[-GoMp-] Skrevet 15. april 2003 Rapporter Del Skrevet 15. april 2003 Hei, det har blitt lagt ut RYKTER om det som visstnok er "de ekte" spekifikasjonene på NV35 - ikke tro på alt du leser :wink: da kan det hende at du blir skuffet! Det gjenstår å vente og se hvordan NV35 blir. Hvis du vil lese hele artikkelen og diskusjonene i forumet, klikker du her: http://www.nvnews.net/vbulletin/showthread...&threadid=10184 Her er spekifikasjonene: CineFX ( TM ) Shading Architecture Support for the Microsoft DirectX® 9.0 Pixel Shader 2.0 Support for the DirectX 9.0 Vertex Shader 2.0 Long pixel programs up to 1,024 instructions Long vertex programs up to 256 static instructions with up to 65,536 instructions executed Dynamic, conditional execution and flow control 256-bit advanced memory interface combines a wider memory data path with next generation controller technology for superior performance and throughput. Full 128-bit, studio-quality floating point precision through the entire rendering pipeline with native hardware support for 32 bpp, 64 bpp and 128 bpp rendering modes Accelerated pixel shaders allow for up to 12 pixel shader operations/clock Up to 16 textures per rendering pass Support for sRGB texture format for gamma textures IntellisampleTM performance technology, a Hi-Res compression technology (HCT), increases performance at higher resolutions through advances in compression and anti-aliasing technology. Shadow Volume Accelerator – accelerates shadow volumes by maintaining them more accurately and discarding useless information. Full nViewTM multi-display technology capability Integrated NTSC/PAL TV encoder supporting resolutions up to 1024x768 without the need for panning with built-in Macrovision copy protection Microsoft® Video Mixing Renderer (VMR) creates support for multiple video windows with full video quality and features in each window DVD and HDTV-ready MPEG-2 decoding up to 1920 × 1080i resolutions Dual, integrated 400 MHz RAMDACs for display resolutions up to and including 2048 × 1536 @ 85 Hz Dual DVO ports for interfacing to external TMDS transmitters and external TV encoders Dual internal TMDS encoders (one single and one Dual link) able to drive next-generation flat panel displays with resolutions greater than 1600 × 1200 Digital Vibrance Control 3.0 0.13 micron process technology for higher levels of integration and higher operating clock speeds 40 mm × 40 mm, BGA 1309 flip-chip package Comprehensive Microsoft DirectX® 9.0 (and lower) and OpenGL 1.4 (and earlier) support DirectX and S3TC texture compression (Jeg bruke Ctrl+C, Ctrl+V - ikke omskrevet ) Lenke til kommentar
MistaPi Skrevet 16. april 2003 Rapporter Del Skrevet 16. april 2003 Ser ikke ut som det blir forbedringer med FSAA, hverken med sample pattern eller gamma corrected AA (ikke at jeg hadde regnet med det). Blir nok et ATI kort i PCen min en stund til. Lenke til kommentar
[-GoMp-] Skrevet 16. april 2003 Forfatter Rapporter Del Skrevet 16. april 2003 Hehe Vi kan jo håpe at de har gjort noe med den, men at de ikke har sagt noe om det...det er jo ikke sikkert at dette er de spesifikasjonene som kommer til å gjelde når NV35 blir lansert...men vi får se... Lenke til kommentar
