To snodige feilmeldinger etter oppgradering til Servicepack 3
Prøv og se om dette løser problemet.
1.Follow the link to download new drivers. This will take you to D-link support website.
http://support.dlink.com/downloads/
2. Select the model of the d-link hardware
3. Read the Q/A by scrolling down the page and select the one about problem with SP3
4. Select to download new drivers for correct model number. (When you download SAVE to a folder you remember were it is)
5. Once finished downloading, open file and click setup.
Just a quick note, I had to shut down and restart the laptop about 3 times throughout this. When you first press setup, it uninstalls the previous software & drivers. This is when to shut down and reboot. Windows will detect new hardware as it is booting. Just ignore this and go back to were you saved the new drivers and click on setup again. Once complete reboot again and then select the wireless network you wish to connect with.
  • 2 uker senere...
Skal prøve dette nå :)
