Den store ATI Radeon HD5xxx-tråden. (ATI HD51X0-59X0)
SVD
Andre som opplever at fargene på skjermen ser ut som det har et grått belegg over seg, jeg får det ikke med 10.4....men legger jeg inn 10.7, 10.8 beta, 10.7 hotfix så får jeg det :ph34r:
Fikk det ikke første gangen, men får det vist nå.....
I 10.7, har det når jeg viser bilder i windows viwer, men ikke når jeg setter til fullscreen. Blidene er slik grå/gule
Er det noe slikt du opplever?
Endret av B-QL
Kopier topic jeg lagde på starcraft 2 forums:
Hello Everyone!
My rig is as follow:
Procesor: Intel Core i7 i7-920 (2,67GHz)
GPU: His Radeon 4870x2 2GB
RAM: Corsair XMS3 DDR3 1333MHz 6GB CL9
Motherboard: Asus P6T Deluxe
Computer Case: Antec Twelve Hundred Gaming Case Dell
Monitor: UltraSharp 2408WFP 24" 1920x1200
OS: Windows 7 64-bit
Nothing is overclocked.
I am getting around 40-45 fps at more or less when idle during tutorials and on random practice matches. With Rivatuner, I see that both of my gpus are working 1st one at 99% and 2nd one at 70%, so that means at least there are some dual gpu performance, disabling 2nd gpu drops the fps to around 19.
I forgot to add that I get a constant 29-30 fps no matter what setting I put it on, medium/high/ultra.
The game looks pretty good, but I expected higher performance then this.
What might be my problem?
I currently have 10.7 driver, upgraded from 10.5, However I wish I tested on 10.5 first :(
If it is a driver issue, which one do you suggest I switch to?
I know how to use driver sweeper, if necessary.
Here is my dxdiag:
System Information
Time of this report: 8/5/2010, 12:23:12
Machine name: AMIRHAYEK-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_gdr.100226-1909)
Language: Norwegian (Bokmål) (Regional Setting: Norwegian (Bokmål))
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 02/24/10 14:02:48 Ver: 08.00.15
Processor: Intel® Core i7 CPU 920 @ 2.67GHz (8 CPUs), ~2.7GHz
Memory: 6144MB RAM
Available OS Memory: 6136MB RAM
Page File: 1942MB used, 10326MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Radeon HD 4870 X2
Manufacturer: ATI Technologies Inc.
Chip type: ATI display adapter (0x9441)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_9441&SUBSYS_25421002&REV_00
Display Memory: 744 MB
Dedicated Memory: 2029 MB
Shared Memory: 2811 MB
Current Mode: 1920 x 1200 (32 bit) (59Hz)
Monitor Name: Dell 2408WFP(Digital)
Monitor Model: DELL 2408WFP
Monitor Id: DELA02A
Native Mode: 1920 x 1200(p) (59.950Hz)
Output Type: DVI
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1036 (English)
Driver Version: 8.753.0.0
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 7/7/2010 03:53:20, 594432 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-D701-11CF-BE77-4805BEC2C535}
Vendor ID: 0x1002
Device ID: 0x9441
SubSys ID: 0x25421002
Revision ID: 0x0000
Driver Strong Name: oem25.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_RV7X:8.753.0.0:pci\ven_1002&dev_9441
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_989B&SUBSYS_10438372&REV_1003
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7600.16385 (English)
WHQL Logo'd: Yes
Date and Size: 7/14/2009 02:07:00, 350208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX 2.0 Listen/Src: No, No
I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Microsoft® SiderWinderTM X6 Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x074B
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x3A36
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/14/2009 02:07:09, 343040 bytes
| Driver: usbd.sys, 7/14/2009 02:06:23, 7936 bytes
Gameport Devices
PS/2 Devices
+ Microsoft SideWinder X6 Keyboard (IntelliType Pro)
