Thomas. Skrevet 27. februar 2009 Del Skrevet 27. februar 2009 <?php error_reporting(E_ALL); class ActiveRelationalRecord { private $db_pk = null; /** * EKS: addRelation('brukere', 'nick', 'admin'); * ==== select * from brukere where nick = admin */ function addRelation($table,$fk='',$pk='', $felt) { $fk = strlen($fk)>0 ? $fk : $this->db_pk; $pk = strlen($fk)>0 ? $pk : $this->db_pk; $rs = mysql_query('select * from ' . $table . ' where ' . $fk . ' = '. $pk . ''); echo $rs; while($row = mysql_fetch_array($rs)) { echo $row[$felt]; } } } class MAL { private $host = 'x'; private $user = 'x'; private $password = 'x'; private $database = 'x'; function __construct($host='',$user='',$password='',$database='') { $this->host = $host; $this->user = $user; $this->password = $password; $this->database = $database; } function execute($sql) { mysql_connect($this->host,$this->user,$this->password); mysql_select_db($this->database); } } $dal = new MAL('localhost','root','','test'); $am = new ActiveRelationalRecord(); $am->addRelation('brukere','nick','admin', 'nick'); ?> Jeg får feilmeldingene: Warning: mysql_query() [function.mysql-query]: Access denied for user 'ODBC'@'localhost' (using password: NO) in C:\wamp\www\mafiasosVER2\data\sql\sql.php on line 22 Warning: mysql_query() [function.mysql-query]: A link to the server could not be established in C:\wamp\www\mafiasosVER2\data\sql\sql.php on line 22 Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\wamp\www\mafiasosVER2\data\sql\sql.php on line 24 Håper på hjelp Lenke til kommentar
AlecTBM Skrevet 27. februar 2009 Del Skrevet 27. februar 2009 (endret) Du har ikke tilkoblet databasen via MAL Mulig løsning: Bytt ut $rs = mysql_query('select * from ' . $table . ' where ' . $fk . ' = '. $pk . ''); med $rs = MAL::execute('select * from ' . $table . ' where ' . $fk . ' = '. $pk . ''); Hvilken php versjon kjører du? Beklager, litt trøtt du må også endre litt i execute function execute($sql) { mysql_connect($this->host,$this->user,$this->password); mysql_select_db($this->database); return mysql_query($sql); } Eller så legger du database tilkoblinga i __construct() istedet for å kjøre en til funksjon Endret 27. februar 2009 av AlecTBM Lenke til kommentar
