CL2 vs. CL2.5
aMo
Jeg hadde tenkt å kjøpe TwinMOS 2x512 mb pc 3200 m/ windond (cl 2,5)
Skal jeg bruke dual cahnnel minne opplegget for å bedre ytelse hva er best å ha da....har hørt at begge (cl2 og cl2,5) funker :-?
Skal ha en kickass pc (Xp3000+, Asus a7n8x Deluxe, radeon 9800 pro, segate 120gb 8 mb cache osv osv) :wink:
hva er forskjellen på CL2.5 og CL2.0 da? Hadde vert fint å vite  :)
Kopi fra http://www.experts-exchange.com
The CL2 stands for clock 2. What that means is that is how fast it gives information to the CPU. Using the spreadsheet example, the CPU ask the RAM for pages 2 - 6. It works on those pages and needs to save them on page 7, so it ask the RAM for page 7. It takes the RAM 2 of the CPU's clock cycles to get this information to the CPU.
As you can see, 2 clock RAM works faster with the CPU than 2.5 clock RAM. (Because the way CPU clocks work, the data might be ready at 2.5 clocks, but the CPU won't get it until the third clock.)
What I meant by "when you get to those speeds the RAM clock makes a lot of difference" is that most of the devices on your computer cannot run at even 266Mhz, so therefore the difference between 366Mhz and 400Mhz really isn't that much, but there is a big difference between 2 clock and 2.5 clock.
What this means to you:
If you are going to be coping LOTS of data between devices, you want the 400Mhz RAM. Coping from Hard Drive to Hard Drive, for example. Burning CD's doesn't really count because the CD burner is much slower than the RAM.
If you will be playing games and/or using video or graphics, getting the data to the CPU is top priority, thus 2 clock RAM would be best.