| Matching Device ID: hid\vid_045e&pid_074b&mi_00
| Service: kbdhid
| Driver: kbdhid.sys, 7/14/2009 02:00:20, 33280 bytes
| Driver: kbdclass.sys, 7/14/2009 03:48:04, 50768 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/14/2009 01:19:57, 105472 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x1532, 0x000D
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/14/2009 02:00:20, 31232 bytes
| Driver: mouclass.sys, 7/14/2009 03:48:27, 49216 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 7/14/2009 03:45:55, 62544 bytes
| Driver: sermouse.sys, 7/14/2009 02:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 835.1 GB
Total Space: 953.9 GB
File System: NTFS
Model: SAMSUNG HD103UJ ATA Device
Drive: D:
Free Space: 382.4 GB
File System: NTFS
Drive: E:
Model: Optiarc DVD RW AD-7200S ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (Norwegian (Bokmål)), 7/14/2009 01:19:54, 147456 bytes
Drive: F:
Model: VKRKPW PU7W12J8LE SCSI CdRom Device
System Devices
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_82EA1043&REV_00\3&11583659&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/14/2009 02:06:13, 122368 bytes
Name: Intel® ICH10 Family USB Universal Host Controller - 3A34
Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_82D41043&REV_00\3&11583659&0&E8
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/14/2009 02:06:27, 30720 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/14/2009 02:06:31, 324608 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/14/2009 02:07:09, 343040 bytes
Name: Intel® 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_82D41043&REV_90\3&11583659&0&F0
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/14/2009 03:45:45, 183872 bytes
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10B5&DEV_8647&SUBSYS_864710B5&REV_AB\4&2EB3824&0&0018
Name: Intel® ICH10 Family USB Enhanced Host Controller - 3A3C
Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_82D41043&REV_00\3&11583659&0&D7
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/14/2009 02:06:30, 51200 bytes
Name: Intel® ICH10 Family SMBus Controller - 3A30
Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_82D41043&REV_00\3&11583659&0&FB
Driver: n/a
Name: RAID Controller
Device ID: PCI\VEN_11AB&DEV_6440&SUBSYS_82E41043&REV_02\4&18D9E9AB&0&00E3
Driver: n/a
Device ID: PCI\VEN_1002&DEV_AA30&SUBSYS_AA301002&REV_00\6&7B36EA7&0&01200018
Name: Intel® ICH10 Family USB Enhanced Host Controller - 3A3A
Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_82D41043&REV_00\3&11583659&0&EF
Name: Intel® ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26
Device ID: PCI\VEN_8086&DEV_3A26&SUBSYS_82D41043&REV_00\3&11583659&0&FD
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/14/2009 03:45:45, 12352 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (Norwegian (Bokmål)), 7/14/2009 03:45:46, 48720 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 03:52:21, 24128 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (Norwegian (Bokmål)), 7/14/2009 03:52:21, 155728 bytes
Name: Intel® 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423
Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00000000&REV_12\3&11583659&0&A2
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_11AB&DEV_6121&SUBSYS_82121043&REV_B2\4&28714A0B&0&00E4
Name: ATI Radeon HD 4870 X2
Device ID: PCI\VEN_1002&DEV_9441&SUBSYS_25421002&REV_00\6&7B36EA7&0&00200018
Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.1047 (English), 7/7/2010 04:30:08, 7195648 bytes
Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0019 (English), 7/7/2010 03:14:16, 53248 bytes
