xbmc problemer i Ubuntu 8.10.
Xbmc vil ikke starte skikkelig, kommer ikke lengre enn 3-4 i loading..
Får så følgende feil i terminal:
marius@marius-desktop:~$ xbmc
Fatal error encountered, aborting
Error log at /var/tmp/marius-xbmc.log
Aborted (core dumped)
Går inn i loggen og finner dette: (nederste del av loggen)
15:39:25 T:3052754752 M: 6725632 INFO: GL: Maximum texture width: 4096
15:39:25 T:3052754752 M: 6725632 INFO: load language info file: /usr/share/xbmc/language/English/langinfo.xml
15:39:25 T:3052754752 M: 6725632 DEBUG: SECTION:LoadDLL(Q:\system\ImageLib-i486-linux.so)
15:39:25 T:3052754752 M: 6725632 DEBUG: Loading: /usr/share/xbmc/system/ImageLib-i486-linux.so
15:39:25 T:3052754752 M: 6725632 WARNING: CreateFile, successfuly opened </usr/share/xbmc/media/Splash.png> instead of </usr/share/xbmc/media/splash.png>
15:39:25 T:3052754752 M: 6230016 DEBUG: PICTURE: loaded image and created texture. height: 401, width: 721
15:39:25 T:3052754752 M: 6823936 DEBUG: Load /usr/share/xbmc/media/splash.png: 92.4ms
15:39:25 T:3052754752 M: 7843840 INFO: load language file:/usr/share/xbmc/language/English/strings.xml
15:39:25 T:3052754752 M: 7471104 INFO: load keymapping
15:39:25 T:3052754752 M: 7471104 INFO: Loading /usr/share/xbmc/system/Keymap.xml
15:39:25 T:3052754752 M: 7471104 DEBUG: CButtonTranslator::Load - no userdata keymap found, skipping
15:39:25 T:3052754752 M: 7471104 INFO: Loading /usr/share/xbmc/system/Lircmap.xml
15:39:25 T:3052754752 M: 7471104 INFO: Loading /home/marius/.xbmc/userdata/Lircmap.xml
15:39:25 T:3052754752 M: 7471104 INFO: Checking skin version of: PM3.HD
15:39:25 T:3052754752 M: 7471104 INFO: The above skin isn't suitable - checking the version of the default: PM3.HD
15:39:25 T:3052754752 M: 7471104 WARNING: Emergency recovery console starting...
Noen som kan si meg hvorfor xbmc ikke starter ?
:w00t:
Se denne posten. Han nevner noe om at hvis du ikke vil ha skins skal du utføre den kommandoen. Prøvd det? Hvis ikke, prøv :) og rapporter hvordan det gikk ;)
Edit: Ooops, leste feil fordi han skrev feil. Glem det jeg sa.
Edit2: Eller, du kan jo prøve å installere nye skins, da, og se hvordan det funker.
Endret av Filthpig
