Hvorfor vises ikke Javascript-meny i Netscape/Mozilla?
Dette er en slidemeny som virker fra iexplorer og opera, men ikke fra mozilla og netscape. Kan noen som er guru på javascript fortelle meg hvorfor?
Legger ved hele sriptet:
function lib_bwcheck(){ //Browsercheck (needed)
this.ver=navigator.appVersion
this.agent=navigator.userAgent
this.dom=document.getElementById?1:0
this.opera5=this.agent.indexOf("Opera 5")>-1
this.ie5=(this.ver.indexOf("MSIE 5")>-1 && this.dom && !this.opera5)?1:0;
this.ie6=(this.ver.indexOf("MSIE 6")>-1 && this.dom && !this.opera5)?1:0;
this.ie4=(document.all && !this.dom && !this.opera5)?1:0;
this.ie=this.ie4||this.ie5||this.ie6
this.mac=this.agent.indexOf("Mac")>-1
this.ns6=(this.dom && parseInt(this.ver) >= 5) ?1:0;
this.ns4=(document.layers && !this.dom)?1:0;
this.bw=(this.ie6 || this.ie5 || this.ie4 || this.ns4 || this.ns6 || this.opera5)
return this
var bw=new lib_bwcheck()
function makeMenuObj(obj,nest){
nest=(!nest) ? "":'document.'+nest+'.'
this.css=bw.dom? document.getElementById(obj).style:bw.ie4?document.all[obj].style:bw.ns4?eval(nest+"document.layers." +obj):0;
this.el=bw.dom?document.getElementById(obj):bw.ie4?document.all[obj]:bw.ns4?eval(nest+'document.'+obj):0;
this.ref=bw.dom || bw.ie4? document:bw.ns4?eval(nest+"document.layers." +obj+".document"):0;
this.x=(bw.ns4 || bw.ns5)? this.css.left:this.css.offsetLeft;
this.y=(bw.ns4 || bw.ns5)? this.css.top:this.css.offsetTop;
this.hideIt=b_hideIt; this.showIt=b_showIt; this.movey=b_movey
this.moveIt=b_moveIt; this.moveBy=b_moveBy; this.status=0;
this.bgImg=b_bgImg; this.obj = obj + "Object"; eval(this.obj + "=this");
this.clipTo=b_clipTo;
return this
function b_showIt(){this.css.visibility="visible"; this.status=1}
function b_hideIt(){this.css.visibility="hidden"; this.status=0}
function b_movey(y){this.y=y; this.css.top=this.y}
function b_moveIt(x,y){this.x=x; this.y=y; this.css.left=this.x;this.css.top=this.y}
function b_moveBy(x,y){this.x=this.x+x; this.y=this.y+y; this.css.left=this.x;this.css.top=this.y}
function b_bgImg(img){if(bw.ie||bw.dom)this.css.backgroundImage="url('"+img+"')"
else this.css.background.src=img
function b_clipTo(t,r,b,l,w){if(bw.ns4){this.css.clip.top=t;this.css.clip.right=r
this.css.clip.bottom=b;this.css.clip.left=l
}else{this.css.clip="rect("+t+","+r+","+b+","+l+")"; if(w){this.css.width=r; this.css.height=b}}}
function SlideMenuInit(){
oSlideMenu=new makeMenuObj('divSlideCont')
oSlideMenu.moveIt(menux,menuy)
oSlide=new Array()
for(i=0;i<menus.length;i++){
oSlide=new makeMenuObj('divSlide'+i,'divSlideCont')
oSlide.subs=menus.subs
oSlide.sub=new Array()
oSlide.moveIt(0,mainheight*i)
oSlide.starty=oSlide.y
if(bw.opera) oSlide.css.paddingLeft="10px"
if(!menus.seperator) oSlide.bgImg(level0_regular)
for(j=0;j<oSlide.subs;j++){
oSlide.sub[j]=new makeMenuObj('divSlideSub'+i+"_"+j,'divSlideCont')
oSlide.sub[j].moveIt(10,oSlide.y+subheight*j+between)
oSlide.sub[j].starty=oSlide.sub[j].y
oSlide[j]=new Array()
oSlide[j].subs=menus[j].subs
oSlide[j].sub=new Array()
img=level1_round
if(oSlide[j].subs!=0){
