drall Skrevet 25. april 2003 Del Skrevet 25. april 2003 Og Selvfølgelig: man <program eller confg-fil> #Gir en detaljert bruksmanual som forklarer hvordan man bruker programmet eller hvordan man redigerer config-fila eks: man X Kan vere et fint tips å bruke konqueror til å se man sider om du bruker KDE. man:<program/fil> f.eks. man:mount i adressefeltet. Det kan også vere fint å legge inn midnight commander (kommando mc) for filbehandling i terminal. Sikkert lettere for nybegynnere. Lenke til kommentar
Klette Skrevet 29. april 2003 Del Skrevet 29. april 2003 Ett eksempel på en "Clean" XFree86Config ######################/############# # XFree86 Config # --av Klette-- # # Testet på: # Redhat9 # # # Specs: # Geforce4 Ti4400 # Acer 712 ( lcd/tft ) # DVi tilkoblet # Nyeste Nvidia driverne # ###########################29/4-2003# ############### # Server Section "ServerLayout" Identifier "Default Layout" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection ######## #Files Section "Files" RgbPath "/usr/X11R6/lib/X11/rgb" FontPath "unix/:7100" EndSection ######## #Modules Section "Module" Load "dbe" Load "extmod" Load "fbdevhw" Load "glx" Load "record" Load "freetype" Load "type1" EndSection ######### #Keyboard Section "InputDevice" Identifier "Keyboard0" Driver "keyboard" Option "XkbRules" "xfree86" Option "XkbModel" "pc105" Option "XkbLayout" "no" EndSection ########## #Mouse Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "IMPS/2" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "no" EndSection Section "InputDevice" Identifier "DevInputMice" Driver "mouse" Option "Protocol" "IMPS/2" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "no" EndSection ############ #Monitor Section "Monitor" Identifier "Monitor0" VendorName "Monitor Vendor" ModelName "DDCPROBED" DisplaySize 340 270 HorizSync 24.0 - 80.0 VertRefresh 56.0 - 75.0 Option "dpms" EndSection ############## #Gfx Card Section "Device" Identifier "Videocard0" Driver "nvidia" VendorName "Videocard vendor" BoardName "NVIDIA GeForce 4 (generic)" Option "ConnectedMonitor" "DFP" EndSection ##################### # GfxCard vs Monitor Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Depth 24 Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480" EndSubSection EndSection ############## # DRI ( sux ) Section "DRI" Group 0 Mode 0666 EndSection Si ifra om feil e.l Lenke til kommentar
GNUfan Skrevet 29. april 2003 Del Skrevet 29. april 2003 Konfigfila til Klette forutsetter at du bruker XFS (X Font Server), har en Microsoft/Locitech mus som er litt over 2 knapper+PS/2 standard. Du får 1280x1024 som standard oppløsning, men du kan med ett enkelt tastetrykk (<ctrl><alt><+> eller <->) skifte den mellom 1280x1024, 1280x960, 1152x864, 1024x768, 800x600 og 640x480. For å skifte dette, bytter du ut tallene som står under Modes under "Section Screen" Har du en vanlig mus, så bruker du dette: # Standard mus Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "PS/2" Option "Device" "/dev/psaux" Option "Emulate3Buttons" Sett inn dette istedet for det som står i Klette sin fil under Mouse, og slett det andre som står under Mouse-delen. For å få et grunnlag til en XF86Config, så går du til konsoll ( <ctrl><alt><F1>), logger inn som root, og skriver xf86config, og følger instruksjonene på skjermen. Lenke til kommentar
panzerwolf Skrevet 29. april 2003 Del Skrevet 29. april 2003 wow... svært bra samling, folkens! Mitt prosjekt bruke-microsoft-minst-mulig kan nå snart passere en ny terskel!! Takk fra denne Ulven!!! Lenke til kommentar
