CPU 100% og treigt tastatur og pc
Du kan fjerne combofix ved å skrive combofix /u fra kjør-vinduet. Denne kommandoen gjør at filer i karantene og backups blir slette. Systemgjenopprettingsmappa nullstilt etc.
Last ned kjør CCleaner
'Valg'->'Avansert'. Fjern avkryssingen framfor: "bare slett midlertidige filer som er eldere enn 48 t.
Kjør register-renser "svar ja til og reparere" --> backup svar ja når du blir spørt.
Kjør register-renser et par ganger til alle feil er borte.
DPCs bruker mye, sammen med interrupts (5-15)
DCP (Deferred Procedure Calls) og hardware interrupts.
Tyder på at det er noe problemer med hardware.
Prøv ned og uten batteri.
Søke google "acer model(Deferred Procedure Calls)"
hardware interrupts "acer model"
Prøv også uten eller se på innstillinger for power.
O4 - HKLM\..\Run: [epm-dm] c:\acer\Empowering Technology\ePower\epm-dm.exe
We have an Acer Aspire 1640 laptop (1642WLMi). The problem was that the keyboard and trackpad were not working properly. Key strokes would be missed and the trackpad worked intermittently. It had become unusable over the last week or so. Plugging in a USB keyboard / mouse did work just fine - but hardly a practical solution.
Task manager showed a process with the image name "system" using 20 to 50% of the CPU. After some Google searching I downloaded Process Explorer, which showed the CPU was spending its time doing DPCs. So I eventually found your post searching Google for dcps keyboard.
I took out the battery (while powered by the mains adapter) and DPCs activity disappears on Process Explorer and the keyboard and trackpad work perfectly!
After plugging the battery in again the keyboard still works - maybe it was a bad connection? maybe the battery has to be warm? Time will tell.
It turns out the battery life has been lousy over the last year so the laptop has been used plugged in most of the time.
The laptop has been shutting down intermittently too so we'll try with the battery out for a while. If it is OK then maybe the battery is somehow causing the shutdowns and I'll just buy a replacement battery.
Det funket å ta ut batteriet..!
Utrolig irriterendes ettersom jeg har brukt en del timer på å scanne med alt av programmet som fins uten å skjønne en drit da jeg aldri fann noe..! :p
Fikk da bort noen småting, uansett.
Tusen takk for hjelpa! Nå fungerer det helt supert her. :)
