitter jo du igjen med regninga på 500kr + porto... Lenke til kommentar
NgZ Skrevet 19. mars 2009 Del Skrevet 19. mars 2009 Amentio kontakter sin distributør som igjen ber deg sende inn diskene for testing. At du sier det er noe galt med (mulig fabrikkerte) data er ikke nok. Ulempen er jo at det ikke er sikkert at de finner noe galt (selv om det er noe galt), og da sitter jo du igjen med regninga på 500kr + porto...Jeg tester den i en annen maskin+eksternt harddiskkabinett før jeg sender den inn, så da er jeg sikker på at den er ødelagt. (Den som allerede har tatt kvelden.) Men får jeg den tilbake etterpå, Aå jeg fysisk kan ødelegge den og data som er på den? Det jeg lurer mer på, er om de godtar disker som snart dør, fordi de har høye feilverdier, eller om jeg får høre "Den virker jo enda da, du får fortsette å bruke den til den tar kvelden." Og evt. hvor høye/hvilke feilverdier det er snakk om. Men det er det val kanskje bare de selv som vet, så jeg får vurdere å fyre av en mail. Lenke til kommentar
