Registered RAM?
Motig
ECC - Short for Error-Correcting Code memory, a type of memory that includes special circuitry for testing the accuracy of data as it passes in and out of memory.
Registered Memory - A memory module that contains registers that hold the data for one clock cycle before it is moved on to the motherboard. This process increases the reliability of high-speed data access. Registered memory modules are typically used only in servers and other mission-critical systems where it is extremely important that the data is properly handled.
Jepp, men ecc/reg er laget for bruk i servere du har ikke noe glede/fordel med å bruke en så kostbare rambrikker i din pc.
For å si det på en annen måte, du merker ingen forskjell med eller uten reg/ecc ram på din pc?
Men har du formye peng, så kjøp ecc/reg brikker. Det er bortkastet peng syns nå eg da?
