Xecuter Skrevet 12. februar 2009 Del Skrevet 12. februar 2009 (endret) X kræsjer hver gang jeg ser video i Arch og jeg går fra å se Grey's Anatomy til å se Scrubs. Dette skjer faktisk hver gang. Totem, har ikke sjekket om problemet er det samme i andre avspillere. Pluss, videoen kommer lenge etter lyden. /var/log/Xorg.0.log: X.Org X Server 1.5.3 Release Date: 5 November 2008 X Protocol Version 11, Revision 0 Build Operating System: Linux 2.6.27-ARCH x86_64 Current Operating System: Linux Arch 2.6.28-ARCH #1 SMP PREEMPT Sun Feb 8 09:47:26 UTC 2009 x86_64 Build Date: 17 December 2008 10:46:49PM Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Thu Feb 12 22:27:26 2009 (==) Using config file: "/etc/X11/xorg.conf" (==) ServerLayout "X.org Configured" (**) |-->Screen "aticonfig-Screen[0]-0" (0) (**) | |-->Monitor "aticonfig-Monitor[0]-0" (**) | |-->Device "aticonfig-Device[0]-0" (**) |-->Input Device "Mouse0" (**) |-->Input Device "Keyboard0" (==) Automatically adding devices (==) Automatically enabling devices (==) Including the default font path /usr/share/fonts/misc,/usr/share/fonts/100dpi:unscaled,/usr/share/fonts/75dpi:unscaled,/usr/share/fonts/TTF,/usr/share/fonts/Type1. (**) FontPath set to: /usr/share/fonts/misc, /usr/share/fonts/100dpi:unscaled, /usr/share/fonts/75dpi:unscaled, /usr/share/fonts/TTF, /usr/share/fonts/Type1, /usr/share/fonts/misc, /usr/share/fonts/100dpi:unscaled, /usr/share/fonts/75dpi:unscaled, /usr/share/fonts/TTF, /usr/share/fonts/Type1 (**) ModulePath set to "/usr/lib/xorg/modules" (**) Extension "Composite" is enabled (WW) AllowEmptyInput is on, devices using drivers 'kbd' or 'mouse' will be disabled. (WW) Disabling Mouse0 (WW) Disabling Keyboard0 (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory) (II) No APM support in BIOS or kernel (II) Loader magic: 0x7b54e0 (II) Module ABI versions: X.Org ANSI C Emulation: 0.4 X.Org Video Driver: 4.1 X.Org XInput driver : 2.1 X.Org Server Extension : 1.1 X.Org Font Renderer : 0.6 (II) Loader running on linux (++) using VT number 7 (--) PCI:*(0@1:0:0) ATI Technologies Inc RV610 video device [Radeon HD 2400 PRO] rev 0, Mem @ 0xd0000000/268435456, 0xfe8f0000/65536, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072 (II) System resource ranges: [0] -1 0 0xffffffff - 0xffffffff (0x1) MX [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [4] -1 0 0xffffffff - 0xffffffff (0x1) MX [5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [6] -1 0 0x000c0000 - 0x000effff (0x30000) MX [7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [8] -1 0 0xffffffff - 0xffffffff (0x1) MX [9] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [10] -1 0 0x000c0000 - 0x000effff (0x30000) MX [11] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [12] -1 0 0xffffffff - 0xffffffff (0x1) MX [13] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [14] -1 0 0x000c0000 - 0x000effff (0x30000) MX [15] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [16] -1 0 0xffffffff - 0xffffffff (0x1) MX [17] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [18] -1 0 0x000c0000 - 0x000effff (0x30000) MX [19] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [20] -1 0 0xffffffff - 0xffffffff (0x1) MX [21] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [22] -1 0 0x000c0000 - 0x000effff (0x30000) MX [23] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [24] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [25] -1 0 0x00000000 - 0x00000000 (0x1) IX [26] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [27] -1 0 0x00000000 - 0x00000000 (0x1) IX [28] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [29] -1 0 0x00000000 - 0x00000000 (0x1) IX [30] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [31] -1 0 0x00000000 - 0x00000000 (0x1) IX [32] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [33] -1 0 0x00000000 - 0x00000000 (0x1) IX [34] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [35] -1 0 0x00000000 - 0x00000000 (0x1) IX (II) "extmod" will be loaded. This was enabled by default and also specified in the config file. (II) "dbe" will be loaded. This was enabled by default and also specified in the config file. (II) "glx" will be loaded. This was enabled by default and also specified in the config file. (II) "freetype" will be loaded. This was enabled by default and also specified in the config file. (II) "dri" will be loaded. This was enabled by default and also specified in the config file. (II) LoadModule: "glx" (II) Loading /usr/lib/xorg/modules/extensions//libglx.so (II) Module glx: vendor="X.Org Foundation" compiled for 7.4.0, module version = 1.0.0 ABI class: X.Org Server Extension, version 1.1 (==) AIGLX disabled (WW) fglrx: Force AIGLX enabled (II) Loading extension GLX (II) LoadModule: "extmod" (II) Loading /usr/lib/xorg/modules/extensions//libextmod.so (II) Module extmod: vendor="X.Org Foundation" compiled for 1.5.3, module version = 1.0.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 1.1 (II) Loading extension SHAPE (II) Loading extension MIT-SUNDRY-NONSTANDARD (II) Loading extension BIG-REQUESTS (II) Loading extension SYNC (II) Loading extension MIT-SCREEN-SAVER (II) Loading extension XC-MISC (II) Loading extension XFree86-VidModeExtension (II) Loading extension XFree86-Misc (II) Loading extension XFree86-DGA (II) Loading extension DPMS (II) Loading extension TOG-CUP (II) Loading extension Extended-Visual-Information (II) Loading extension XVideo (II) Loading extension XVideo-MotionCompensation (II) Loading extension X-Resource (II) LoadModule: "xtrap" (II) Loading /usr/lib/xorg/modules/extensions//libxtrap.so (II) Module xtrap: vendor="X.Org Foundation" compiled for 1.5.3, module version = 1.0.