Netbeans sqlexception [LØST]
Hei
Prøver å få kjørte følgende kode i Netbeans
package oving5;
import java.sql.*;
import static javax.swing.JOptionPane.*;
// Øving 5 Oppgave a
public class BibliotekB {
public static void main(String[] args) throws Exception {
String databasedriver = "org.apache.derby.jdbc.ClientDriver"; // HM HM
Class.forName(databasedriver);
String databasenavn = "jdbc:derby://localhost:1527/vprg;user=vprg;password=vprg";
Connection forbindelse = DriverManager.getConnection(databasenavn);
//update eksemplar set laant_av = 'Per Olsen' where isbn = '0-07-241163-5' and eks_nr = 1 and laant_av is null
Statement setning = forbindelse.createStatement();
String isbn = showInputDialog("skriv inn isbn");
String laant_av = showInputDialog("navn");
String lest = showInputDialog("antall eksmplar");
int eks_nr = Integer.parseInt(lest);
String SQLset ="update eksemplar set laant_av = '"+laant_av + "'where isbn ='" + isbn + "' and eks_nr = "+ eks_nr + " and laant_av is null";
if(setning.executeUpdate(SQLset)==1){
showMessageDialog(null, "gikk bra");
}else showMessageDialog(null, "gikk dårlig");
setning.close();
forbindelse.close();
Men får følgende feilmelding
run:
Exception in thread "main" org.apache.derby.client.am.SqlException: Schema 'VPRG' does not exist
at org.apache.derby.client.am.Statement.completeSqlca(Unknown Source)
at org.apache.derby.client.am.Statement.completeExecuteImmediate(Unknown Source)
at org.apache.derby.client.net.NetStatementReply.parseEXCSQLIMMreply(Unknown Source)
at org.apache.derby.client.net.NetStatementReply.readExecuteImmediate(Unknown Source)
at org.apache.derby.client.net.StatementReply.readExecuteImmediate(Unknown Source)
at org.apache.derby.client.net.NetStatement.readExecuteImmediate_(Unknown Source)
at org.apache.derby.client.am.Statement.readExecuteImmediate(Unknown Source)
at org.apache.derby.client.am.Statement.flowExecute(Unknown Source)
at org.apache.derby.client.am.Statement.executeUpdateX(Unknown Source)
at org.apache.derby.client.am.Statement.executeUpdate(Unknown Source)
at oving5.BibliotekB.main(BibliotekB.java:33)
Java Result: 1
BUILD SUCCESSFUL (total time: 7 seconds)
Noen som vet hva jeg har gjort feil?
Endret av Wisd0m
Ser du har satt oppgaven som løst uten å skrive hva løsningen var.
Personlig vil jeg ikke ha satt oppgaven som løst.
Hvis noen skriver inn navnet "oisann';--" så vil alle lånt av kolonnene i tabellen eksemplarer være satt til "oisann". Ikke helt heldig. ;)
Bruk preparedStatements for å løse sikkerhetsrisikoen.
hint: forbindelse.prepareStatement
