Den store ATI Radeon HD5xxx-tråden. (ATI HD51X0-59X0)
SVD
Tittet i førstepost under 5970:
Crossfire mellom dette kortet og et 5870 er fullt mulig, 5850 går også men er ikke anbefalt siden det vil yte dårligere. (blir som 3x5850)
Den siste påstanden er feil. Et 5850 vil ikke sinke ned et 5970, da CF-teknologien benytter seg av load balancing.
5850 har færre texture units og streaming processors...
streaming processors: 1440 VS 1600
texture units: 72 VS 80
Endret av Nizzen
Ja, men rendringen går fortsatt til det kortet som har tid - de samarbeider ikke om en enkelt frame.
Et 5850 og et 5970 vil f.eks rendre 20/80 (5850 på 20% av en frame, 5970 på de resterende) eller liknende.
EDIT:
Jeg quoter Sindre fra hardwarekaféen:
Sikker, Sindre? Mener ATIs CrossfireX-teknologi gjorde slik at det kortet som har "tid" tar seg av oppgaven.
Stemmer det, var visst ikke helt oppdatert her. :p
- Scissors:
This mode is similar to the SFR (Split Frame Rendering) from SLI, but since you can hook two different video cards under CrossFire, the half of the screen rendered by the fastest video card would be done first and the card would have to wait for the slower can to finish its job to go ahead to the next frame. This would make the faster video card work at the same speed of the slower one. To solve this problem, Crossfire enables dynamic load balancing, i.e. if a fast card is connected together with a slower one, the system won’t divide the screen as two equal parts, it will put the faster card to render a bigger portion of the screen than the slower one, thus making them to finish the rendering at the same time.
- SuperTiling:
Under this mode the screen is divided into several small squared portions (or “tiles”), each one measuring 32x32 pixels, and each video card is in charge of handling part of the available tiles. Load balancing is also used here, so the fastest card will get more tiles to render than the slowest card if you use two different video cards.
- Alternate Frame Rendering
This mode is identical to the SLI mode with the same name, where while one video card is rendering the current frame, the other card is rendering the next frame.
Kilde
Dynamic load balancing het det. Endret av WheelMan
@Nizzen
Hvordan får du cfx til å funke i Dirt2, jeg får det ikke til( Har inst. hotfix driveren)
Klokker med MSI afterburner samtidig, kan det være derfor det ikke funker?
Får "kun" 70 fps i benchmarken og ser at GPU 2 ikke er i bruk når jeg spiller.
Spørsmål: HVA SKJER??
Jeg hadde tidligere 4870x2, og brukte 2 skjermer på det uten problemer. I dag byttet jeg ut 4870x2'et med et 5850. Jeg er skuffet! Forventet at dette skulle gå uten NOE lagg, eller flimring. Men neida! Skjerm nummer 2 her flimrer HELE tiden. Noen som har en løsning? Jeg har installert den nyeste driveren fra amd.com
Kan godt hende at dette er feil driver, eller en som kanskje er gammel. Isåfall så post gjerne en link til en hotfix eller en driver som har kjørt bra.
mange sliter med det der og det ligger en link til en ny bios i en av 5870 trådene som skal fikse dette;)
Hvis ikke det var til 5870 da, men det der er et problem mange har og det ligger i bios eller driver så ordnet blir det.
Kommet ny bios til 5870:
http://www.xtremesystems.org/forums/showthread.php?t=240336
det var til 5870 ja:S
Har du søkt på google\nettet etter løsning?
Og ha litt tålmodighet , det er et nytt produkt og feil kommer opp hele tiden. Og de kommer hele tiden ut med små fixer.
Og den nyeste drivern fra Ati.com sine sider SUGER. Du må prøve litt før du før man hyler og bæljer over hvor skuffet man er:P
Endret av Amanita Muscaria
Jeg har 5850.. men kan godt prøve den fixen der. Nei har ikke googlet det enda (gjør det nå..) Tenkte å spørre i denne tråden, ettersom dette er 58xx tråden osv.
du endret innlegget til å kjefte litt på meg ja :p
Greit nok det. jeg syns det er lettere å få ut litt aggresjon ved å skrive et slikt innlegg, enn å finne løsningen på problemet med en gang.
Rask på svar jo :O
Har ikke prøvd den bios fixen enda, xs er stengt i 30 min pga noe database sjekking.
* puster nå lettet ut *
Ny edit: Jepp, vista 64 bit. Og takk for hjelp! prøver denne ;)
Endret av christhenoob
var egentlig ikke ment som kjefting:)
Var mer ment som et klask i bakhuet og be deg ha litt tålmodighet:P
Vet sånt er frustrerende, men det løser seg til slutt;)
Foreks. mange sliter med eyefinity med CF osv.
Er nytt produkt og de finner ikke alle feilene før det kommer ut.
Siden alle pcer er forskjelig og hele suppa der.
Så vi blir som ufrivilige prøvekaniner.
Prøver og svare raskt på problemer hvis jeg kan hjelpe siden je ger slik selv som deg:P
Blir fort sint og klikker i vinkel..hehe