MarcelSB Skrevet 29. april 2003 Del Skrevet 29. april 2003 Foreslår at moderator samler sammen alle de forskjellige guidene og svarene i en generell FAQ som brukerne ikke kan røre. Så kan vi heller bruke denne som FAQ-devel. Det blir litt for mye rot med en FAQ der alle kan poste. Passer bedre med en ordentlig strukturert og oversiktelig FAQ, som blir satt opp og vedlikeholdt av moderatorer... MarcelSB Lenke til kommentar
GNUfan Skrevet 29. april 2003 Del Skrevet 29. april 2003 Foreslår at moderator samler sammen alle de forskjellige guidene og svarene i en generell FAQ som brukerne ikke kan røre. Så kan vi heller bruke denne som FAQ-devel. Det blir litt for mye rot med en FAQ der alle kan poste. Passer bedre med en ordentlig strukturert og oversiktelig FAQ, som blir satt opp og vedlikeholdt av moderatorer... MarcelSB Enig. Og sorry for eventuelle feil jeg skreiv ovenfor... Lenke til kommentar
MarcelSB Skrevet 29. april 2003 Del Skrevet 29. april 2003 Noen moderatorer som melder seg? MarcelSB Lenke til kommentar
abcd423417984 Skrevet 29. april 2003 Del Skrevet 29. april 2003 det går evt ann å stenge posten så ingen andre enn moderatører kan poste...men da er vel litt av vitsen borte da dere ikke lenger kan skrive FAQ's, noe vi moderatører antagligvis ikke orker sitte igjen med å gjøre alene. Lenke til kommentar
Egil.B Skrevet 29. april 2003 Del Skrevet 29. april 2003 http://www.hardware.no/linux/ må jo være et velegnet sted Lenke til kommentar
MarcelSB Skrevet 29. april 2003 Del Skrevet 29. april 2003 Poenget er at denne tråden kan være oppe en god stund som FAQ development tråd. Det er sikkert en av oss i linuxforumkjernen som hadde tatt på seg FAQ jobben hvis han ble moderator. Hva med DummeGaas? MarcelSB Lenke til kommentar
iv3rs Skrevet 30. april 2003 Del Skrevet 30. april 2003 Løsningen på alle problemer: GOOGLE Lenke til kommentar
MarcelSB Skrevet 2. mai 2003 Del Skrevet 2. mai 2003 Ingen som stemmer for forslaget mitt? MarcelSB Lenke til kommentar
bergetun Skrevet 3. mai 2003 Del Skrevet 3. mai 2003 Ingen som stemmer for forslaget mitt? MarcelSB Uansett saa boer du ikke ta dette opp i selve FAQ traaden.. Vet jeg gjoer det selv naa men de saa ikke ut som det hjalp aa poste traaden "Forslag til endring i FAQ traaden" Lenke til kommentar
xeon Skrevet 4. mai 2003 Del Skrevet 4. mai 2003 APT på RedHat Et av de store problemene man opplever med rpm (pakkesystemet til Red Hat) er dependencies. Dette betyr i all enkelhet at et program X krever at program/library Y skal være installert for at programmet skal fungere korrekt. Program Y er ikke alltid like lett å finne. APT4RPM løser dette enkelt. Gå til http://freshrpms.net/ og last ned apt til din distribusjon ( 8.0 eller 9.0 ). Følgende forutsetter at du er root - Installer så apt med kommandoen 'rpm -ivh --nodeps --force apt-*.rpm' - Kjør 'apt-get update && apt-get dist-upgrade' i kommando linja - Vil du ha GUI til apt, så kjør 'apt-get install synaptic' (programnavnet er 'synaptic' og kan enten startes vi kommando linja eller Alt+F2) - Skal du ha installlere et program; kjør apt-get install <pakkenavn> - For å søke etter en pakke; kjør apt-cache search <søke string> Anbefalte pakker: xmms-mp3, mplayer, mplayer-gui, xine Installering av RedHat via ftp: Dette er tatt mer eller mindre ut fra hodet, så om alt er riktig er jeg ikke helt sikker på. Send en PM hvis du har prøvd det. For å installere RedHat via ftp i stedet for å laste ned alle 3 cd'ene, som er påkrevd dersom du velger cd-installasjon, kan du installere RedHat via ftp. Du vil ikke få grafisk installasjon av RedHat når du bruker ftp, men det er fremdeles lett forståelig. Du har da to valg: - Du kan laste ned en liten iso på 4-5 MB og brenne denne ut på nero med ditt favoritt brenneprogram - Dersom du ikke har brenner eller mulighet noen mulighet kan du bruke disketter. De imagene du trenger finer du her. Du må da høyst sannsynlig ha disse filene: bootdisk.img og drvnet.img Har du pcmcia nettverkskort trenger du det imaget også.. For å få de på diskett trenger du innholdet i denne mappen. (mer spesifikt dll og exe filen) Deretter booter du enten diskettene eller cd'en. Bruker du disketter så si ja til eventuelle spørsmål om å legge inn drivere fra diskett. Så velger du ftp-installasjon og dytter inn fornuftige verdier i nettverkskonfigureringen. Deretter dytter du inn denne banen når du får spørsmål om hvor du vil installere fra (dersom det er der du vil installere fra, det kan selfølgelig også gjøres fra en lokal server): ftp://ftp.uninett.no/linux/RedHat/redhat/9/en/os/i386/ NTFS til RedHat Grunnen til at du ikke får lest noe fra ntfs-partisjonene dine er at RH ikke har inkludert støtte for det grunnet at NTFS er proprietært, men det er som alt annet i linux enkelt å fikse. Gå til Linux NTFS RedHat, hvor installasjonen står utførlig forklart. I sin enkelhet. last ned rpm pakken til din kernel og installer den med rpm -ivh <pakkenavn> Les også mounting av ntfs partisjoner Lenke til kommentar
LordErr Skrevet 8. mai 2003 Del Skrevet 8. mai 2003 Heisann. Her er min freevo & nvidia tv-ut howto. Hvis dere skulle finne noen feil i denne howto'en så gjerne si i fra. Den er forøverig kun testet på slackware 9.0 edit: det var vist noen tabs ol. som ikke ble riktig her. dokumentet i sin helhet kan lastes ned på: http://www.intel-nerd.net/howto/freevo_nvi...ut_howto-no.txt ----- Freevo & Nvidia tv-out howto (Norsk) Copyright © 2003 Lasse A. Palm Denne dokumenasjonen er lisensiert under GNU GPL License http://www.gnu.org/licenses/gpl.txt Følgende howto vil veilede deg gjennom en enkel installasjon av tv-ut på nvidia baserte kort og installasjon og konfigurering av freevo. Plattformen for denne howto'en er ia32 (i386) Freevo URL: www.freevo.org | freevo.sourceforge.net Jeg tar på ingen som helst måte ansvar på hva følgene av denne dokumentasjon gjør med din maskin. Alt gjøres på eget ansvar. Denne howto'en dekker kun konfigurasjon for vising av filmer og musikk. Ønsker du å benytte deg av TV og opptaks funksjonen, les dokumentasjonen på www.freevo.org. Innhold: 1 - Nedlasting av de nødvendige komponentene 1.1 - Nedlasting av freevo 1.2 - Nedlasting av Nvidia drivere 2 - Konfigurasjon og installasjon 2.1 - Installasjon av nvidia drivere 2.2 - Konfigurasjon av XFree86 2.3 - Installasjon av Freevo 2.4 - Konfigurasjon av Freevo 2.5 - Oppsett av xinitrc.freevo 2.6 - Tv-out bash script 3 - Nyttige linker 1. - Nedlasting av de nødvendige komponentere Vi er nødt til å laste ned noen komponenter for av vi skal få freevo og nvidia tv-ut til å fungere. Jeg tar i utgangspunkt at du ikke har noen av disse komponentene installert fra før. 1.1 - Nedlasting av freevo For at vi skal gjøre dette lettest mulig bruker vi en ferdig komplimert versjon av freevo. Dette er for at vi skal slippe å laste ned alle de tilhørende komponentene som mplayer etc. last ned freevo binary static http://switch.dl.sourceforge.net/sourcefor...