Hvordan sikkre privat data mot Hackere og annet Avskum bedre
Gjest Slettet+513
Gjest Slettet+513
Hei :new_woot:
Har du informasjon som du vil beskytte best mulig?
Fant ett programm på nettet som gjør nettopp dette, Advanced Encryption Package 2009.
Programmet har RSA støtte som blir brukt i flere sikre banker og 512,768,1024,2048 bits krypteringer..Det viste seg at programmet også har ganske mange andre proffe løsninger.
Ingen hackere klarer 2048 bits kryptering sies det og 1024 bit blir ofte brukt i mange banker.
utdrag fra nettsiden:
New in version 4!
RSA algorithm support. Now it is possible to encrypt files using public key file and decrypt files using private key file.
Added PKI keys Manager and Generator. It supports keys: 512, 768, 1024 and 2048 bits.
Improved command line tool.
New in version 4.2.0!
Added new file wiping algorithm! Now AEP2009 Pro can securely delete your files using 17 wiping algorithms, including U.S. DoD 5200.28, NATO Data Destruction Standard, U.S. Air Force Standard, U.S. Army Standard, Russian GOST P50739-95 Data Destruction Standard and others!
Advanced Encryption Package 2009 Professional destructs files not only at FAT16 and FAT32 formatted hard drives and other media, but it includes special algorithms for NTFS formatted hard drives, it recognized and destructs NTFS compressed and encrypted files. It cleans files sector by sector and cleans unused space in file clusters. Just try it now! You can download and try this software for free during 31 days period.
New in version 4.4.0!
Added support for USB Flash Drives! Now it is possible to store all your encryption passwords on USB Flash Drive. You just need to remember single Master Password. All other encryption keys will be stored on flash memory in an encrypted form (AES 256 bit encryption is used). Now is is possible to randomly generate big binary encryption keys and store them in your pocket.
Negative med dette er at tingen koster penger men det finnes en gratis prøveversjon heldigvis på samme side.
Link til Advanced File Encryption Software Hjemmeside
Om noen av dere vet om ett helt gratis alternativ si gjerne ifra.
Endret av Slettet+513