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 1.1 (II) Loading extension DEC-XTRAP (II) LoadModule: "dri" (II) Loading /usr/lib/xorg/modules/extensions//libdri.so (II) Module dri: vendor="X.Org Foundation" compiled for 7.4.0, module version = 1.0.0 ABI class: X.Org Server Extension, version 1.1 (II) Loading extension XFree86-DRI (II) LoadModule: "dbe" (II) Loading /usr/lib/xorg/modules/extensions//libdbe.so (II) Module dbe: vendor="X.Org Foundation" compiled for 1.5.3, module version = 1.0.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 1.1 (II) Loading extension DOUBLE-BUFFER (II) LoadModule: "freetype" (II) Loading /usr/lib/xorg/modules/fonts//libfreetype.so (II) Module freetype: vendor="X.Org Foundation & the After X-TT Project" compiled for 1.5.3, module version = 2.1.0 Module class: X.Org Font Renderer ABI class: X.Org Font Renderer, version 0.6 (II) Loading font FreeType (II) LoadModule: "fglrx" (II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so (II) Module fglrx: vendor="FireGL - ATI Technologies Inc." compiled for 1.4.99.906, module version = 8.56.4 Module class: X.Org Video Driver (II) Primary Device is: PCI 01@00:00:0 (WW) Falling back to old probe method for fglrx (II) ATI Proprietary Linux Driver Version Identifier:8.56.4 (II) ATI Proprietary Linux Driver Release Identifier: 8.561 (II) ATI Proprietary Linux Driver Build Date: Dec 1 2008 14:56:52 (WW) This ATI Proprietary Linux Driver does not guarantee support of video driver ABI higher than 2.0 (WW) Video driver ABI version of the X server is 4.1 (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:0:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:2:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:6:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:18:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:1) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:2) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:3) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:4) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:5) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:1) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:2) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:3) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:4) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@1:0:1) found (--) Chipset Supported AMD Graphics Processor (0x94C3) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:0:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:2:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:6:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:18:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:1) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:2) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:3) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:4) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:19:5) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:0) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:1) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:2) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:3) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@0:20:4) found (WW) fglrx: No matching Device section for instance (BusID PCI:0@1:0:1) found (II) AMD Video driver is running on a device belonging to a group targeted for this release (II) AMD Video driver is signed (II) resource ranges after xf86ClaimFixedResources() call: [0] -1 0 0xffffffff - 0xffffffff (0x1) MX [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [4] -1 0 0xffffffff - 0xffffffff (0x1) MX [5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [6] -1 0 0x000c0000 - 0x000effff (0x30000) MX [7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [8] -1 0 0xffffffff - 0xffffffff (0x1) MX [9] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [10] -1 0 0x000c0000 - 0x000effff (0x30000) MX [11] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [12] -1 0 0xffffffff - 0xffffffff (0x1) MX [13] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [14] -1 0 0x000c0000 - 0x000effff (0x30000) MX [15] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [16] -1 0 0xffffffff - 0xffffffff (0x1) MX [17] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [18] -1 0 0x000c0000 - 0x000effff (0x30000) MX [19] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [20] -1 0 0xffffffff - 0xffffffff (0x1) MX [21] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [22] -1 0 0x000c0000 - 0x000effff (0x30000) MX [23] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [24] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [25] -1 0 0x00000000 - 0x00000000 (0x1) IX [26] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [27] -1 0 0x00000000 - 0x00000000 (0x1) IX [28] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [29] -1 0 0x00000000 - 0x00000000 (0x1) IX [30] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [31] -1 0 0x00000000 - 0x00000000 (0x1) IX [32] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [33] -1 0 0x00000000 - 0x00000000 (0x1) IX [34] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [35] -1 0 0x00000000 - 0x00000000 (0x1) IX (II) fglrx(0): pEnt->device->identifier=0x13d0bc0 (II) resource ranges after probing: [0] -1 0 0xffffffff - 0xffffffff (0x1) MX [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [4] -1 0 0xffffffff - 0xffffffff (0x1) MX [5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [6] -1 0 0x000c0000 - 0x000effff (0x30000) MX [7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [8] -1 0 0xffffffff - 0xffffffff (0x1) MX [9] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [10] -1 0 0x000c0000 - 0x000effff (0x30000) MX [11] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [12] -1 0 0xffffffff - 0xffffffff (0x1) MX [13] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [14] -1 0 0x000c0000 - 0x000effff (0x30000) MX [15] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [16] -1 0 0xffffffff - 0xffffffff (0x1) MX [17] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [18] -1 0 0x000c0000 - 0x000effff (0x30000) MX [19] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [20] -1 0 0xffffffff - 0xffffffff (0x1) MX [21] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [22] -1 0 0x000c0000 - 0x000effff (0x30000) MX [23] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [24] 0 0 0x000a0000 - 0x000affff (0x10000) MS [25] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS [26] 0 0 0x000b8000 - 0x000bffff (0x8000) MS [27] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [28] -1 0 0x00000000 - 0x00000000 (0x1) IX [29] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [30] -1 0 0x00000000 - 0x00000000 (0x1) IX [31] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [32] -1 0 0x00000000 - 0x00000000 (0x1) IX [33] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [34] -1 0 0x00000000 - 0x00000000 (0x1) IX [35] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [36] -1 0 0x00000000 - 0x00000000 (0x1) IX [37] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [38] -1 0 0x00000000 - 0x00000000 (0x1) IX [39] 0 0 0x000003b0 - 0x000003bb (0xc) IS [40] 0 0 0x000003c0 - 0x000003df (0x20) IS (II) Setting vga for screen 0. (II) fglrx(0): === [atiddxPreInit] === begin (II) Loading sub module "vgahw" (II) LoadModule: "vgahw" (II) Loading /usr/lib/xorg/modules//libvgahw.so (II) Module vgahw: vendor="X.Org Foundation" compiled for 1.5.3, module version = 0.1.0 ABI class: X.Org Video Driver, version 4.1 (II) fglrx(0): PCI bus 1 card 0 func 0 (**) fglrx(0): Depth 24, (--) framebuffer bpp 32 (II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps) (==) fglrx(0): Default visual is TrueColor (**) fglrx(0): Option "DPMS" "true" (II) fglrx(0): Loading PCS database from /etc/ati/amdpcsdb (II) fglrx(0): 10BitPixelFormat disabled by default (==) fglrx(0): RGB weight 888 (II) fglrx(0): Using 8 bits per RGB (8 bit DAC) (**) fglrx(0): Gamma Correction for I is 0x06419064 (==) fglrx(0): Gamma Correction for II is 0x06419064 (==) fglrx(0): Buffer Tiling is ON (II) Loading sub module "fglrxdrm" (II) LoadModule: "fglrxdrm" (II) Loading /usr/lib/xorg/modules/linux//libfglrxdrm.so (II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc." compiled for 1.4.99.906, module version = 8.56.4 ABI class: X.Org Server Extension, version 1.1 (--) fglrx(0): Chipset: "ATI Radeon HD 2400 PRO" (Chipset = 0x94c3) (--) fglrx(0): (PciSubVendor = 0x1043, PciSubDevice = 0x01c2) (--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI (--) fglrx(0): Linear framebuffer (phys) at 0xd0000000 (--) fglrx(0): MMIO registers at 0xfe8f0000 (--) fglrx(0): I/O port at 0x0000e000 (==) fglrx(0): ROM-BIOS at 0x000c0000 (II) Loading sub module "int10" (II) LoadModule: "int10" (II) Loading /usr/lib/xorg/modules//libint10.so (II) Module int10: vendor="X.Org Foundation" compiled for 1.5.3, module version = 1.0.0 ABI class: X.Org Video Driver, version 4.1 (II) fglrx(0): Primary V_BIOS segment is: 0xc000 (II) Loading sub module "vbe" (II) LoadModule: "vbe" (II) Loading /usr/lib/xorg/modules//libvbe.so (II) Module vbe: vendor="X.Org Foundation" compiled for 1.5.3, module version = 1.1.0 ABI class: X.Org Video Driver, version 4.1 (II) fglrx(0): VESA BIOS detected (II) fglrx(0): VESA VBE Version 3.0 (II) fglrx(0): VESA VBE Total Mem: 16384 kB (II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS (II) fglrx(0): VESA VBE OEM Software Rev: 10.56 (II) fglrx(0): VESA VBE OEM Vendor: © 1988-2005, ATI Technologies Inc. (II) fglrx(0): VESA VBE OEM Product: RV610 (II) fglrx(0): VESA VBE OEM Product Rev: 01.00 (II) fglrx(0): ATI Video BIOS revision 9 or later detected drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 9, (OK) drmOpenByBusid: Searching for BusID PCI:1:0:0 drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 9, (OK) drmOpenByBusid: drmOpenMinor returns 9 drmOpenByBusid: drmGetBusid reports PCI:1:0:0 (II) fglrx(0): Using adapter: 1:0.0. (II) fglrx(0): [FB] MC range(MCFBBase = 0xc0000000, MCFBSize = 0x10000000) (--) fglrx(0): Video RAM: 262144 kByte, Type: DDR2 (II) fglrx(0): PCIE card detected (--) fglrx(0): Using per-process page tables (PPPT) as GART. (WW) fglrx(0): board is an unknown third party board, chipset is supported (II) Loading sub module "ddc" (II) LoadModule: "ddc" (II) Module "ddc" already built-in (II) fglrx(0): ***Display: ConnectedDisplayTypes=0x00000080, disabled=0x00000000 (II) fglrx(0): Connected Display1: DFP on secondary TMDS [tmds2i] (II) fglrx(0): Display1 EDID data --------------------------- (II) fglrx(0): Manufacturer: HWP Model: 2695 Serial#: 16843009 (II) fglrx(0): Year: 2006 Week: 40 (II) fglrx(0): EDID Version: 1.3 (II) fglrx(0): Digital Display Input (II) fglrx(0): Max Image Size [cm]: horiz.: 43 vert.: 27 (II) fglrx(0): Gamma: 2.20 (II) fglrx(0): DPMS capabilities: StandBy Suspend Off (II) fglrx(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 (II) fglrx(0): Default color space is primary color space (II) fglrx(0): First detailed timing is preferred mode (II) fglrx(0): redX: 0.651 redY: 0.333 greenX: 0.277 greenY: 0.614 (II) fglrx(0): blueX: 0.145 blueY: 0.082 whiteX: 0.313 whiteY: 0.329 (II) fglrx(0): Supported VESA Video Modes: (II) fglrx(0): 720x400@70Hz (II) fglrx(0): 640x480@60Hz (II) fglrx(0): 640x480@72Hz (II) fglrx(0): 640x480@75Hz (II) fglrx(0): 800x600@60Hz (II) fglrx(0): 800x600@72Hz (II) fglrx(0): 800x600@75Hz (II) fglrx(0): 832x624@75Hz (II) fglrx(0): 1024x768@60Hz (II) fglrx(0): 1024x768@70Hz (II) fglrx(0): 1024x768@75Hz (II) fglrx(0): 1152x870@75Hz (II) fglrx(0): Manufacturer's mask: 0 (II) fglrx(0): Supported Future Video Modes: (II) fglrx(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897 (II) fglrx(0): #1: hsize: 1680 vsize 1050 refresh: 60 vid: 179 (II) fglrx(0): #2: hsize: 1680 vsize 1050 refresh: 75 vid: 4019 (II) fglrx(0): Supported