Driver: C:\Windows\system32\DRIVERS\atikmpag.sys, 8.14.0001.6126 (English), 7/7/2010 03:15:42, 265728 bytes
Driver: C:\Windows\system32\atiumd64.dll, 8.14.0010.0768 (English), 7/7/2010 03:22:26, 5099008 bytes
Driver: C:\Windows\system32\atiumd6a.dll, 8.14.0010.0267 (English), 7/7/2010 03:30:12, 2785792 bytes
Driver: C:\Windows\system32\atitmm64.dll, 6.14.0011.0022 (English), 7/7/2010 03:49:48, 120320 bytes
Driver: C:\Windows\system32\atiicdxx.dat, 5/11/2010 22:42:08, 205156 bytes
Driver: C:\Windows\system32\amdpcom64.dll, 8.14.0010.0023 (English), 7/7/2010 03:11:12, 54272 bytes
Driver: C:\Windows\system32\atimpc64.dll, 8.14.0010.0023 (English), 7/7/2010 03:11:12, 54272 bytes
Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1054 (English), 7/7/2010 03:16:06, 335872 bytes
Driver: C:\Windows\system32\atiumd6a.cap, 7/7/2010 03:27:28, 543664 bytes
Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1001 (English), 7/7/2010 03:49:14, 12288 bytes
Driver: C:\Windows\system32\atiapfxx.exe, 6.14.0010.1001 (English), 7/7/2010 03:54:16, 143360 bytes
Driver: C:\Windows\system32\atiapfxx.blb, 7/7/2010 03:54:32, 63416 bytes
Driver: C:\Windows\system32\atiesrxx.exe, 6.14.0011.1062 (English), 7/7/2010 03:50:54, 203264 bytes
Driver: C:\Windows\system32\atieclxx.exe, 6.14.0011.1062 (English), 7/7/2010 03:51:26, 462336 bytes
Driver: C:\Windows\system32\atipdl64.dll, 6.14.0010.2562 (English), 7/7/2010 03:49:36, 421376 bytes
Driver: C:\Windows\system32\atiedu64.dll, 6.14.0010.2514 (English), 7/7/2010 03:49:10, 59392 bytes
Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.3839.37545 (Norwegian (Bokmål)), 7/7/2010 03:51:30, 446464 bytes
Driver: C:\Windows\system32\atio6axx.dll, 6.14.0010.10061 (English), 7/7/2010 04:16:20, 20118528 bytes
Driver: C:\Windows\system32\aticaldd64.dll, 6.14.0010.0737 (English), 7/7/2010 03:29:06, 5378560 bytes
Driver: C:\Windows\system32\aticalrt64.dll, 6.14.0010.0737 (English), 7/7/2010 03:29:26, 51200 bytes
Driver: C:\Windows\system32\aticalcl64.dll, 6.14.0010.0737 (English), 7/7/2010 03:29:16, 44544 bytes
Driver: C:\Windows\system32\atipblag.dat, 6/16/2010 00:28:58, 2857 bytes
Driver: C:\Windows\system32\atiu9p64.dll, 8.14.0001.6126 (English), 7/7/2010 03:14:50, 30208 bytes
Driver: C:\Windows\system32\atiuxp64.dll, 8.14.0001.6126 (English), 7/7/2010 03:15:04, 39424 bytes
Driver: C:\Windows\system32\atig6pxx.dll, 8.14.0001.6126 (English), 7/7/2010 03:15:54, 14848 bytes
Driver: C:\Windows\system32\atig6txx.dll, 8.14.0001.6126 (English), 7/7/2010 03:15:48, 18432 bytes
Driver: C:\Windows\system32\atibtmon.exe, 2.00.0000.0000 (English), 5/11/2009 23:35:28, 118784 bytes
Driver: C:\Windows\system32\atidxx64.dll, 8.17.0010.0292 (English), 7/7/2010 03:37:36, 4463616 bytes
Driver: C:\Windows\SysWOW64\atiumdag.dll, 8.14.0010.0768 (English), 7/7/2010 03:28:20, 3975680 bytes
Driver: C:\Windows\SysWOW64\atiumdva.dll, 8.14.0010.0267 (English), 7/7/2010 03:23:14, 3058688 bytes
Driver: C:\Windows\SysWOW64\amdpcom32.dll, 8.14.0010.0023 (English), 7/7/2010 03:11:06, 52736 bytes
Driver: C:\Windows\SysWOW64\atimpc32.dll, 8.14.0010.0023 (English), 7/7/2010 03:11:06, 52736 bytes
Driver: C:\Windows\SysWOW64\atiadlxy.dll, 6.14.0010.1054 (English), 7/7/2010 03:16:02, 237568 bytes
Driver: C:\Windows\SysWOW64\atiumdva.cap, 7/7/2010 03:22:52, 543664 bytes
Driver: C:\Windows\SysWOW64\atipdlxx.dll, 6.14.0010.2562 (English), 7/7/2010 03:49:28, 356352 bytes
Driver: C:\Windows\SysWOW64\Oemdspif.dll, 6.15.0006.0006 (English), 7/7/2010 03:49:18, 278528 bytes
Driver: C:\Windows\SysWOW64\ati2edxx.dll, 6.14.0010.2514 (English), 7/7/2010 03:49:06, 43520 bytes
Driver: C:\Windows\SysWOW64\atioglxx.dll, 6.14.0010.10061 (English), 7/7/2010 03:55:08, 15461888 bytes
