snabelkabel Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 Hei prøver å legge inn openarena, men har problemer med å kjøre det (på ubuntu).. Hvis jeg trykker på spillet fra menyen skjer det ingenting, men hvis jeg kjører det i console så får jeg dette : ------------------------------------------------------------------------------------------------- root@Snabelkabel:/usr/games# ./openarena ioq3+oa 1.35 linux-i386 Sep 10 2008 ----- FS_Startup ----- Current search path: /root/.openarena/baseoa /usr/share/games/openarena/baseoa/pak7-patch.pk3 (12 files) /usr/share/games/openarena/baseoa/pak6-misc.pk3 (204 files) /usr/share/games/openarena/baseoa/pak5-TA.pk3 (15 files) /usr/share/games/openarena/baseoa/pak4-textures.pk3 (1720 files) /usr/share/games/openarena/baseoa/pak3-music.pk3 (1 files) /usr/share/games/openarena/baseoa/pak2-players.pk3 (610 files) /usr/share/games/openarena/baseoa/pak2-players-mature.pk3 (234 files) /usr/share/games/openarena/baseoa/pak1-maps.pk3 (89 files) /usr/share/games/openarena/baseoa/pak0.pk3 (988 files) /usr/share/games/openarena/baseoa ---------------------- 3873 files in pk3 files execing default.cfg couldn't exec q3config.cfg couldn't exec autoexec.cfg Hunk_Clear: reset the hunk ok ----- Client Initialization ----- Couldn't read q3history. ----- Initializing Renderer ---- ------------------------------- QKEY found. ----- Client Initialization Complete ----- ----- R_Init ----- SDL_Init( SDL_INIT_VIDEO )... OK Initializing OpenGL display Estimated display aspect: 1.333 ...setting mode 3: 640 480 X Error of failed request: BadRequest (invalid request code or no such operation) Major opcode of failed request: 143 (GLX) Minor opcode of failed request: 19 (X_GLXQueryServerString) Serial number of failed request: 15 Current serial number in output stream: 15 ------------------------------------------------------------------------------------------------- Noen som vet hva som må gjøres ? På forhånd takk Snabelkabel Lenke til kommentar
Smif Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 (endret) Velkommen til forumet Kan se ut som du sliter med grafikkdrivere.. (?) Hvilket kort har du? Drivere? Edit: kjør "lspci | grep VGA" Endret 23. desember 2008 av Smif Lenke til kommentar
indietrash Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 ser ut som at du ikke har ordnet 3d-aksellering/skjermkortdrivere. Lenke til kommentar
snabelkabel Skrevet 23. desember 2008 Forfatter Del Skrevet 23. desember 2008 Velkommen til forumet Kan se ut som du sliter med grafikkdrivere.. (?) Hvilket kort har du? Drivere? Edit: kjør "lspci | grep VGA" Er nok skjermkort driverene ja... Har ATI mobility radeon 9700 Etter jeg skjekket lspci, der står det at det er 9600, som er feil, og jeg får ikke installert de nyeste driverene fra ATI sin side, Eller det ser ut som hele installasjonen går greit, men når jeg restarter får jeg opp en beskjed om at den ikke finner drivere og at det blir kjørende i en "dårlig grafikk modus" (husker ikke helt hva det sto ) Så har jeg prøvd å kjøre "aticonfig --initial" kommandoen etter fulgt endel guider men da får jeg beskjeden: "Uninitialized file found, configuring. Segmentation fault". Takk for svar og velkommst melding Snabelkabel Lenke til kommentar
Smif Skrevet 23. desember 2008 Del Skrevet 23. desember 2008 Har du prøvd de åpene driverne da? De gir ikke samme ytelsen, men tror ikke det skal hemme deg for mye. Lenke til kommentar
del_diablo Skrevet 24. desember 2008 Del Skrevet 24. desember 2008 Er nok skjermkort driverene ja... Har ATI mobility radeon 9700 Prøvd forskjellige drivere? Som drivert til bare 9700 eller 9600? Har møt på et lignende problems selv. Lenke til kommentar