-1.3.2-pre4.tgz 1.2 - Nedlasting av Nvidia drivere Nedlasting av de nyeste nvidia driverene er nødvendig. Dette er fordi at på noen av de eldre driverene er ikke overscan støttet på alle kort. Husk å last ned driver versjon lik eller høyere enn 1.0-4363. Følg instruskjonene for nedlasting på Nvidia sin side. XXXX er ment som versjons nummeret. Filen vil antagligvis hete: NVIDIA-Linux-x86-1.0-XXXX.run Notat: Nvidia drivere under 1.0-1251 støtter ikke tv-ut last ned nyeste nvidia drivere http://www.nvidia.com/view.asp?IO=linux 2 - Konfigurasjon og installasjon Jepp, du gjettet riktig. Vi må nok også gjøre litt konfigurasjon for at komponentene skal fungere sammen. Vi skal sette opp XFree86 slik at vi kan bruke tv-ut sammen med freevo. 2.1 - Installasjon av Nvidia drivere Som sagt så må vi installere nye nvidia drivere. Dette er for at da er det størst mulighet for at ditt skjermkort er støttet fult ut. OBS! Nvidia sine drivere krever XFree86 4.0.1 eller høyere. Avslutt XFree86. Dette kan gjøres på mange måter. Det beste er å bruke logout funksjonen i din Window Manager/Desktop Environment. Hvis dette av en eller annen grunn ikke skulle gå. Dette kan oppstå om du bruker GDM eller lingende. Ta da å start en form for terminal emulator (xterm, aterm, konsole, gnome trem). I terminalen skriver du: $ init 3 Du vil da komme ut i konsolet. Her må du lokalisere den de nedlastede nvidia driverne og kjøre denne som root. $ cd /der/hvor/jeg/har/lagt/driveren $ su # sh NVIDIA-Linux-x86-1.0-XXXX.run Følg der etter instruksjonene på skjermen. Når installasjonen er ferdig må vi redigere konfigurasjons filen til XFree86. Filen heter enten XF86Config-4 eller XF86Config og ligger i katalogen /etc/X11. Bruk din favoritt editor for å redigere denne (pico, nano, vi, vim ol.) # pico /etc/X11/XF86Config-4 Under Device seksjonen finn og erstatt: Driver "nv" (eller Driver "vesa") med Driver "nvidia" I Module seksjonen sørg for at du har: Load "glx" Du må også fjerne disse linjene: Load "dri" Load "GLcore" Etter dette, lagrer du filen og avslutter progammet. Når vi er ferdige starter vi opp XFree86 igjen for å brekrefte at nvidia driverene ble installert riktig. Du vil da se Nvidia logoen på starten. Dette gjør vi som en vanlig bruker. # exit $ startx Hvis du ser nvidia logoen på oppstarten er installasjonen av nvidia driverene en sukess. Skulle du ha problemer med å installere Nvidia sine drivere, se på nvidia sine sider eller på deres forum http://www.nvidia.com http://www.nvnews.net/vbulletin/forumdispl...p?s=&forumid=14 2.2 - Konfigurasjon av XFree86 For at vi skal få konfigurert XFree86 med tv-ut må vi redigere /etc/X11/XF86Config-4 filen ytligere. Vi skal nå legge inn støtte for tv og sette riktig tv format. Du må igjen åpne /etc/X11/XF86Config-4 filen for redigering. Husk at du må gjøre dette som root. Dette er fordi vanlige brukere har ikke skrive tilgang til denne filen. Start opp en terminal emulator (xterm, aterm, konsole, gnome term ol.) $ su # pico /etc/X11/XF86Config-4 Først må vi gå til Device seksjonen og finne den delen hvor du har Driver "nvidia" I den samme seksjonen står det Identifier "xxxxx" Noter ned hva verdien til identifier er. Vi trenger den senere. Gå til Monitor seksjonenen og legg til dette. Section "Monitor" Identifier "TV" HorizSync 30-50 VertRefresh 60 EndSection Der har jeg skrevet Device "xxxxx" bytt ut xxxxx med verdien til identifier, som vi fant tidligere. Gå deretter til Screens seksjonen og legg dette til for støtte for 640x480: Section "Screen" Identifier "Screen_tvout640" Device "xxxxx" Monitor "TV" DefaultDepth 24 Option "TVStandard" "PAL-B" Option "ConnectedMonitor" "TV" Subsection "Display" Depth 24 Modes "640x480" ViewPort 0 0 EndSubsection EndSection Der har jeg skrevet Device "xxxxx" bytt ut xxxxx med verdien til identifier, som vi fant tidligere. Gå deretter til Screens seksjonen og legg dette til for støtte for 800x600: Section "Screen" Identifier "Screen_tvout800" Device "xxxxx" Monitor "TV" DefaultDepth 24 Option "TVStandard" "PAL-B" Option "ConnectedMonitor" "TV" Subsection "Display" Depth 24 Modes "800x600" ViewPort 0 0 EndSubsection EndSection Hvis dere ønsker å bruke composite utgangen i steden for svideo, legg til dette over Option "TVStandard" "Pal B". Dette må gjøres på begge seksjonene som vi la til. Option "TVOutFormat" "COMPOSITE" Hvis dere har brukt for overscan. Dvs. hvis dere får en svart kant rundt bildet på tv-ut. Så kan dette også rettes på. legg dette inn under Option "ConnectedMonitor" "TV". Option "TVOverScan" "0.7" Verdien til TVOverScan kan være alt fra "0.0" (ikke bruk overscan) til "1.0" (full overscan). Dette er noe som dere nesten må prøve dere frem på. "0.7" Passet best for min TV. Nå kan du lagre filen og avslutte programmet og gå ut som vanlig bruker # exit 2.3 - Installasjon av Freevo Det første du trenger å gjøre er å starte en terminal emulator og gå til mappen hvor du lagret freevo. $ cd /der/du/lastet/ned/freevo Pakk deretter ut med: $ tar -zxvf freevo-1.3.2-pre4.tgz Gå inn i mappen. $ cd freevo-1.3.2-pre4 Kjør "freevo setup" og bytt bruker til root for å kjøre "make install" $ ./freevo setup $ su # make install Vi er da ferdige med installasjon av freevo 2.4 - Konfigurasjon av freevo Siden vi forsatt er brukeren root, går vi til mappen /usr/local/freevo $ cd /usr/local/freevo vi må nå redigere to konfigurasjon filer. Detter freevo.conf og freevo_config.py. Bruk gjerne din favoritt editor til dette, men husk at dette må gjøres som root. $ pico freevo.conf finn linjen som er: tv = ntsc og rediger denne til tv = pal Det er alt som trengs å gjøres i denne filen. Hvis du ønsker å bruke din egen versjon av mplayer. Rediger den aktuelle verdien til din versjon av mplayer Du kan nå lagre og avslutte editoren din. Vi må også redigere freevo_config.py. Dette er for å få filmene som du har til a vises i freevo. Igjen bruk din favoritt editor. $ pico freevo_config.py Lokaliser Freevo movie settings. Finn verdien DIR_MOVIES og rediger denne. Her er et forslag til hvordan den kan se ut. DIR_MOVIES = [ ('Ferie', '/usr/share/film/ferie') ] Hvis du ønsker å benytte deg av bilder av dvd covere ol. så kan du definere mappen til disse under MOVIE_DATA_DIR og COVER_DIR. Les freevo dokumentasjonen for å finne ut hvordan du setter opp disse. Hvis du ønsker å bruke freevo til å spille av musikk så kan du det. Finn verdien DIR_AUDIO. Rediger den deretter til ditt oppsett. Her er et forslag til hvordan den kan se ut. DIR_AUDIO = [ ('Min Musikk', '/usr/share/musikk') ] Bilde funksjonen i freevo er også nyttig. Her kan du se på dine ferie bilder på TVen. Finn verdien DIR_IMAGES. Forslag til hvordan den kan se ut. DIR_IMAGES = [ ('Ferie bilder', '/usr/share/bilder/ferie') ] Du kan også endre hva slags bilder som vises. Standard verdi er bare satt til jpg. Finn verdien SUFFIX_IMAGE_FILES og rediger den etter ditt ønske. Her er et forslag til hvordan den kan se ut. SUFFIX_IMAGE_FILES = [ 'jpg', 'gif' ] Hvis du trenger å redigere dine lyd instillinger for mplayer, så kan dette gjøres ved å endre endre verdien MPLAYER_AO_DEV. Les freevo dokumentasjonen for freevo og mplayer for endring av dette. Bruker du OSS kan du la denne stå som den er. Neste skritt er å redigere mplayer instillingene. Finn Mplayer sections og rediger denne verdien: MPLAYER_USE_WID = 1 til MPLAYER_USE_WID = 0 Denne redigering gjør slik at dine video klipp blir sentrert på skjermen. Hvis du lar denne så som verdi 1 kan du oppleve at dine video klipp blir plassert øverst på skjermen. Du kan nå lagre og