Driver: C:\Windows\SysWOW64\atidxx32.dll, 8.17.0010.0292 (English), 7/7/2010 03:46:26, 3826688 bytes
Driver: C:\Windows\SysWOW64\aticaldd.dll, 6.14.0010.0737 (English), 7/7/2010 03:27:58, 4323840 bytes
Driver: C:\Windows\SysWOW64\aticalrt.dll, 6.14.0010.0737 (English), 7/7/2010 03:29:24, 46080 bytes
Driver: C:\Windows\SysWOW64\aticalcl.dll, 6.14.0010.0737 (English), 7/7/2010 03:29:14, 44032 bytes
Driver: C:\Windows\SysWOW64\atipblag.dat, 6/16/2010 00:28:58, 2857 bytes
Driver: C:\Windows\SysWOW64\atiu9pag.dll, 8.14.0001.6126 (English), 7/7/2010 03:14:44, 22528 bytes
Driver: C:\Windows\SysWOW64\atiuxpag.dll, 8.14.0001.6126 (English), 7/7/2010 03:14:58, 30208 bytes
Driver: C:\Windows\SysWOW64\atigktxx.dll, 8.14.0001.6126 (English), 7/7/2010 03:15:46, 16896 bytes
Driver: C:\Windows\SysWOW64\atiglpxx.dll, 8.14.0001.6126 (English), 7/7/2010 03:15:50, 12800 bytes
Driver: C:\Windows\atiogl.xml, 6/18/2010 07:13:30, 21682 bytes
Driver: C:\Windows\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 2/3/2009 22:52:06, 51200 bytes
Driver: C:\Windows\system32\ATIODE.exe, 1.00.0000.0001 (English), 2/18/2009 19:55:22, 332288 bytes
Driver: C:\Windows\system32\atiglpxx.dll, 8.14.0001.6126 (English), 7/7/2010 03:15:50, 12800 bytes
Driver: C:\Windows\system32\aticfx64.dll, 8.17.0010.1036 (English), 7/7/2010 03:53:20, 594432 bytes
Driver: C:\Windows\SysWOW64\aticfx32.dll, 8.17.0010.1036 (English), 7/7/2010 03:54:08, 513024 bytes
Driver: C:\Windows\system32\coinst.dll, 1.00.0002.0001 (English), 7/7/2010 03:24:34, 55296 bytes
Name: Intel® ICH10 Family PCI Express Root Port 6 - 3A4A
Device ID: PCI\VEN_8086&DEV_3A4A&SUBSYS_82EA1043&REV_00\3&11583659&0&E5
Name: Intel® ICH10 Family USB Universal Host Controller - 3A39
Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_82D41043&REV_00\3&11583659&0&D2
Name: Intel® ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20
Device ID: PCI\VEN_8086&DEV_3A20&SUBSYS_82D41043&REV_00\3&11583659&0&FA
Name: Intel® 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422
Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00000000&REV_12\3&11583659&0&A1
Driver: n/a
Name: Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2
Device ID: PCI\VEN_11AB&DEV_4364&SUBSYS_81F81043&REV_12\4&B1C1760&0&00E5
Driver: C:\Windows\system32\DRIVERS\yk62x64.sys, 11.24.0003.0003 (English), 2/15/2010 12:24:00, 401696 bytes
Driver: C:\Windows\system32\yk62x64.dll, 11.11.0001.0003 (English), 2/15/2010 12:24:00, 501536 bytes
Device ID: PCI\VEN_1002&DEV_9441&SUBSYS_20421002&REV_00\6&3A31A9D6&0&00400018
Name: Intel® ICH10 Family PCI Express Root Port 5 - 3A48
Device ID: PCI\VEN_8086&DEV_3A48&SUBSYS_82EA1043&REV_00\3&11583659&0&E4
Name: Intel® ICH10 Family USB Universal Host Controller - 3A38
Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_82D41043&REV_00\3&11583659&0&D1
Name: Intel® ICH10R LPC Interface Controller - 3A16
Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_82D41043&REV_00\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 03:48:27, 15424 bytes
Name: Intel® 7500/5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E
Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_836B1043&REV_12\3&11583659&0&38
Device ID: PCI\VEN_11AB&DEV_4364&SUBSYS_81F81043&REV_12\4&325840BC&0&00E2
Name: Intel® ICH10 Family PCI Express Root Port 4 - 3A46
Device ID: PCI\VEN_8086&DEV_3A46&SUBSYS_82EA1043&REV_00\3&11583659&0&E3
Name: Intel® ICH10 Family USB Universal Host Controller - 3A37
Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_82D41043&REV_00\3&11583659&0&D0
Name: Intel® 7500/5520/5500/X58 I/O Hub Throttle Registers - 3438
