100hz skjerm overklokking
Typisk for CS folk dette her. Husker det var et program som "mekket" slik at du fikk smoothere hz på skjermen, men dette funket ikke så bra på LCD skjermer. Refresh... (husker ikke resten) mener jeg det het.
Men på LCD er det noe helt annet. Det er noen dyyre flatskjerm TV'er som har 100hz, så jeg tror ikke vanlige pc flatskjermer har det enda. Finnes nok noen, dog.. :)
ok takk ;) gler mej til d kommer 100hz PC lcd :):):):):
Typiske LCD skjermer har en "tilnærmet" oppdateringsrate på 200Hz.
Liquid crystal displays
Wiki
Much of the discussion of refresh rate does not apply to the liquid crystal portion of an LCD monitor. This is because while a CRT monitor uses the same mechanism for both illumination and imaging, LCDs employ a separate backlight to illuminate the image being portrayed by the LCD's liquid crystal shutters. The shutters themselves do not have a "refresh rate" as such due to the fact that they always stay at whatever opacity they were last instructed to continuously, and do not become more or less transparent until instructed to produce a different opacity. Most of the TFT LCDs used in portable devices and computer monitors need a continuous refresh. The driving voltage determines the transmittance of the liquid crystal.
The closest thing liquid crystal shutters have to a refresh rate is their response time, while nearly all LCD backlights (most notably fluorescent cathodes, which commonly operate at (~200Hz) have a separate figure known as flicker, which describes how many times a second the backlight pulses on and off.
Mye nyttig lesing her dersom du ønsker å forstå mer om egenskaper ved LCD skjermer:
http://www.xbitlabs.com/articles/monitors/...parameters.html