additional Video Mode: (II) fglrx(0): clock: 146.2 MHz Image Size: 430 x 270 mm (II) fglrx(0): h_active: 1680 h_sync: 1784 h_sync_end 1960 h_blank_end 2240 h_border: 0 (II) fglrx(0): v_active: 1050 v_sync: 1080 v_sync_end 1086 v_blanking: 1089 v_border: 0 (II) fglrx(0): Ranges: V min: 50 V max: 76 Hz, H min: 24 H max: 93 kHz, PixClock max 160 MHz (II) fglrx(0): Monitor name: HP L2045w (II) fglrx(0): Serial No: CNT640H1DZ (II) fglrx(0): EDID (in hex): (II) fglrx(0): 00ffffffffffff0022f0952601010101 (II) fglrx(0): 28100103802b1b78eed105a655479d25 (II) fglrx(0): 155054adee808180b300b30f01010101 (II) fglrx(0): 01010101010121399030621a274068b0 (II) fglrx(0): e604ae0e1100001c000000fd00324c18 (II) fglrx(0): 5d10000a202020202020000000fc0048 (II) fglrx(0): 50204c32303435770a202020000000ff (II) fglrx(0): 00434e543634304831445a0a20200062 (II) fglrx(0): End of Display1 EDID data -------------------- (WW) fglrx(0): Only one display is connnected,so single mode is enabled (II) fglrx(0): Primary Controller - DFP on secondary TMDS (II) fglrx(0): Internal Desktop Setting: 0x00000001 (==) fglrx(0): QBS disabled (==) fglrx(0): FAST_SWAP disabled (==) fglrx(0): PseudoColor visuals disabled (**) fglrx(0): Center Mode is disabled (==) fglrx(0): TMDS coherent mode is enabled (II) fglrx(0): Total of 35 modes found for primary display. (--) fglrx(0): Virtual size is 1680x1050 (pitch 0) (**) fglrx(0): *Mode "1680x1050": 146.2 MHz (scaled from 0.0 MHz), 65.3 kHz, 60.0 Hz (II) fglrx(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1080 1086 1089 +hsync (65.3 kHz) (**) fglrx(0): *Mode "1440x900": 106.5 MHz (scaled from 0.0 MHz), 55.9 kHz, 60.0 Hz (II) fglrx(0): Modeline "1440x900"x60.0 106.50 1440 1520 1672 1904 900 903 909 934 +vsync (55.9 kHz) (**) fglrx(0): *Mode "1400x1050": 121.8 MHz (scaled from 0.0 MHz), 65.3 kHz, 60.0 Hz (II) fglrx(0): Modeline "1400x1050"x60.0 121.75 1400 1488 1632 1864 1050 1053 1057 1089 +hsync (65.3 kHz) (**) fglrx(0): *Mode "1280x1024": 135.0 MHz (scaled from 0.0 MHz), 80.0 kHz, 75.0 Hz (II) fglrx(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 (80.0 kHz) (**) fglrx(0): Default mode "1280x1024": 128.9 MHz (scaled from 0.0 MHz), 74.6 kHz, 70.0 Hz (II) fglrx(0): Modeline "1280x1024"x70.0 128.94 1280 1368 1504 1728 1024 1025 1028 1066 +hsync (74.6 kHz) (**) fglrx(0): Default mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz (II) fglrx(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 (64.0 kHz) (**) fglrx(0): *Mode "1280x960": 108.0 MHz (scaled from 0.0 MHz), 60.0 kHz, 60.0 Hz (II) fglrx(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 (60.0 kHz) (**) fglrx(0): *Mode "1280x768": 79.5 MHz (scaled from 0.0 MHz), 47.8 kHz, 60.0 Hz (II) fglrx(0): Modeline "1280x768"x60.0 79.50 1280 1344 1472 1664 768 771 778 798 +hsync (47.8 kHz) (**) fglrx(0): *Mode "1280x720": 74.5 MHz (scaled from 0.0 MHz), 44.8 kHz, 60.0 Hz (II) fglrx(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 +hsync (44.8 kHz) (**) fglrx(0): *Mode "1152x864": 108.0 MHz (scaled from 0.0 MHz), 67.5 kHz, 75.0 Hz (II) fglrx(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 (67.5 kHz) (**) fglrx(0): Default mode "1152x864": 81.6 MHz (scaled from 0.0 MHz), 53.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 +hsync (53.7 kHz) (**) fglrx(0): *Mode "1024x768": 78.8 MHz (scaled from 0.0 MHz), 60.0 kHz, 75.0 Hz (II) fglrx(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 (60.0 kHz) (**) fglrx(0): Default mode "1024x768": 78.4 MHz (scaled from 0.0 MHz), 57.7 kHz, 72.0 Hz (II) fglrx(0): Modeline "1024x768"x72.0 78.43 1024 1080 1192 1360 768 769 772 801 +hsync (57.7 kHz) (**) fglrx(0): Default mode "1024x768": 75.0 MHz (scaled from 0.0 MHz), 56.5 kHz, 70.0 Hz (II) fglrx(0): Modeline "1024x768"x70.0 75.00 1024 1048 1184 1328 768 771 777 806 +hsync +vsync (56.5 kHz) (**) fglrx(0): Default mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz (II) fglrx(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 +hsync +vsync (48.4 kHz) (**) fglrx(0): *Mode "800x600": 49.5 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz (II) fglrx(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 (46.9 kHz) (**) fglrx(0): Default mode "800x600": 50.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.0 Hz (II) fglrx(0): Modeline "800x600"x72.0 50.00 800 856 976 1040 600 637 643 666 (48.1 kHz) (**) fglrx(0): Default mode "800x600": 45.5 MHz (scaled from 0.0 MHz), 43.8 kHz, 70.0 Hz (II) fglrx(0): Modeline "800x600"x70.0 45.50 800 840 920 1040 600 601 604 625 +hsync (43.8 kHz) (**) fglrx(0): Default mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.0 Hz (II) fglrx(0): Modeline "800x600"x60.0 40.00 800 840 968 1056 600 601 605 628 (37.9 kHz) (**) fglrx(0): Default mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.0 Hz (II) fglrx(0): Modeline "800x600"x56.0 36.00 800 824 896 1024 600 601 603 625 (35.2 kHz) (**) fglrx(0): *Mode "720x480": 26.7 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz (II) fglrx(0): Modeline "720x480"x60.0 26.71 720 736 808 896 480 481 484 497 +hsync (29.8 kHz) (**) fglrx(0): *Mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz (II) fglrx(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 +hsync +vsync (37.5 kHz) (**) fglrx(0): Default mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 72.0 Hz (II) fglrx(0): Modeline "640x480"x72.0 31.50 640 664 704 832 480 489 492 520 +hsync +vsync (37.9 kHz) (**) fglrx(0): Default mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (II) fglrx(0): Modeline "640x480"x60.0 25.18 640 656 752 800 480 490 492 525 +hsync +vsync (31.5 kHz) (**) fglrx(0): Default mode "640x432": 21.1 MHz (scaled from 0.0 MHz), 26.9 kHz, 60.0 Hz (II) fglrx(0): Modeline "640x432"x60.0 21.07 640 648 712 784 432 433 436 448 +hsync (26.9 kHz) (**) fglrx(0): Default mode "640x400": 28.1 MHz (scaled from 0.0 