avslutte. Skulle dere ønske å fjerne noen av meny valgene på hoved menyen kan dette gjøres lett. Lokaliser Plugins. Hvis dere for eksempel ikke ønsker tv under menyen kan denne fjernes ved å plassere # foran den aktuelle menyen. Her er et forslag. # Items in the main menu. # plugin_tv = plugin.activate('tv', level=10) plugin_video = plugin.activate('mediamenu', level=20, args=('video', )) plugin_audio = plugin.activate('mediamenu', level=30, args=('audio', )) plugin_image = plugin.activate('mediamenu', level=40, args=('image', )) plugin_shutdown = plugin.activate('base.shutdown', level=50) 2.5 Oppsett av xinitrc.freevo Når jeg skulle lage denne filen valge jeg å lage den i mappen /etc/tvout. Du må ikke dette, men det valget føltes mest naturlig for meg. Siden du forsatt er logget inn som root, kan vi nå lage denne filen. # mkdir /etc/tvout # pico /etc/tvout/xinitrc.freevo Denne filen skal inneholde følgende: exec /usr/local/freevo/freevo Etter dette kan du avslutte og lagre filen 2.6 - Tv-out bash script Jeg valgte å lage dette skriptet i /usr/local/bin. Dette var fordi at alle brukere skulle få tilgang til tv-ut skriptet. Bruk en editor og lag filen /usr/bin/tv-ut. Husk at du må være root brukeren. $ pico tv-ut Det denne filen skal inneholde er følgende. startx /etc/tvout/xinitrc.freevo -- :1 -bpp 24 -screen Screen_tvout800 dette skriptet vil da starte opp en X server til på din tv og automatisk starte freevo. God fornøyelse og lykke til. 3. Nyttige Linker Freevo - http://www.freevo.org Mplayer - http://www.mplayerhq.org Fjernkontroll - http://www.lirc.org Video Capture driver - http://bytesex.org/bttv/ MAME - http://www.mame.net Zsnes - http://www.zsnes.com Lenke til kommentar
bergetun Skrevet 14. mai 2003 Del Skrevet 14. mai 2003 Hvordan installere en Thumbdrive / USB drive / Flash Drive / USB flash i RH 9 og andre systemer. 1 : Skriv modprobe usb-storage som root 2 : Aapne ett konsoll vindu som root og skrive tail -f /var/log/messages 3 : Insert USB driven i en usb port 4 : Sjekk konsollvinduet du aapnet paa punkt 2 og se sjekk hvilken "dev addresse" usb driven din fikk mest sannsynlig sda1. 5 : Legg denne linja til i /etc/fstab : /dev/sda1 /mnt/usbdrive auto user,noauto 0 0 6 : Lag en katalog i /mnt/ hvor du vil mounte usb driven din. feks mkdir /mnt/usbdrive 7 : Skriv mount /mnt/usbdrive for aa mounte din USB., Lenke til kommentar
Yamato47 Skrevet 18. mai 2003 Del Skrevet 18. mai 2003 OpenBSD har to veldig gode man-sider for nybegynnere: help(1) , og afterboot(8) Help(1) går gjennom mange helt elementære elementer og kommandoer. Det aller meste her gjelder for alle unix-kloner, inkludert Linux. Lenke til kommentar
sete Skrevet 22. mai 2003 Del Skrevet 22. mai 2003 Meget bra link for nybegynnere Lenke til kommentar
PaiNKillaH Skrevet 22. mai 2003 Del Skrevet 22. mai 2003 " sikkert noen som syns dette er Off Topic , men jeg tar sjangsen " Noen som har lyst til å skrive noe om dette: ? Etter installasjon av linux / *bsd Så er det sikkert noen her som lurer på dette: Jeg vil hoste min egen hjemmeside plass, hvordan får jeg Apache til å fungere, og hva må jeg gjøre ? Jeg har lyst til å bruke PHP , men skjønner ikke Mysql / php bruken Jeg har fast ip, noe spess jeg må gjøre for å få pekt mitt domene på denne IPen og hva må jeg gjøre i linux boxen får å få det til å fungere ut på nettet ? Jeg er litt på irc, hva skal jeg gjøre for å bruke mitt domene på irc eller eventuelt en ipv6 ? Ble kanskje litt mye " jeg " form her, men er trøtt etter lange dager med pes Håper det er noen som ser på disse spørsmålene da På forhånd takk Lenke til kommentar
