probl m/ Last.fm client installering
proooo
hei - se vedlagt bilde,
har problemer med installering av et miniprogram jeg lasta ned via min konto hos last.fm
den skal integrere med min lokale medieavspiller, men under oppsettet bugger den.
noe jeg kan gjøre?
mvh
Endret av proooo
RESOLUTION:
Set the folder "my documents" to its default values.
Right click on my documents folder in explorer or the desktop > select properties from the menu that appears > Select the option for returning the position to its default value.
C:\Documents and settings > All Users Documents > under properties you will see attributes and the settings for "read only"
Setting back the default value for "My documents" is just a workaround, which usually fixes the default read/write rights for the "My Documents" folder.
