Lage en snarvei med developer?
Eksempel
Hei.
Jeg har planer om å cheate på Max Payne 2, og da får jeg beskjed om å gjøre dette:
Make a shortcut to maxpayne2.exe, right click on it and select ''Properties.'' Where it says ''Target:'' you will see the location of your maxpayne2.exe file. Change this text so that it reads ''C:\Program Files\Rockstar Games\Max Payne 2\MaxPayne2.exe'' -developer. Make sure that the ''-developer'' part is on the outside of the quotation marks. Start the game with this shortcut, and then press the ''~'' key while in-game to bring up the console. From there, enter one or more of the following commands:
Jeg tror jeg har fått til dette.
Men når jeg trykker "Play", så kommer det opp: Exception in engineInit:Unable to load save game "Files\Rockstar". File does not exist or it is not a valid savegame file.
Hva kan være feil?