if(j!=oSlide.subs-1) img=level1_sub
else img=level1_sub_round
oSlide.sub[j].css.color="white"
}else{
if(j!=oSlide.subs-1)img=level1_regular
oSlide.sub[j].origimg=img
oSlide.sub[j].bgImg(img)
for(a=0;a<oSlide[j].subs;a++){
oSlide[j].sub[a]=new makeMenuObj('divSlideSub'+i+"_"+j+"_"+a,'divSlideCont')
oSlide[j].sub[a].moveIt(20,oSlide.sub[j].y+subheight*a+between-2)
oSlide[j].sub[a].starty=oSlide[j].sub[a].y
oSlide[j][a]=new Array()
oSlide[j][a].subs=menus[j][a].subs
oSlide[j][a].sub=new Array()
if(a!=oSlide[j].subs-1) img=level2_regular
else img=level2_round
oSlide[j].sub[a].origimg=img
oSlide[j].sub[a].bgImg(img)
oSlideMenu.showIt()
var active=-1;var going;var isthere; var sactive=-1; var sisthere=-1; var s2active=-1; var s2isthere=-1
function swmenu(num,snum,s2num){
if(snum!=-1){
if(oSlide[num][snum].subs==0) return
if(s2num!=-1){
if(oSlide[num][snum][s2num].subs==0) return
if((num!=active || snum!=sactive || s2num!=s2active) && !going){going=true;isthere=0;sisthere=0;moveUp(num,snum,s2num)}
function moveUp(num,snum){
if(snum==-1){
for(i=0;i<oSlide.length;i++){
if(oSlide.y>oSlide.starty+pxspeed && active!=i) oSlide.moveBy(0,-pxspeed)
else{if(active!=i) oSlide.moveIt(oSlide.x,oSlide.starty); isthere=i}
if(isthere<oSlide.length-1) setTimeout("moveUp("+num+","+snum+")",timspeed)
else swmenu2(num,snum)
}else{
if(num==oSlide.length-1) isthere=num
if(sactive!=-1){ //Is out!
//Slide subs
j=0
for(i=sactive+1;i<oSlide[num].sub.length;i++){
j++
if(oSlide[num].sub.y>oSlide[num].sub.starty+pxspeed) oSlide[num].sub.moveBy(0,-pxspeed)
else{oSlide[num].sub.moveIt(oSlide[num].sub.x,oSlide[num].sub.starty); sisthere=i}
//Slide main
for(i=num+1;i<oSlide.length;i++){
if(oSlide.y>oSlide.starty + oSlide[num].sub[sactive].y +subheight*j ) oSlide.moveBy(0,-pxspeed)
else{oSlide.moveIt(oSlide.x,oSlide.starty + oSlide[num].sub[sactive].y +subheight*j ); isthere=i}
}else{ //Slide to the one clicked
if(oSlide.y>oSlide.starty + snum*between+between) oSlide.moveBy(0,-pxspeed)
else{oSlide.moveIt(oSlide.x,oSlide.starty + snum*between+between); isthere=i}
if(isthere<oSlide.length-1 || (sactive!=-1 && sisthere<oSlide[num].sub.length-1 && sactive!=oSlide[num].sub.length-1)) setTimeout("moveUp("+num+","+snum+")",timspeed)
function swmenu2(num,snum){
isthere=0;
sisthere=0;
if(active>-1 && snum==-1){
//Hiding submenus
for(j=0;j<oSlide[active].subs;j++){oSlide[active].sub[j].hideIt()}
oSlide[active].bgImg(level0_regular)
oSlide[active].moveIt(0,oSlide[active].starty)
if(sactive>-1){
//Hiding submenus
for(j=0;j<oSlide[active][sactive].sub.length;j++){oSlide[active][sactive].sub[j].hideIt()}
oSlide[active].sub[sactive].bgImg(oSlide[active].sub[sactive].origimg)
oSlide[active].sub[sactive].moveIt(10,oSlide[active].sub[sactive].starty)
//Move back to place
for(i=sactive+1;i<oSlide[active].sub.length;i++){
oSlide[active].sub.moveIt(oSlide[active].sub.x,oSlide[active].sub.starty)
active=num
//Showing submenus
if(snum>-1){
sactive=snum
for(j=0;j<oSlide[num][snum].sub.length;j++){oSlide[num][snum].sub[j].showIt()}
oSlide[num].sub[snum].moveBy(10,3)
oSlide[num].sub[snum].bgImg(level1_round2)
