Backup Av Kontaktene
ken8
Hei.
Har en Nokia 5310 og bruker Nokia PC Suite for å synkronisere osv og det fungerer bra. Men jeg skulle gjerne fått tatt backup av kontaktene mine slik at hvis jeg mister telefonen så beholder jeg alt av nr. Når man tar backup i PC Suite så må man legge .nbu fila tilbake på en telefon. Er det mulig å ta backup på en annen måte evt lese .nbu fila på en annen måte slik at jeg kan få opp navn og tlfnr. i feks Notepad eller excel eller et annet program?
Takker for alle svar.
Fra PCSuite
Exporting contacts to a text file
You can export contact data in the following file formats:
comma-separated values (.csv)
plain text (.txt)
electronic business card vCard (.vcf).
When working with a .csv file, define the used list separator in the Regional and Language Options dialog box in Windows Control Panel.
To export contacts, do the following:
In the Contacts view, select one or more contacts.
Select File > Export.
From the Save as Type field, select the file format to use.
Option
Description
.csv
A contact's information is listed on one line, with values differentiated by a separator, such as a comma. Select this file format if you want to transfer the export file into an Excel spreadsheet or into a database.
.txt
Each value is on a separate line. The field names and values are separated by a tab.
.vcf
A contact's information is exported as an electronic business card. If you select only one contact, this format is used automatically. Select this file format if you want to include thumbnail images in the export file.
In the dialog box, select the target folder for exporting and give the file a name, if needed.
Click Save.
The export file is created in the target folder.
Tip:
You can also drag contact information to other applications or into your PC's file system. In this case, the contact file is automatically created in the vCard format and named according to the contact's full name.
Emnetittelen i denne tråden er lite beskrivende for trådens innhold og det er derfor ingen god emnetittel. Jo bedre og mer beskrivende emnetittelen er, jo lettere er det for andre å skjønne trådens innhold og det vil være lettere å treffe den riktige forumbrukeren med det rette svaret. Ber deg derfor om å endre emnetittel. Vennligst forsøk å ha dette i tankene neste gang du starter en tråd, og orienter deg om hva vår nettikette sier om dårlig bruk av emnetitler.
Husk at en god emnetittel skal beskrive eller oppsummere hvilket problem du har - ikke at du har et problem. En god emnetittel skal heller ikke kun bestå av et produktnavn.
Bruk p_edit.gif-knappen i første post for å endre emnetittelen.
(Dette innlegget vil bli fjernet ved endring av emnetittel. Ikke kommenter dette innlegget, men p_report.gif gjerne dette innlegget når tittelen er endret, så vil det bli fjernet..)
