Summen dukker ikke opp?
Jeg laget dette som en liten udvidelse av et eksempel, men hver gang jeg skriver inn de fem tallene i programmet så lukker det seg uten å gi meg summen. Her er koden:
#include <iostream> // allows to perform input and output
#include <Integer.h>
// Function main begins program execution
int main()
{	// Opening brace for function main
int number1; // first integer to add
int number2; // second integer to add
int number3; // third integer to add
int number4; // fourth integer to add which multiplies
int number5; // fifth integer to add which divides
int sum; // the value of the numbers after addision, substraction, multiplieing and dividing
std::cout << "Enter the first integer: "; // Ask user for the first integer
std::cin >> number1; // reads the first integer from user in to number1
std::cout << "Enter the second integer: "; // number2
std::cin >> number2; // number2
std::cout << "Enter the third integer: ";
std::cin >> number3;
std::cout << "Enter the fourth integer: ";
std::cin >> number4;
std::cout << "Enter your fifth integer: ";
std::cin >> number5;
sum = number1 + number2 + number3 * number4 / number5; // adds up the numbers; stores the sum
std::cout << "Sum is " << sum << std::endl; // display sum endline
system ("pause"); // Freezes the program, preventing it from shutting down
return 0; //Indicate that the program ended successfully
} //Closing brace ending function main
Og så står i build
1>c:\users\supersindre\documents\visual studio 2008\projects\integer program\integer program\integer.cpp(3) : fatal error C1083: Cannot open include file: 'Integer.h': No such file or directory
Takker for svar på forhånd.
PS: Hvis noen skal mase om at emnetittelen er lite beskrivende kom med forslag, er tom for ideer.
Endret av Geek_Master
Jeg fant ut av det.
#include <filnavn> står det at: the preprocessor searches for a specified file in an implementation-dependent manner, normally through predesignated directories.
#include "filnavn" står det at: the preprocessor searches first in the same directory as the file is beeing compiled, then in the same implementation-dependent manner as for the files with enclosed brackets.
EDIT: orker ikke oversette
EDIT: Kan noen forklare meg nøyaktig hva en c++ preprocessor, forstår det ikke helt?
Her står det ganske godt forklart:
http://en.wikipedia.org/wiki/C_preprocessor
Håpet på en forklaring på norsk, fant ikke noe på google.
PreProssesore er en prosess for skjer før kompileringen, det blir blandt annet "variabler" fra #define plasert ut... man kan si at alle (det er alle ikke sant?) "funksjoner" som starter med # er ment for preprossesoren.
f. eks.
#include "fil" klasker innholdet til "fil" på linjen #include står.
så kompileres det.
Du som bruker vc kjenner sikkert #pragma (kompilatore setting) once som gjør headeren ikke blir includert flere ganger.
Her er noe jeg har skrevet på CodeWiki Preprosessor(C/C++)
Hvilken include du bruker er spiller her ingen rolle.
Ligger headeren i samme windows mappe som source filen?
Hvis den ikke gjør det så må du legge til mappen ved å gå inn på prosjekt instillinger -> c/c++ -> General -> Additional Include Directories
Lykke til
f. eks.
så kompileres det.
Lykke til
Preprocessor er en prosess utført før kompileringen altså.
Men når jeg bruker "" så lukker den seg ikke mens når jeg bruker <> så lukker programmet seg uten å gi svaret.
Og nei jeg har ikke hørt om #pragma, hva er det forresten?
Takk for svaret Giddion.
Jeg går ut ifra at du mener at
står inne i file Integer.h
Når du bruker #include <FilnavN> så leter preprosessoren kun i noen bestemte include-mapper etter filen FilnavN, og den titter ikke i samme mappe som cpp-filen.
Når du bruker #include "FilnavN" så leter preprosessoren først i mappen cpp-filen er i, så leter den i de samme mappene som den ville sett i om du hadde brukt <FilnavN>.
#include bare setter inn teksten i fila den blir bedt om å lete etter. Så når du bruker #include "Integer.h", så setter den inn teksten #include <iostream> på linja der det sto #include "Integer.h". Deretter bytter den ut linja #include <iostream> med innholdet i iostream, som ligger i preprosessorens include-mapper.
Om jeg ikke inkluderer iostream (enten ved include <iostream> eller include "Integer.h" med include <iostream> i) så nekter programmet mitt å kompileres. Det er ikke en gammel versjon av programmet der du ikke hadde med utksrift av sum som kommer når kompilatoeren ikke finner iostream?
Du deler foresten på number5 i stedet for å legge det til.
Jeg vet det, det var egentlig poenget å prøvenoe som ikke var brukt i noen eksempler.
Takk for alle svarene.