Device ID: PCI\VEN_8086&DEV_3438&SUBSYS_00000000&REV_12\3&11583659&0&A3
Driver: n/a
Name: Intel® 7500/5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A
Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_836B1043&REV_12\3&11583659&0&18
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&1B359D48&0&10F0
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/14/2009 02:07:13, 227840 bytes
Name: Intel® ICH10 Family PCI Express Root Port 3 - 3A44
Device ID: PCI\VEN_8086&DEV_3A44&SUBSYS_82EA1043&REV_00\3&11583659&0&E2
Name: Intel® ICH10 Family USB Universal Host Controller - 3A36
Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_82D41043&REV_00\3&11583659&0&EA
Name: Intel® 7500/5520/5500/X58 I/O Hub System Management Registers - 342E
Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00000000&REV_12\3&11583659&0&A0
Driver: n/a
Name: Intel® 7500/5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408
Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_836B1043&REV_12\3&11583659&0&08
Device ID: PCI\VEN_10B5&DEV_8647&SUBSYS_864710B5&REV_AB\5&288E9C76&0&400018
Name: Intel® ICH10 Family PCI Express Root Port 1 - 3A40
Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_82EA1043&REV_00\3&11583659&0&E0
Name: Intel® ICH10 Family USB Universal Host Controller - 3A35
Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_82D41043&REV_00\3&11583659&0&E9
Name: Intel® 5520/5500/X58 I/O Hub to ESI Port - 3405
Device ID: PCI\VEN_8086&DEV_3405&SUBSYS_836B1043&REV_12\3&11583659&0&00
Driver: n/a
Device ID: PCI\VEN_10B5&DEV_8647&SUBSYS_864710B5&REV_AB\5&288E9C76&0&200018
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16590
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
ATI MPEG File Writer,0x00200000,1,0,atimpenc64.dll,11.01.0000.50527
ATI MPEG Video Decoder,0x005fffff,1,2,atimpenc64.dll,11.01.0000.50527
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16590
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc64.dll,11.01.0000.50527
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
ATI MPEG Video Encoder,0x00200000,1,1,atimpenc64.dll,11.01.0000.50527
ATI MPEG Multiplexer,0x00200000,2,1,atimpenc64.dll,11.01.0000.50527
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
ATI Video Scaler Filter,0x00200000,1,1,atimpenc64.dll,11.01.0000.50527
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
Overlay Mixer2,0x00200000,1,1,,
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16590
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
ATI Video Rotation Filter,0x00200000,1,1,atimpenc64.dll,11.01.0000.50527
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16490
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16590
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16590
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16590
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16490
WDM Streaming Capture Devices:
,0x00000000,0,0,,
HD Audio Muxed capture,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
WDM Streaming Rendering Devices:
ATI HD Audio rear output,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
HD Audio HDMI out,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
HD Audio Speaker,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
HD Audio SPDIF out,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16590
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (High Definition Audio,0x00200000,1,0,quartz.dll,6.06.7600.16490
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7600.16490
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
edit: det viser seg at gpu 1 er på 70%, gpu 2 er på 100%,er det normalt?
