[sannsyneligvis løst]Sette op Xorg.conf eller noe.....
# xrandr
Can't open display
Mjau <.< Tror jeg begynner her. Spurte om dette på Ubuntu forumet først så...........
WDC WD3200BEVT-22ZCT0 ATA Device
ATI Mobility Radeon HD 3470 Hybrid X2
ATI Radeon HD 3200
GraphicsOptiarc DVD RW AD-7590S ATA Device
Standard Dual Channel PCI IDE Controller
Standard PS/2 Keyboard
Synaptics PS/2 Port TouchPad
Generic PnP Monitor
Ralink 802.11n Wireless LAN Card
Realtek RTL8168C(P)/8111C(P)
Family PCI-E Gigabit Ethernet NIC (NDIS 6.0)
AMD Turion X2 Dual-Core Mobile RM-70
Realtek High Definition Audio
ATI PCI Express (3GIO) Filter Driver
JMB38X MS Host Controller
JMB38X SD Host Controller
JMB38X SD/MMC Host Controller
JMB38X xD Host Controller
Problemet er at alt med nyere Xorg en hva Ubuntu 8.04 kom med gjør X ukjørbart. Det gjelder installasjon også.
Funker før i Debian Lenny og derfor tipper jeg det er Xorg som har skylda(updates updates updates).
Feilen som jeg får er: "Cannot detects displays".
Takker på forhånd for hjelp <.<
Endret av del_diablo
Tydeligvis et kjent problem. Ser ut til at det fungerte med 8.10 alpha også.
https://bugs.launchpad.net/ubuntu/+source/x...ati/+bug/254908
Flere løsninger:
I've found a solution but it decreases the usable amount of RAM. I added mem=2900M to booting line from grub. Then, it works. But, as I said it decreases the usable amount of RAM. It works fine with 8.04.1 and 8.10 alpha4.
Then I upgraded to Lenny from the Debian official repository and this broken X (or the drivers): I was not able to get into graphical mode. Using VESA I got messages saying that it was not possible to correctly start X.
Then I downloaded the Radeon drivers from Debian repository, and changed xorg.conf to use them. In this case the system was simply stopping while entering the graph mode (consoles was always available).
After an half a day of searching and trying to tweak xorg.conf, I tried the instructions here
http://wiki.ubuntu-it.org/Hardware/Video/Ati/RadeonHd
to compile the latest Radeon's drivers from sources, and now everything works fine, even at resolution of 1280x800, which is the max I can obtain. (actually I didn't check every feature yet, like HDMI, second monitor, etc., but at least I have graphics :-))
btw, looking at section 8, "Known Bugs & Limitations", from here
http://wiki.x.org/wiki/radeonhd
I also tried the tweak of booting the kernel with mem=1000M (they suggest < 2GB), but before compiling the latest driver this didn't solve the problem. I currently using mem=1000M with the new drivers and everything work fine (not yet tested without this flag).
Gjorde BTW bare et kjapt søk på Google på "intrepid ATI Mobility Radeon HD 3470"
Hvor mye RAM har du?
Endret av oj88
Hvordan tvinger jeg inn det for f.eks Live CD'r? Ta en rambrikke eller? Og jeg legger bare til linja i grub ved å gjøre hva? Editie fila til den i Nano?
Edit: Har dradd ut ram før, prøve det senere.
På LiveCDer kan du spesifisere RAM når GRUB starter ved oppstar
Once you have loaded the GRUB boot screen, type e for edit. You will be presented with a list of items in the configuration file for the boot label you have selected.
Choose the line that starts with kernel and type e to edit this boot entry.
At the end of the kernel line, add
mem=xxM
where xx equals the amount of RAM in your system.
Press [Enter] to exit edit mode.
Once the GRUB screen has returned, type b to boot with your new RAM specifications.
For å endre mem-innstillingen på en installert distro (her Ubuntu), kjører du
nano /boot/grub/menu.lst
Så finner du kernelen du booter, og legger til mem=2900M i kernel-linja. Ville blitt sånn hos meg:
kernel		/boot/vmlinuz-2.6.27-7-generic root=UUID=54aa98a3-3aed-453f-8521 mem=2900M
OBS, dette skal være på en linje
Så kjør:
grub-install /dev/dindisk
Erstatt dindisk med disken root-partisjonen din ligger på, i mitt tilfelle /dev/sda. Kjør "df" for å se hvilken disk.
Litt usikker på om det er nødvendig med grub-install.
Endret av oj88
