Tenori-on, tilgjengelig i Norge?
Blåbær
For de som ikke vet hva det er så sjekk ut videoen her:
Se filmen hos Youtube
Tenori-on is an electronic musical instrument, designed and created by Japanese artist, Toshio Iwai and Yu Nishibori of the Music and Human Interface Group, Yamaha Center for Advanced Sound Technology. It consists of a screen, held in the hands, of a sixteen by sixteen grid of LED switches, any of which can be activated in a number of ways to create an evolving musical soundscape. The LED switches are held within a magnesium frame, which has two built-in speakers located on the top of frame, as well as a dial and buttons that control the type of sound and beats per minute produced. There is also an LCD screen on the bottom edge of the frame. Using the connection function, it is possible to play a synchronized session, or to send and receive songs between two of the devices.
Vet lite ellers om instrumentet men virker veldig veldig kul, litt dyr for meg ennå. Men en morsom leketøy som jeg gjerne kunne ha tenkt å prøve.
Endret av Blåbær
altså kp3 og tenori-on her to helt forskjellige ting.
kaosspadene er effektbokser du styrer ved å røre en touchscreen for å kontrolere to parametre.
Tenori-on er en synth/sampler som bruker en matrix-grid for å sequence pitch og time.
Tenori-on er en morsom liten sak men litt vel dyr spør du meg. vet at blant annet Imerslund musikk selger den..
