PS3'en skrur seg ikke på. Blinker rødt.
Toska92
Søstera mi kom å klagde over at ps3en hadde skrudd seg av når de så film. Lyset blinket rødt. Skrudde den helt av med knappen bakpå, og på gjen. Lyset var rødt, jeg trykkte.
Det blinket gult, så grønt å så skrudde den seg av.
Hva skjer?
Endret av Toska92
Hva skjer?
Kan vel dessverre se ut som om du har fått yellow light of death. Er en tråd om dette her.
Prøv dette først:
Hard Reset procedure for the PS3 (as instructed by Sony CS).
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully this will solve your freezing problems.
Problems/symptons that this appears to have resolved:
-freezing when doing anything
-no harddrive activity
-freezing when trying to use onboard keyboard or bringing up keyboard
-game/movie disc freezes system
