Gjøre endringer i menu.lst
Jeg er veldig ny på området og vil nødig gjøre noen feil (vil at XP skal være standard OS for oppstart):
## ## End Default Options ##
title Ubuntu 8.10, kernel 2.6.27-7-generic
uuid 8665f20f-b2f1-475c-a322-81dbc75deff4
kernel /boot/vmlinuz-2.6.27-7-generic root=UUID=8665f20f-b2f1-475c-a322-81dbc75deff4 ro quiet splash
initrd /boot/initrd.img-2.6.27-7-generic
quiet
title Ubuntu 8.10, kernel 2.6.27-7-generic (recovery mode)
kernel /boot/vmlinuz-2.6.27-7-generic root=UUID=8665f20f-b2f1-475c-a322-81dbc75deff4 ro single
title Ubuntu 8.10, memtest86+
kernel /boot/memtest86+.bin
quiet
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title Other operating systems:
root
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/sda1
title Microsoft Windows XP Professional
root (hd0,0)
savedefault
makeactive
chainloader +1
Hva må jeg endre?
Det letteste er: alt + F2, skriv gksu gedit /boot/grub/menu.lst og endre default fra 0 til 3.
Sjekk helt øverst i teksten:
# menu.lst - See: grub(8), info grub, update-grub(8)
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not use 'savedefault' or your
# array will desync and will not let you boot your system.
default 0 endre denne til 3
atlef.
