Twinview fullskjerm problema i Fedora 10
Når eg køyre program i fullskjerm so blir det automatisk sendt til ein av skjermen uansett kva for ein skjerm eg er på når eg velger fullskjerm, det varier i frå program til program. VLC blir alltid fullskjerm på den høgre skjermen, medan flash og Totem blir alltid fullskjerm på venstre skjerm. Nokon som har vært bort i noko liknadne før?
skjermkortet mitt er eit Nvidia 8800GT
Xorg.conf fila mi:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 1.0  (buildmeister@builder63)  Thu Feb  5 00:19:09 PST 2009
# Xorg configuration created by livna-config-display
Section "ServerLayout"
Identifier	 "Default Layout"
Screen	  0  "Screen0" 0 0
InputDevice	"Keyboard0" "CoreKeyboard"
InputDevice	"Mouse0" "CorePointer"
EndSection
Section "Files"
ModulePath	  "/usr/lib/xorg/modules/extensions/nvidia"
ModulePath	  "/usr/lib/xorg/modules"
EndSection
Section "ServerFlags"
# Removed Option "Xinerama" "0"
# Removed Option "Xinerama" "1"
Option		 "AIGLX" "on"
EndSection
Section "InputDevice"
# generated from data in "/etc/sysconfig/keyboard"
Identifier	 "Keyboard0"
Driver		 "kbd"
Option		 "XkbLayout" "no"
Option		 "XkbModel" "pc105"
EndSection
# generated from default
Identifier	 "Mouse0"
Driver		 "mouse"
Option		 "Protocol" "auto"
Option		 "Device" "/dev/input/mice"
Option		 "Emulate3Buttons" "no"
Option		 "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
Identifier	 "Monitor0"
VendorName	 "Unknown"
ModelName	  "SAMSUNG"
HorizSync	   30.0 - 61.0
VertRefresh	 60.0 - 75.0
EndSection
Section "Monitor"
Identifier	 "Monitor1"
ModelName	  "SAMSUNG"
EndSection
Section "Device"
Identifier	 "Videocard0"
Driver		 "nvidia"
Option		 "AddARGBGLXVisuals" "True"
EndSection
Section "Device"
Identifier	 "Device0"
Driver		 "nvidia"
VendorName	 "NVIDIA Corporation"
BoardName	  "GeForce 8800 GT"
EndSection
Section "Device"
Identifier	 "Device1"
Driver		 "nvidia"
BusID		  "PCI:1:0:0"
Screen		  1
EndSection
Section "Screen"
Identifier	 "Default Screen"
Device		 "Videocard0"
Monitor		"Monitor0"
EndSection
Section "Screen"
# Removed Option "TwinView" "0"
# Removed Option "metamodes" "DFP: nvidia-auto-select +0+0"
Identifier	 "Screen0"
Device		 "Device0"
Monitor		"Monitor0"
DefaultDepth	24
Option		 "TwinView" "1"
Option		 "TwinViewXineramaInfoOrder" "DFP-0"
Option		 "metamodes" "CRT: nvidia-auto-select +0+0, DFP: nvidia-auto-select +1360+0"
SubSection	 "Display"
	Depth	   24
EndSubSection
EndSection
Section "Screen"
Identifier	 "Screen1"
Device		 "Device1"
Monitor		"Monitor1"
DefaultDepth	24
Option		 "metamodes" "CRT: nvidia-auto-select +0+0"
	Depth	   24
EndSubSection
EndSection
Section "Extensions"
Option		 "Composite" "Enable"
EndSection
Dette kan være to ting.
Mange programmer sjekker etter en instillingen som angir "main display" for x serveren eller noe sånt. På nvidia-settings kan man angi hvilken skjerm som er main, ved hver monitor sin oppløsning osv.
Det andre punktet er at VLC (og enkelte andre mediaspillere) har en skjerm som standard. I VLC endres dette med advanced settings, video, modules og default display tror jeg. Mulige verdier er vel 0 eller 1 kanskje.
Output modules du meina? Er ingen ting som heite default display so vidt eg kan sjå der
