OyvindN Skrevet 8. januar 2009 Del Skrevet 8. januar 2009 Skal hente ut alle titler med liten bokstav og en stor bokstav rett ved siden av hverandre. Har prøvd noe alá dette: SELECT title FROM item WHERE title REGEXP '[a-z][A-Z]' Funker dårlig, noen som har bedre forslag? Lenke til kommentar
Ekko Skrevet 8. januar 2009 Del Skrevet 8. januar 2009 (endret) Prøv SELECT title FROM item WHERE title REGEXP '.*[a-z][A-Z].*' EDIT:Forresten, så denne: http://dev.mysql.com/doc/refman/5.1/en/regexp.html REGEXP is not case sensitive, except when used with binary strings. Edit2: Les også dette: This sql statements: SELECT 'WORD' REGEXP '[[:upper:]]{4}'; # => 1; SELECT 'WORD' REGEXP '[[:lower:]]{4}'; # => 0 work right only when collate is _cs and NOT _ci (case insensitive) created tables eg. the collate 'latin1_swedish_ci' have to be changed, if you want to use case sensitive REGEXPs like [[:upper:]] or [[:lower:]]! ALTER TABLE <name> CONVERT TO CHARACTER SET latin1 COLLATE latin_general_cs I set in my.cnf now: [mysqld] default-collation= latin1_general_cs #default was latin1_swedish_ci Posted by Koy Kragh on March 4 2006 7:33pm [Delete] [Edit] The above post by Guido Dieterich (about collation and case sensitivity) is a good point. However, there is a way to match in a case-sensitive manner without having to change the collation of your existing tables: use the "BINARY" keyword. Here's an extended example (based on the one previously posted): SELECT ('WORD' REGEXP '[[:upper:]]{4}') AS `upper_match`, # this will be a 1 ('WORD' REGEXP '[[:lower:]]{4}') AS `lower_match`, # this will be a 1 on an "*_ci" collation # -BINARY- matches below (BINARY 'WORD' REGEXP '[[:upper:]]{4}') AS `bin_upper_match`, # this will be a 1 (BINARY 'WORD' REGEXP '[[:lower:]]{4}') AS `bin_lower_match` # this will be a 0 even on an "*_ci" collation Posted by Dennis K on November 8 2006 10:04am [Delete] [Edit] The query "SELECT * FROM table WHERE text REGEXP 'UPPER'" on a *.ci (e.g. latin1_general_ci) table will find any case insensetive words, even words like "upper" or "uPpOr", or "UpPOr", etc... To avoid this use one of the following Methods: SELECT * FROM table WHERE text COLLATE latin1_general_cs REGEXP '...' OR SELECT * FROM table WHERE CAST(x AS BINARY) REGEXP '...' Endret 8. januar 2009 av Ekko Lenke til kommentar
OyvindN Skrevet 8. januar 2009 Forfatter Del Skrevet 8. januar 2009 REGEXP BINARY var løsningen gitt. Lenke til kommentar