MHz), 33.7 kHz, 75.0 Hz (II) fglrx(0): Modeline "640x400"x75.0 28.07 640 696 736 832 400 413 415 449 (33.7 kHz) (**) fglrx(0): Default mode "640x400": 24.9 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (II) fglrx(0): Modeline "640x400"x60.0 24.92 640 664 760 792 400 460 462 525 (31.5 kHz) (**) fglrx(0): Default mode "512x384": 19.7 MHz (scaled from 0.0 MHz), 31.1 kHz, 75.0 Hz (II) fglrx(0): Modeline "512x384"x75.0 19.68 512 528 576 632 384 384 385 416 (31.1 kHz) (**) fglrx(0): Default mode "512x384": 19.8 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz (II) fglrx(0): Modeline "512x384"x60.0 19.81 512 544 624 664 384 451 453 497 (29.8 kHz) (**) fglrx(0): Default mode "400x300": 24.8 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz (D) (II) fglrx(0): Modeline "400x300"x75.0 24.75 400 408 448 528 300 601 602 625 doublescan (46.9 kHz) (**) fglrx(0): Default mode "400x300": 22.3 MHz (scaled from 0.0 MHz), 45.0 kHz, 60.0 Hz (D) (II) fglrx(0): Modeline "400x300"x60.0 22.33 400 416 480 496 300 601 605 742 doublescan (45.0 kHz) (**) fglrx(0): Default mode "320x240": 15.8 MHz (scaled from 0.0 MHz), 37.9 kHz, 75.0 Hz (D) (II) fglrx(0): Modeline "320x240"x75.0 15.75 320 328 360 416 240 481 482 501 doublescan (37.9 kHz) (**) fglrx(0): Default mode "320x240": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D) (II) fglrx(0): Modeline "320x240"x60.0 12.59 320 328 376 400 240 491 493 525 doublescan (31.5 kHz) (**) fglrx(0): Default mode "320x200": 13.1 MHz (scaled from 0.0 MHz), 31.5 kHz, 75.0 Hz (D) (II) fglrx(0): Modeline "320x200"x75.0 13.10 320 352 368 416 200 406 407 417 doublescan (31.5 kHz) (**) fglrx(0): Default mode "320x200": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D) (II) fglrx(0): Modeline "320x200"x60.0 12.59 320 336 384 400 200 457 459 524 doublescan (31.5 kHz) (--) fglrx(0): Display dimensions: (430, 270) mm (--) fglrx(0): DPI set to (99, 98) (--) fglrx(0): Virtual size is 1680x1050 (pitch 1728) (**) fglrx(0): *Mode "1680x1050": 146.2 MHz (scaled from 0.0 MHz), 65.3 kHz, 60.0 Hz (II) fglrx(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1080 1086 1089 +hsync (65.3 kHz) (**) fglrx(0): *Mode "1440x900": 106.5 MHz (scaled from 0.0 MHz), 55.9 kHz, 60.0 Hz (II) fglrx(0): Modeline "1440x900"x60.0 106.50 1440 1520 1672 1904 900 903 909 934 +vsync (55.9 kHz) (**) fglrx(0): *Mode "1400x1050": 121.8 MHz (scaled from 0.0 MHz), 65.3 kHz, 60.0 Hz (II) fglrx(0): Modeline "1400x1050"x60.0 121.75 1400 1488 1632 1864 1050 1053 1057 1089 +hsync (65.3 kHz) (**) fglrx(0): *Mode "1280x1024": 135.0 MHz (scaled from 0.0 MHz), 80.0 kHz, 75.0 Hz (II) fglrx(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 (80.0 kHz) (**) fglrx(0): Default mode "1280x1024": 128.9 MHz (scaled from 0.0 MHz), 74.6 kHz, 70.0 Hz (II) fglrx(0): Modeline "1280x1024"x70.0 128.94 1280 1368 1504 1728 1024 1025 1028 1066 +hsync (74.6 kHz) (**) fglrx(0): Default mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz (II) fglrx(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 (64.0 kHz) (**) fglrx(0): *Mode "1280x960": 108.0 MHz (scaled from 0.0 MHz), 60.0 kHz, 60.0 Hz (II) fglrx(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 (60.0 kHz) (**) fglrx(0): *Mode "1280x768": 79.5 MHz (scaled from 0.0 MHz), 47.8 kHz, 60.0 Hz (II) fglrx(0): Modeline "1280x768"x60.0 79.50 1280 1344 1472 1664 768 771 778 798 +hsync (47.8 kHz) (**) fglrx(0): *Mode "1280x720": 74.5 MHz (scaled from 0.0 MHz), 44.8 kHz, 60.0 Hz (II) fglrx(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 +hsync (44.8 kHz) (**) fglrx(0): *Mode "1152x864": 108.0 MHz (scaled from 0.0 MHz), 67.5 kHz, 75.0 Hz (II) fglrx(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 (67.5 kHz) (**) fglrx(0): Default mode "1152x864": 81.6 MHz (scaled from 0.0 MHz), 53.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 +hsync (53.7 kHz) (**) fglrx(0): *Mode "1024x768": 78.8 MHz (scaled from 0.0 MHz), 60.0 kHz, 75.0 Hz (II) fglrx(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 (60.0 kHz) (**) fglrx(0): Default mode "1024x768": 78.4 MHz (scaled from 0.0 MHz), 57.7 kHz, 72.0 Hz (II) fglrx(0): Modeline "1024x768"x72.0 78.43 1024 1080 1192 1360 768 769 772 801 +hsync (57.7 kHz) (**) fglrx(0): Default mode "1024x768": 75.0 MHz (scaled from 0.0 MHz), 56.5 kHz, 70.0 Hz (II) fglrx(0): Modeline "1024x768"x70.0 75.00 1024 1048 1184 1328 768 771 777 806 +hsync +vsync (56.5 kHz) (**) fglrx(0): Default mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz (II) fglrx(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 +hsync +vsync (48.4 kHz) (**) fglrx(0): *Mode "800x600": 49.5 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz (II) fglrx(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 (46.9 kHz) (**) fglrx(0): Default mode "800x600": 50.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.0 Hz (II) fglrx(0): Modeline "800x600"x72.0 50.00 800 856 976 1040 600 637 643 666 (48.1 kHz) (**) fglrx(0): Default mode "800x600": 45.5 MHz (scaled from 0.0 MHz), 43.8 kHz, 70.0 Hz (II) fglrx(0): Modeline "800x600"x70.0 45.50 800 840 920 1040 600 601 604 625 +hsync (43.8 kHz) (**) fglrx(0): Default mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.0 Hz (II) fglrx(0): Modeline "800x600"x60.0 40.00 800 840 968 1056 600 601 605 628 (37.9 kHz) (**) fglrx(0): Default mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.0 Hz (II) fglrx(0): Modeline "800x600"x56.0 36.00 800 824 896 1024 600 601 603 625 (35.2 kHz) (**) fglrx(0): *Mode "720x480": 26.7 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz (II) fglrx(0): Modeline "720x480"x60.0 26.71 720 736 808 896 480 481 484 497 +hsync (29.8 kHz) (**) fglrx(0): *Mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz (II) fglrx(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 +hsync +vsync (37.5 kHz) (**) fglrx(0): Default mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 72.0 Hz (II) fglrx(0): Modeline "640x480"x72.0 31.50 640 664 704 832 480 489 492 520 +hsync +vsync (37.9 kHz) (**) fglrx(0): Default mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (II) fglrx(0): Modeline "640x480"x60.0 25.18 640 656 752 800 480 490 492 525 +hsync +vsync (31.5 kHz) (**) fglrx(0): Default mode "640x432": 21.1 MHz (scaled from 0.0 MHz), 26.9 kHz, 60.0 Hz (II) fglrx(0): Modeline "640x432"x60.0 21.07 640 648 712 784 432 433 436 448 +hsync (26.9 kHz) (**) fglrx(0): Default mode "640x400": 28.1 MHz (scaled from 0.0 MHz), 33.7 kHz, 75.0 Hz (II) fglrx(0): Modeline "640x400"x75.0 28.07 640 696 736 832 400 413 415 449 (33.7 kHz) (**) fglrx(0): Default mode "640x400": 24.9 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (II) fglrx(0): Modeline "640x400"x60.0 24.92 640 664 760 792 400 460 462 525 (31.5 kHz) (**) fglrx(0): Default mode "512x384": 19.7 MHz (scaled from 0.0 MHz), 31.1 kHz, 75.0 Hz (II) fglrx(0): Modeline "512x384"x75.0 19.68 512 528 576 632 384 384 385 416 (31.1 kHz) (**) fglrx(0): Default mode "512x384": 19.8 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz (II) fglrx(0): Modeline "512x384"x60.0 19.81 512 544 624 664 384 451 453 497 (29.8 kHz) (**) fglrx(0): Default mode "400x300": 24.8 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz (D) (II) fglrx(0): Modeline "400x300"x75.0 24.75 400 408 448 528 300 601 602 625 doublescan (46.9 kHz) (**) fglrx(0): Default mode "400x300": 22.3 MHz (scaled from 0.0 MHz), 45.0 kHz, 60.0 Hz (D) (II) fglrx(0): Modeline "400x300"x60.0 22.33 400 416 480 496 300 601 605 742 doublescan (45.0 kHz) (**) fglrx(0): Default mode "320x240": 15.8 MHz (scaled from 0.0 MHz), 37.9 kHz, 75.0 Hz (D) (II) fglrx(0): Modeline "320x240"x75.0 15.75 320 328 360 416 240 481 482 501 doublescan (37.9 kHz) (**) fglrx(0): Default mode "320x240": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D) (II) fglrx(0): Modeline "320x240"x60.0 12.59 320 328 376 400 240 491 493 525 doublescan (31.5 kHz) (**) fglrx(0): Default mode "320x200": 13.1 MHz (scaled from 0.0 MHz), 31.5 kHz, 75.0 Hz (D) (II) fglrx(0): Modeline "320x200"x75.0 13.10 320 352 368 416 200 406 407 417 doublescan (31.5 kHz) (**) fglrx(0): Default mode "320x200": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D) (II) fglrx(0): Modeline "320x200"x60.0 12.59 320 336 384 400 200 457 459 524 doublescan (31.5 kHz) (II) Loading sub module "fb" (II) LoadModule: "fb" (II) Loading /usr/lib/xorg/modules//libfb.so (II) Module fb: vendor="X.Org Foundation" compiled for 1.5.3, module version = 1.0.0 ABI class: X.Org ANSI C Emulation, version 0.4 (II) Loading sub module "ramdac" (II) LoadModule: "ramdac" (II) Module "ramdac" already built-in (==) fglrx(0): NoAccel = NO (II) Loading sub module "xaa" (II) LoadModule: "xaa" (II) Loading /usr/lib/xorg/modules//libxaa.so (II) Module xaa: vendor="X.Org Foundation" compiled for 1.5.3, module version = 1.2.1 ABI class: X.Org Video Driver, version 4.1 (==) fglrx(0): NoDRI = NO (II) Loading sub module "fglrxdrm" (II) LoadModule: "fglrxdrm" (II) Reloading /usr/lib/xorg/modules/linux//libfglrxdrm.so (==) fglrx(0): Capabilities: 0x00000000 (==) fglrx(0): CapabilitiesEx: 0x00000000 (==) fglrx(0): cpuFlags: 0x4000001f (==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so" (II) fglrx(0): [pcie] 262144 kB allocated (II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 65536 (==) fglrx(0): UseFastTLS=0 (==) fglrx(0): BlockSignalsOnLock=1 (II) fglrx(0): Direct rendering enabled (II) fglrx(0): AC Adapter is used (II) fglrx(0): Interrupt handler installed at IRQ 18. (II) fglrx(0): Exposed events to the /proc interface (II) fglrx(0): Finished Initialize PPLIB! (--) Depth 24 pixmap format is 32 bpp (II) do I need RAC? No, I don't. (II) resource ranges after preInit: [0] -1 0 0xffffffff - 0xffffffff (0x1) MX [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [4] -1 0 0xffffffff - 0xffffffff (0x1) MX [5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [6] -1 0 0x000c0000 - 0x000effff (0x30000) MX [7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [8] -1 0 0xffffffff - 0xffffffff (0x1) MX [9] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [10] -1 0 0x000c0000 - 0x000effff (0x30000) MX [11] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [12] -1 0 0xffffffff - 0xffffffff (0x1) MX [13] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [14] -1 0 0x000c0000 - 0x000effff (0x30000) MX [15] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [16] -1 0 0xffffffff - 0xffffffff (0x1) MX [17] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [18] -1 0 0x000c0000 - 0x000effff (0x30000) MX [19] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [20] -1 0 0xffffffff - 0xffffffff (0x1) MX [21] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [22] -1 0 0x000c0000 - 0x000effff (0x30000) MX [23] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [24] 0 0 0x000a0000 - 0x000affff (0x10000) MS(OprU) [25] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS(OprU) [26] 0 0 0x000b8000 - 0x000bffff (0x8000) MS(OprU) [27] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [28] -1 0 0x00000000 - 0x00000000 (0x1) IX [29] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [30] -1 0 0x00000000 - 0x00000000 (0x1) IX [31] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [32] -1 0 0x00000000 - 0x00000000 (0x1) IX [33] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [34] -1 0 0x00000000 - 0x00000000 (0x1) IX [35] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [36] -1 0 0x00000000 - 0x00000000 (0x1) IX [37] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [38] -1 0 0x00000000 - 0x00000000 (0x1) IX [39] 0 0 0x000003b0 - 0x000003bb (0xc) IS(OprU) [40] 0 0 0x000003c0 - 0x000003df (0x20) IS(OprU) (II) fglrx(0): driver needs X.org 1.4.x.y with x.y >= 99.906 (II) fglrx(0): detected