Winamp 2.91
b-real
Download
fixed an incorrect vis color
fixed shuffle; now, when you start winamp w/shuffle on, it returns you to the song you were at when you exited last time
made winamp not crash if you close it while a file info dialog is open
fixed jump dialogs when using language packs
fixed tooltip in lightning bolt
made video window on autoclose not stop if configured to do so
made in_mp3 have options for adding tags from ml
fixed a bug in in_wm
library: made library refresh properly on add/compact/etc
library: fixed a library win9x view issue
library: fixed shift+enter in media library tree
library: added "Explore item folder" in library's media view
library: made internet radio/tv display msg when reload is blocked
library: added "Physically delete file" in library's media view
dshow: added config dialog (filetypes)
dshow: added option to vertically flip WMV videos (for machines with old WMV codec installed)
dshow: added file info box
dshow: fixed issues with widechars
dshow: fixed bitrates displayed
dshow: added 32 & 64-bit audio support
nsv: fixed title updating (playlist flicker) bug
nsv: made nsv info box show filename and basic info
nsv: made nsv use less cpu on [p]rebuffering
nsv: fixed mp3 decoder's eating of the end of nsv file
nsv: added AAC decoding support
nsv: fixed vis on audioless nsvs
put AOD in all installers (opt-out always)
