C#: [Løst]hjep form 1 og 2 opner seg...
når eg opner programmet så åpner form 1 og 2istede for bare 1.:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace WindowsFormsApplication1
public partial class Form1 : Form
public Form1()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
Form3 form = new Form3();
form.Show();
private void textBox1_TextChanged(object sender, EventArgs e)
private void webBrowser1_DocumentCompleted(object sender, WebBrowserDocumentCompletedEventArgs e)
private void button2_Click(object sender, EventArgs e)
Form2 form = new Form2();
form.Show();
private void Form1_Load(object sender, EventArgs e)
private void button1_Click_1(object sender, EventArgs e)
form.Show();
-ikono
hva er feil?
Du har muligens bundet button1_click to ganger, men det er litt vanskelig å se utifra denne delen av programmet.
Men hvis Form1 og Form2 åpnes når programmet starter, ville jeg tro dette lå i Program.cs.
oki ...
using System;
using System.Linq;
static class Program
/// <summary>
/// The main entry point for the application.
/// </summary>
[sTAThread]
static void Main()
Application.EnableVisualStyles();
Application.SetCompatibleTextRenderingDefault(false);
Application.Run(new Form1());
hei er program.cs
Endret av ikono3