Pleier det ikke vanligvis å være omvendt?
edit2: på alle medium settings, da har jeg 100fps average, high og ultra får jeg samme fps.
Endret av amir90
Ikke grå\gult nei, bare grått...om det er litt gult i det kan godt hende :!:
Jeg ser bare at noe ikke stemmer :hrm:
spør microsoft, dems feil at alt blir gult hehe, er noe med hvordan windows hondterer farger
fiks her
http://www.walkernews.net/2009/11/22/fix-windows-photo-viewer-display-problem-tinted-yellow-to-pink-colour-glitch/
Meg og skjerm Ourasi er som man skal ha sex for første gang i sitt liv...og man er dritings :ph34r:
Så mens jeg letet etter "Pixel Format", så gikk jeg inn configure på skjermen igjenom CCC, så trykte jeg default og da ble skjermen som den skulle.
Restartet for og se om den var fremdeles slik som den skulle være, og det var den :thumbup:
Men det er som du sier, den setter en feil profil ja:)
Endret av Amanita Muscaria
Jau, slike driverbugs er bittesmå for meg som kjenner igjen problemet og løser det med noen museklikk, men blir straks værre når man ikke har opplevd det før så du har ingen grunn til å være flau. Feil "Pixel Format" eller skjermer/HDTV som ikke støtter default format har terrorisert mange i denne tråden med bla. rosa farger o.l...
Men gøy at du kan utforske siste drivere nå da :thumbup:
Jeg har funnet "the golden driver" for BC2 nå :D Iallefall for mitt system.
Catalyst [Modified build] Build v3.80a http://forums.guru3d.com/showthread.php?t=322616
ATI CrossFireX™ Application Profiles 492.5KB July 26th 7/26/2010 http://game.amd.com/us-en/drivers_catalyst.aspx?p=win7/windows-7-64bit
= :love:
Ligger på rundt om 140FPS :w00t:
Dette topper lett 10.4 beta og 10.5a eller hva de heter :thumbup:
Endret av Nizzen
Hmm, jeg trenger virkelig hjelp med å få installert 10.6 display driver, ser ikke til å fungere!
Metodene jeg har prøvd:
1) Driver sweeper > velger ati > ber programmet om å fjerne alt > blir spurt om å reboot > trykker ok
maskinen har startet på nytt, jeg får beskjed om at det er ingen display driver for ati installert, trykker ok.
Installerer Catalyst Software Suite (64 bit) English Only, etter den er ferdig blir jeg ikke spurt om reboot, gjør det likevel.
etter reboot, får jeg samme beskjed.
Gjør samme opplegg igjen, men denne gangen installerer jeg kun display driver, samma opplegg som øverst, så det funket heller ikke.
2) enhetsbehandling metoden, funket ikke, fikk bare blåskjerm flere ganger.
Noe hjelp å få?
Hvilke vifter annbefales til et HD 5870?
Viften kortet kom med ser ut til å ha fått tourettes eller lignende, rister og lager mer lyd enn en gressklipper..
Er ikke intresert i vannkjøling og har "vokst" fra overklokking (er ikke det samme lenger :S), samtidig som jeg ikke har noe behov for det.
Eneste kriteriet er at det fungerer og ikke lager noe serlig lyd og kjøler minst like godt som orginalen.
Pris er jeg ikke spessielt intresert i.
