Hva gjør jeg med denne JAVA feilmeldingen?
Hei!
Jeg skulle logge meg inn i nettbanken her om dagen (har fungert knirkefritt både her og andre som krever JAVA før) og da får jeg plutselig denne feilmeldingen fra JAVA i det det starter:
(kopiert inn hele feilmld.)
Java Plug-in 1.6.0_12
Using JRE version 1.6.0_12 Java HotSpot Client VM
User home directory = C:\Users\Felles
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
load: class jreCheck.class not found.
java.lang.ClassNotFoundException: jreCheck.class
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.SocketException: Permission denied: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception: java.lang.ClassNotFoundException: jreCheck.class
Hva i alle dager?!
Jeg har prøvd å slette alt innen JAVA fra kontrollpanel og så lagt det inn på nytt fra www-java.com, men får samme feilmld..
Er det noen som vet hva som har skjedd?
Jeg får samme feilmld. og en hvit boks med rødt kryss og ERROR-tegn uansett hvordan jeg prøver, også når jeg prøver å sjekke om maskinen har JAVA fra JAVA sine nettsider.
Kan noen hjelpe meg?!
Hmmm, ser ut til at noe hindrer Java i å starte. Har du oppdatert annen programvare i det siste? Har du scannet maskinen etter ymse malware? Hvilken nettleser og OS bruker du?
Hei!
Når jeg tenker etter så har jeg innstallert et program til et digital kamera, Kodak Eye Share bildeprogram. Kan dette ha klusset JAVA til da?
PC'en er relativt ny, kjøpt i november og har Internet Explorer 7.
OS?? Mener du operativ system?! Er ikke helt inne på alle tekniske ord, men hvis det er operativ system du mener så har jeg en HP med Windows Vista (Home premium)!
Hvordan kan jeg scanne pc'en min etter "ymse malware"?
Prøv å avinstallere Kodak-programmet og reinstaller java.
For å sjekke maskinen for malware, altså virus, ormer, spionprogrammer etc, kan du benytte f. eks. Norton Internet Security eller andre Internet Security-pakker (de fleste koster penger), eller du kan bruke gratisprogrammer som AVG Antivirus og AdAware som tar seg av spionprogrammer etc. Attpåtil kan du kjøre Ccleaner som rydder opp i Windows-rotet som oppstår ved normal bruk av Windows over tid.
Dropp Internet Explorer. Last ned Firefox, Google Chrome eller norske Opera og bruk en av dem i stedet. Internet Explorer 7 er markedets dårligste nettleser, mens Firefox, Chrome og Opera er svært sterke aktører som leverer mye bedre produkter. Firefox 3 er den mest populære av disse. Alle tre er gratis, så du kan laste ned alle og prøve deg frem for å finne den som passer deg best. Selv er jeg svak for Opera og dets mange muligheter for å tilpasse nettleseren til dine behov og ønsker (høyreklikk - Tilpass; Alt kan modifiseres)..
Hei igjen!
Jeg avinnstallerte Kodak-programmet og la JAVA inn på nytt, men samme feilmld. kom....
Jeg har Norman Antivirus og den har jo live update og alt, men har nå tatt en ny omfattende virussjekk, og ingenting negativt funnet....
Aner ikke hva jeg skal gjøre!
Har du andre tips...?!