X.org 7.4.3.0 (II) Loading extension ATIFGLRXDRI (II) fglrx(0): doing DRIScreenInit (II) fglrx(0): DRIScreenInit for fglrx driver drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 10, (OK) drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 10, (OK) drmOpenByBusid: Searching for BusID PCI:1:0:0 drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 10, (OK) drmOpenByBusid: drmOpenMinor returns 10 drmOpenByBusid: drmGetBusid reports PCI:1:0:0 (II) fglrx(0): [drm] DRM interface version 1.0 (II) fglrx(0): [drm] created "fglrx" driver at busid "PCI:1:0:0" (II) fglrx(0): [drm] added 8192 byte SAREA at 0x2000 (II) fglrx(0): [drm] mapped SAREA 0x2000 to 0x7f6fc74fc000 (II) fglrx(0): [drm] framebuffer handle = 0x3000 (II) fglrx(0): [drm] added 1 reserved context for kernel (II) fglrx(0): DRIScreenInit done (II) fglrx(0): Kernel Module Version Information: (II) fglrx(0): Name: fglrx (II) fglrx(0): Version: 8.56.4 (II) fglrx(0): Date: Dec 1 2008 (II) fglrx(0): Desc: ATI FireGL DRM kernel module (II) fglrx(0): Kernel Module version matches driver. (II) fglrx(0): Kernel Module Build Time Information: (II) fglrx(0): Build-Kernel UTS_RELEASE: 2.6.28-ARCH (II) fglrx(0): Build-Kernel MODVERSIONS: no (II) fglrx(0): Build-Kernel __SMP__: no (II) fglrx(0): Build-Kernel PAGE_SIZE: 0x1000 (II) fglrx(0): [drm] register handle = 0x00004000 (II) fglrx(0): DRI initialization successfull! (II) fglrx(0): FBADPhys: 0xc0000000 FBMappedSize: 0x01008000 (II) fglrx(0): FBMM initialized for area (0,0)-(1728,2432) (II) fglrx(0): FBMM auto alloc for area (0,0)-(1728,1050) (front color buffer - assumption) (II) fglrx(0): Largest offscreen area available: 1728 x 1382 (==) fglrx(0): Backing store disabled (II) Loading extension FGLRXEXTENSION (II) Loading extension ATITVOUT (**) fglrx(0): DPMS enabled (**) fglrx(0): Textured Video is enabled. (II) LoadModule: "glesx" (II) Loading /usr/lib/xorg/modules//glesx.so (II) Module glesx: vendor="X.Org Foundation" compiled for 1.4.99.906, module version = 1.0.0 ABI class: X.Org Server Extension, version 1.1 (II) Loading extension GLESX (II) fglrx(0): GLESX enableFlags = 90 (II) fglrx(0): Using XFree86 Acceleration Architecture (XAA) Screen to screen bit blits Solid filled rectangles Solid Horizontal and Vertical Lines Driver provided ScreenToScreenBitBlt replacement Driver provided FillSolidRects replacement (II) fglrx(0): GLESX is enabled (II) LoadModule: "amdxmm" (II) Loading /usr/lib/xorg/modules//amdxmm.so (II) Module amdxmm: vendor="X.Org Foundation" compiled for 1.4.99.906, module version = 1.0.0 ABI class: X.Org Server Extension, version 1.1 (II) fglrx(0): UVD2 feature is available (WW) fglrx(0): Option "VendorName" is not used (WW) fglrx(0): Option "ModelName" is not used (II) fglrx(0): X context handle = 0x1 (II) fglrx(0): [DRI] installation complete (==) fglrx(0): Silken mouse enabled (==) fglrx(0): Using hardware cursor (==) RandR enabled (II) Initializing built-in extension MIT-SHM (II) Initializing built-in extension XInputExtension (II) Initializing built-in extension XTEST (II) Initializing built-in extension XKEYBOARD (II) Initializing built-in extension XC-APPGROUP (II) Initializing built-in extension SECURITY (II) Initializing built-in extension XINERAMA (II) Initializing built-in extension XFIXES (II) Initializing built-in extension RENDER (II) Initializing built-in extension RANDR (II) Initializing built-in extension COMPOSITE (II) Initializing built-in extension DAMAGE (II) Initializing built-in extension XEVIE drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 11, (OK) drmOpenByBusid: Searching for BusID PCI:1:0:0 drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 11, (OK) drmOpenByBusid: drmOpenMinor returns 11 drmOpenByBusid: drmGetBusid reports PCI:1:0:0 (WW) AIGLX: 3D driver claims to not support visual 0x23 (WW) AIGLX: 3D driver claims to not support visual 0x24 (WW) AIGLX: 3D driver claims to not support visual 0x25 (WW) AIGLX: 3D driver claims to not support visual 0x26 (WW) AIGLX: 3D driver claims to not support visual 0x27 (WW) AIGLX: 3D driver claims to not support visual 0x28 (WW) AIGLX: 3D driver claims to not support visual 0x29 (WW) AIGLX: 3D driver claims to not support visual 0x2a (WW) AIGLX: 3D driver claims to not support visual 0x2b (WW) AIGLX: 3D driver claims to not support visual 0x2c (WW) AIGLX: 3D driver claims to not support visual 0x2d (WW) AIGLX: 3D driver claims to not support visual 0x2e (WW) AIGLX: 3D driver claims to not support visual 0x2f (WW) AIGLX: 3D driver claims to not support visual 0x30 (WW) AIGLX: 3D driver claims to not support visual 0x31 (WW) AIGLX: 3D driver claims to not support visual 0x32 (WW) AIGLX: 3D driver claims to not support visual 0x33 (WW) AIGLX: 3D driver claims to not support visual 0x34 (WW) AIGLX: 3D driver claims to not support visual 0x35 (WW) AIGLX: 3D driver claims to not support visual 0x36 (WW) AIGLX: 3D driver claims to not support visual 0x37 (WW) AIGLX: 3D driver claims to not support visual 0x38 (WW) AIGLX: 3D driver claims to not support visual 0x39 (WW) AIGLX: 3D driver claims to not support visual 0x3a (WW) AIGLX: 3D driver claims to not support visual 0x3b (WW) AIGLX: 3D driver claims to not support visual 0x3c (WW) AIGLX: 3D driver claims to not support visual 0x3d (WW) AIGLX: 3D driver claims to not support visual 0x3e (WW) AIGLX: 3D driver claims to not support visual 0x3f (WW) AIGLX: 3D driver claims to not support visual 0x40 (WW) AIGLX: 3D driver claims to not support visual 0x41 (WW) AIGLX: 3D driver claims to not support visual 0x42 (WW) AIGLX: 3D driver claims to not support visual 0x43 (WW) AIGLX: 3D driver claims to not support visual 0x44 (WW) AIGLX: 3D driver claims to not support visual 0x45 (WW) AIGLX: 3D driver claims to not support visual 0x46 (WW) AIGLX: 3D driver claims to not support visual 