}else{
sactive=-1
for(j=0;j<oSlide[active].subs;j++){oSlide[active].sub[j].showIt()}
oSlide[num].moveBy(10,3)
oSlide[num].bgImg(level0_round)
if(num!=oSlide.length-1) moveDown(num,snum)
else{
isthere=num
moveDown(num,snum)
function moveDown(num,snum){
//if(num==oSlide.length-1) isthere=num
if(snum==-1){
if(oSlide.y<(oSlide[num].subs-1)*subheight+oSlide.starty+between-pxspeed) oSlide.moveBy(0,pxspeed)
else{oSlide.moveIt(oSlide.x,(oSlide[num].subs-1)*subheight+oSlide.starty+between); isthere=i}
}else{
if(oSlide.y<(oSlide[num].subs-1)*subheight+oSlide.starty+between-pxspeed + (oSlide[num][snum].subs-1)*subheight+between) oSlide.moveBy(0,pxspeed)
else{oSlide.moveIt(oSlide.x,(oSlide[num].subs-1)*subheight+oSlide.starty+between + (oSlide[num][snum].subs-1)*subheight+between); isthere=i}
if(snum!=-1){
for(i=snum+1;i<oSlide[num].sub.length;i++){
if(oSlide[num].sub.y<(oSlide[num][snum].subs-1)*subheight+oSlide[num].sub.starty+between-pxspeed) oSlide[num].sub.moveBy(0,pxspeed)
else{oSlide[num].sub.moveIt(oSlide[num].sub.x,(oSlide[num][snum].subs-1)*subheight+oSlide[num].sub.starty+between); sisthere=i}
if(snum==-1){
if(isthere<oSlide.length-1) setTimeout("moveDown("+num+","+snum+")",timspeed)
else going=false
}else{
if(isthere<oSlide.length-1 || (sisthere<oSlide[num].sub.length-1 && snum!=oSlide[num].sub.length-1)) setTimeout("moveDown("+num+","+snum+")",timspeed)
else going=false
var test=0
menus=new Array(); var a=0; var b=0; var c=0; var d=0
function makeMenu(type,text,lnk,target,end){
str=""; tg="";
if(target) tg='target="'+target+'"'
if(!lnk) lnk="#"
self.status=lnk
if(a==0) str='<div id="divSlideCont">n'
if(type=="top"){
menus[a]=new Array();
if(text=="seperator"){
str+='t<div id="divSlide'+a+'" class="clSlide"></div>n'
menus[a].seperator=1
}else{
str+='t<div id="divSlide'+a+'" class="clSlide"><a href="'+lnk+'" '+tg+' onclick="swmenu('+a+',-1,-1); if(bw.ie || bw.ns6) this.blur(); '
if(lnk=="#") str+='return false'
str+='" class="clSlideLinks fade"> '+text+'</a><br></div>n'
menus[a].subs=0; a++; b=0
}else if(type=="sub"){
str+='tt<div id="divSlideSub'+(a-1)+'_'+(B)+'" class="clSlideSub"><a '+tg+' onclick="swmenu('+(a-1)+','+b+',-1); if(bw.ie || bw.ns6) this.blur(); '
str+='" href="'+lnk+'" class="clSlideSubLinks fade">  '+text+'</a><br></div>n'
b++; menus[a-1].subs=b; menus[a-1][b-1]=new Array(); c=0; menus[a-1][b-1].subs=0
}else if(type=="sub2"){
str+='tt<div id="divSlideSub'+(a-1)+'_'+(b-1)+'_'+c+'" class="clSlideSub2"><a '+tg+' href="'+lnk+'" class="clSlideSub2Links fade">  '+text+'</a><br></div>n'
c++; menus[a-1][b-1].subs=c; menus[a-1][b-1][c-1]=new Array(); d=0; menus[a-1][b-1][c-1].subs=0
if(end) str+="</div>"
document.write(str)
function preLoadBackgrounds(){
for(i=0;i<arguments.length;i++){
this=new Image()
this.src=arguments
return this
Nei, jeg er ikke dum. Jeg la inn hele scriptet iom at jeg ikke kan javascript og ikke vet hva dere skulle se etter. Kan ikke se å ha bedt noen lese hele scriptet heller.
Uansett... Om du ikke vet løsningen, så kan du bare la være å legge inn svar vet du :wink:
