Cortinarius rubellus Skrevet 26. november 2009 Rapporter Del Skrevet 26. november 2009 Dassem: http://www.arctic-cooling.com/catalog/prod...=2_&mID=256 Lenke til kommentar
srbz Skrevet 26. november 2009 Rapporter Del Skrevet 26. november 2009 Jeg fikk da solgt maskinen til en kompis for innkjøpspris. Win-win. Lenke til kommentar
Mydog Skrevet 26. november 2009 Rapporter Del Skrevet 26. november 2009 (endret) 9.12 rc er vel bare kommet til windows xp. Har du til vista/win 7, så er det mest sansynlig 9.11 beta Her er 9.12 Beta driverne til Vista/Win7 8.663.1_Beta4_Hemlock_VistaWin7_Nov6.exe Skal teste den nå. Kommentar fra denne testen av NFS Shift Need for Speed SHIFT Gameplay Performance and IQ Hemlock Driver Along with this new patch, AMD has been improving driver performance, and most of the performance advantages in Need for Speed SHIFT come by way of this new driver. We have an early look at what is coming in Catalyst 9.12. The "Hemlock" driver we are testing with today is what will be found in Catalyst 9.12. As you have probably guessed, this same driver will be used for the launch of Hemlock, AMD’s dual-GPU video card. The version of this driver is Catalyst 8.663.1 Beta. What allows us to go ahead and use this driver right now is the fact that when Hemlock is launched, AMD will provide this same press driver to the public on their website. Therefore, you guys will be able to use this driver as well soon. With this new driver, and this new patch, we are looking for some serious performance improvements in Need for Speed SHIFT. Endret 26. november 2009 av minhund Lenke til kommentar
Dassen Skrevet 26. november 2009 Rapporter Del Skrevet 26. november 2009 Dassem: http://www.arctic-cooling.com/catalog/prod...=2_&mID=256 Takk. Jeg ser at Thermalright kommer med nye kjølere i nær fremtid, så jeg holder ut med stock fram til det. Lenke til kommentar
Cortinarius rubellus Skrevet 26. november 2009 Rapporter Del Skrevet 26. november 2009 Er fan av de selv, når man først skal snakke om luftkjøling:) Lenke til kommentar
wiak Skrevet 26. november 2009 Rapporter Del Skrevet 26. november 2009 Noen som vet om en god kjøler for mitt 5850? stock? Lenke til kommentar
wiak Skrevet 26. november 2009 Rapporter Del Skrevet 26. november 2009 9.11 "Dirt 2" hotfix performance driver http://support.amd.com/us/kbarticles/Pages...erformance.aspx Lenke til kommentar
Dassen Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 Noen som vet om en god kjøler for mitt 5850? stock? Stock gjør jobben, men er veldig bråkete. Leste en plass at 5850 har samme avstand mellom festepunktene som 4870, stemmer dette? Lenke til kommentar
lolvik Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 (endret) Tror både 5850 og 5870 har det. Men nå får du visst svaret, Amanita safes the day. Endret 27. november 2009 av lolvik Lenke til kommentar
Cortinarius rubellus Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 (endret) Opptil 30% på stockkjølern er så og si "lydløst", over det så begynner du og høre det:) Men den kjøler bra, det har jeg fått bevist så det holder. Ja, siden 5870 blokker passer 5850 og 4870 blokker passer 5870 så betyr det at du kan bruke 4870 blokk\kjøler på den. Men er usikker på om den kjøler alt. Tror du må sette på noen ribber på kortet. The man that never sleeps........... Endret 27. november 2009 av Amanita Muscaria Lenke til kommentar
PsySpectre Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 Wuh. fikk mail fra mpx, 5870 er på vei skal bli morro å prøve! Lenke til kommentar
Crazymech Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 (endret) http://www.anandtech.com/weblog/showpost.aspx?i=657 Ooops. Ser ut som 5970 kan tjene mye på 3 parts kjøler som dekker VRM's bedre . Folk som driver overklokking & Folding@Home burde være forsiktig. Endret 27. november 2009 av Crazymech Lenke til kommentar
wiak Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 Nvidia launches first 300 series card And yes, it's a rebrand http://www.fudzilla.com/content/view/16601/34/ hahaha bra av nvidia å ta råtta på sine egne kunder Lenke til kommentar
Crazymech Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 Feil tråd xD Men dårlig gjort av nVidia ovenfor forbrukerne, ikke at det er et unikt tilfelle. Lenke til kommentar
Cortinarius rubellus Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 Nvidia slår hardt på stortromma som vanlig :!: Nvidia the rebrand............. Lenke til kommentar
The Ghost Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 Motto'ets dems er nVidia the way it's ment to be played, det burdte vært: nVidia the way it's ment to be renamed Lenke til kommentar
simalarion Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 (endret) Der ble samtlige 5970 utsatt på komplett til 01.01 , selv om ikke andre webshopper har oppdatert sine ubekreftede datoer regner med at de i alle fall ikke får noe før komplett. Kanselerte bestillingen på komplett og bestilte da sapphire som er det billigste (har nå samme ubekreftede dato) Endret 27. november 2009 av simalarion Lenke til kommentar
Jens viking Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 vanligvis når jeg kjøper på komplett så har jeg pakken i postkassa dagen derpå (så fremt jeg har lagt inn bestillingen ca. rundt kl. 12 på dagen). jeg ser nå at komplett har lagt inn melding om sending kl 11 på skjermkortet mitt i dag, spørsmålet er da om jeg vil få pakken i morgen, mtp at det er fredag/lørdag? Lenke til kommentar
Core2Dude Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 vanligvis når jeg kjøper på komplett så har jeg pakken i postkassa dagen derpå (så fremt jeg har lagt inn bestillingen ca. rundt kl. 12 på dagen). jeg ser nå at komplett har lagt inn melding om sending kl 11 på skjermkortet mitt i dag, spørsmålet er da om jeg vil få pakken i morgen, mtp at det er fredag/lørdag? Lørdag er vel en vanlig sendingsdag for posten, så da burde den jo komme imorgen! Lenke til kommentar
chevyz28 Skrevet 27. november 2009 Rapporter Del Skrevet 27. november 2009 Der ble samtlige 5970 utsatt på komplett til 01.01 , selv om ikke andre webshopper har oppdatert sine ubekreftede datoer regner med at de i alle fall ikke får noe før komplett. Kommer det noen 58XX på det norske markedet i det hele tatt. Det virker som alt er støvsugd! Håper det kommer inn noe før jul, ellers blir jula ødelagt. Lenke til kommentar