0x47 (WW) AIGLX: 3D driver claims to not support visual 0x48 (WW) AIGLX: 3D driver claims to not support visual 0x49 (WW) AIGLX: 3D driver claims to not support visual 0x4a (WW) AIGLX: 3D driver claims to not support visual 0x4b (WW) AIGLX: 3D driver claims to not support visual 0x4c (WW) AIGLX: 3D driver claims to not support visual 0x4d (WW) AIGLX: 3D driver claims to not support visual 0x4e (WW) AIGLX: 3D driver claims to not support visual 0x4f (WW) AIGLX: 3D driver claims to not support visual 0x50 (WW) AIGLX: 3D driver claims to not support visual 0x51 (WW) AIGLX: 3D driver claims to not support visual 0x52 (WW) AIGLX: 3D driver claims to not support visual 0x53 (WW) AIGLX: 3D driver claims to not support visual 0x54 (WW) AIGLX: 3D driver claims to not support visual 0x55 (WW) AIGLX: 3D driver claims to not support visual 0x56 (WW) AIGLX: 3D driver claims to not support visual 0x57 (WW) AIGLX: 3D driver claims to not support visual 0x58 (WW) AIGLX: 3D driver claims to not support visual 0x59 (WW) AIGLX: 3D driver claims to not support visual 0x5a (WW) AIGLX: 3D driver claims to not support visual 0x5b (WW) AIGLX: 3D driver claims to not support visual 0x5c (WW) AIGLX: 3D driver claims to not support visual 0x5d (WW) AIGLX: 3D driver claims to not support visual 0x5e (WW) AIGLX: 3D driver claims to not support visual 0x5f (WW) AIGLX: 3D driver claims to not support visual 0x60 (WW) AIGLX: 3D driver claims to not support visual 0x61 (WW) AIGLX: 3D driver claims to not support visual 0x62 (WW) AIGLX: 3D driver claims to not support visual 0x63 (WW) AIGLX: 3D driver claims to not support visual 0x64 (WW) AIGLX: 3D driver claims to not support visual 0x65 (WW) AIGLX: 3D driver claims to not support visual 0x66 (WW) AIGLX: 3D driver claims to not support visual 0x67 (WW) AIGLX: 3D driver claims to not support visual 0x68 (WW) AIGLX: 3D driver claims to not support visual 0x69 (WW) AIGLX: 3D driver claims to not support visual 0x6a (WW) AIGLX: 3D driver claims to not support visual 0x6b (WW) AIGLX: 3D driver claims to not support visual 0x6c (WW) AIGLX: 3D driver claims to not support visual 0x6d (WW) AIGLX: 3D driver claims to not support visual 0x6e (WW) AIGLX: 3D driver claims to not support visual 0x6f (WW) AIGLX: 3D driver claims to not support visual 0x70 (WW) AIGLX: 3D driver claims to not support visual 0x71 (WW) AIGLX: 3D driver claims to not support visual 0x72 (II) AIGLX: Loaded and initialized /usr/lib/dri/fglrx_dri.so (II) GLX: Initialized DRI GL provider for screen 0 (II) fglrx(0): Enable the clock gating! (II) fglrx(0): Restoring recent mode: 1680x1050@60Hz (II) config/hal: Adding input device Logitech USB RECEIVER (II) LoadModule: "evdev" (II) Loading /usr/lib/xorg/modules/input//evdev_drv.so (II) Module evdev: vendor="X.Org Foundation" compiled for 1.5.3, module version = 2.1.2 Module class: X.Org XInput Driver ABI class: X.Org XInput driver, version 2.1 (**) Logitech USB RECEIVER: always reports core events (**) Logitech USB RECEIVER: Device: "/dev/input/event5" (II) Logitech USB RECEIVER: Found 16 mouse buttons (II) Logitech USB RECEIVER: Found x and y relative axes (II) Logitech USB RECEIVER: Configuring as mouse (**) Logitech USB RECEIVER: YAxisMapping: buttons 4 and 5 (**) Logitech USB RECEIVER: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200 (II) XINPUT: Adding extended input device "Logitech USB RECEIVER" (type: MOUSE) (II) config/hal: Adding input device AT Translated Set 2 keyboard (**) AT Translated Set 2 keyboard: always reports core events (**) AT Translated Set 2 keyboard: Device: "/dev/input/event1" (II) AT Translated Set 2 keyboard: Found keys (II) AT Translated Set 2 keyboard: Configuring as keyboard (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD) (**) Option "xkb_rules" "evdev" (**) Option "xkb_model" "evdev" (**) Option "xkb_layout" "us" (II) config/hal: Adding input device Macintosh mouse button emulation (**) Macintosh mouse button emulation: always reports core events (**) Macintosh mouse button emulation: Device: "/dev/input/event0" (II) Macintosh mouse button emulation: Found 3 mouse buttons (II) Macintosh mouse button emulation: Found x and y relative axes (II) Macintosh mouse button emulation: Configuring as mouse (**) Macintosh mouse button emulation: YAxisMapping: buttons 4 and 5 (**) Macintosh mouse button emulation: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200 (II) XINPUT: Adding extended input device "Macintosh mouse button emulation" (type: MOUSE) Får også denne linjen i terminalen hele tiden: Xlib: extension "Generic Event Extension" missing on display ":0.0". Any ideas? Endret 12. februar 2009 av Xecuter Lenke til kommentar
jonnor Skrevet 12. februar 2009 Del Skrevet 12. februar 2009 (endret) X kræsjer hver gang jeg ser video i Arch og jeg går fra å se Grey's Anatomy til å se Scrubs. Dette skjer faktisk hver gang.Totem, har ikke sjekket om problemet er det samme i andre avspillere. Pluss, videoen kommer lenge etter lyden. Any ideas? Jeg har en idè. http://bugs.archlinux.org/ http://bbs.archlinux.org/viewtopic.php?id=46887 Sjekk også om problemet er det samme med andre avspillere/X interface? EDIT: intel forresten? EDIT2: nevermind. Men den feilmeldingen er forresten sannsynligvis ikke relatert. EDIT3: bekreftet http://www.archivesat.com/FreeBSD_current_...read4535333.htm > Xlib: extension "Generic Event Extension" missing on display ":0.0". This is harmless, it indicates that libXext has support for generic events, but the server does not yet. Endret 12. februar 2009 av NorthWave Lenke til kommentar
dizzykeys Skrevet 15. februar 2009 Del Skrevet 15. februar 2009 Kan være et problem med siste ATI-driveren, har sett flere på phoronix forumene klage over frysing ved avspilling av video. Nedgrader til forrige versjon og problemet burde være løst. Lenke til kommentar
